    Animator Gallery
    renderpluginsextensions
    106 Posts 30 Posters 491.8k Views 30 Watching
    • JQLJ
      JQL
      Could you try rendering that with Thea Rich? Please?
      www.casca.pt
      Visit us on facebook!
        No point. The image sequence plays in the viewport so it would not sync with the frame rate.
        Only direct viewport recording would work.
        • JQLJ
          JQL
          Ok, thanks! Then I guess I'll wait for other kind of implementation...
          I've got a certain project wich would really benefit from texture animation, particularly .exr/.hdr files for animated hdri skies.
          Alas, I will probably learn Unreal engine someday.
          www.casca.pt
            Unreal is some more difficult than Unity! πŸ˜‰
            • JQLJ
              JQL
              I've seen nicer images from Unreal than Unity. Basically, lighting is better. However I've heard something about Unity having revamped their lighting... Why is it easier?
              www.casca.pt
              • ntxdaveN
                ntxdave
                So, are you saying this would not work with Animator or was you animation generated with Animator?
                Press F1...thank me later
                  I'm saying to only way to capture the animated texture is to record the viewport.
                  Exporting the animation won't export the animation applied with SKMtools.
                  • ntxdaveN
                    ntxdave
                    That is what I thought you were saying. What did you use to create the animated gif?
                      It's not a gif. It's an image sequence of pngs.
                      If you google fire image sequence you get a result for them at opengameart
                      You could even try for water spray to see if you can find something for your car wash
                        S1919
                        RHas any one worked with Maxwell Render and this plugin?
                        Would be great to hear the workflow!
                        • fredo6F
                          I does not how how to contact Maxwell developers. So today, it is not interfaced with it.
                            M3one
                            This is what I've been doing lately.
                            Thanks for the development
                            • ntxdaveN
                              ntxdave
                              Nice animation. The sound affect adds a lot to it. πŸ˜„
                              • T
                                Treadshot A1
                                Made this animation to illustrate how an action figure of mine transforms. Haven't got it properly rendered yet, but it works.
                                For reference, the action figure is Trinity.
                                  That's fab!
                                    What a transformer! 😎
                                    • fredo6F
                                      Impressive work, both the model and the design of the animation for so many objects!
                                      • chriC
                                        chri
                                        @ithil said:
                                        Hi.
                                        My test animation.
                                        Beautiful explanation.
                                        Any complex assembly should be explained like this.
                                        So now,I wonder if I will not build a fireplace πŸ’š
                                        Chri
                                        • ithilI
                                          ithil
                                          Hi.
                                          My test animation.
                                          This instruction for installation concrete build-up fireplace
                                          PS. How I can make export a higher resolution?
                                          I was not able to export more than 1030 pixels.
                                          Usually I make a SketchUp render double the larger than needed for the video.
                                          And reduce it in the video editor. To achieve a good antialiasing
                                          https://youtu.be/qSyt4vN94VA
                                            shahram67
                                            @fredo6 said:
                                            I would suggest that you, dear beta testers, post (almost) finished animations under this thread (as YouTube videos).
                                            hi all
                                            this is my first animation in sketchup , i make it with animator plugin in sketchup, work by this plugin is very simple ,Making this animation an hour, I thank fredo6
                                            • 4 / 6
