    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 875.7k Views 144 Watching
    • T
      tulacong
      good...cool...cool good ....hehehehe
      • T
        tomaszdrgas
        One suggestion.. Can you make option maybe in the next reliese.. "Stick with orriginal contours" for triangulated mesh.. So the plugin would not make triangles between not adjacent contour lines (for example one point of triangle on hight=2m another h=3m and third h=5m). Could be done by inforcing engine to require for points two the same hights and fird different.. simple check.. I'm crab with programming but could be nice add on.. I usually have to stick with orriginal contours...
          rv1974
          http://www.scriptspot.com/files/u1362/remesh.gif
          http://www.scriptspot.com/3ds-max/scripts/instant-meshes-bridge
          Fredo, could Toposhaper follow the contours as shown on attached gif?
          And, generally speaking, is doable to make a bridge to this external free retopologizer?
          (https://github.com/wjakob/instant-meshes)
          Or make something similar but independent πŸ˜‰ ?
          • fredo6F
            Well. I know how to constrain the triangulation to the contours. Simply, that's not a trivial development and it requires some time. But it should come.
            • P
              penumbra
              Getting some Ruby errors with latest version,
              Date: 28-Aug-16 15:37:45
              An error occurred in CALCULATING TERRAINS
              The operation is fully aborted
              undefined method `x' for nil:NilClass
              mesh.rb: 134 -- ==
              TopoShaperAlgo.rb: 1996 -- block (2 levels) in hull_exclude_nodes_outside
              TopoShaperAlgo.rb: 1996 -- each
              TopoShaperAlgo.rb: 1996 -- block in hull_exclude_nodes_outside
              TopoShaperAlgo.rb: 1979 -- each
              TopoShaperAlgo.rb: 1979 -- hull_exclude_nodes_outside
              TopoShaperAlgo.rb: 1089 -- grid_mark_contours
              TopoShaperAlgo.rb: 535 -- top_analysis_contour
              TopoShaperAlgo.rb: 418 -- top_processing
              TopoShaperTool.rb: 574 -- algo_processing
              TopoShaperTool.rb: 666 -- execute_validate
              TopoShaperPalette.rb: 130 -- execute_from_palette
              TopoShaperPalette.rb: 76 -- notify_from_palette
              TopoShaperPalette.rb: 518 -- call
              TopoShaperPalette.rb: 518 -- block (2 levels) in palette_validate
              body_Lib6Palette.rb: 3058 -- call
              body_Lib6Palette.rb: 3058 -- execute_button
              body_Lib6Palette.rb: 2865 -- onLButtonUp
              Lib6Palette.rb: 93 -- onLButtonUp
              TopoShaperTool.rb: 984 -- onLButtonUp
              Thoughts? If it is helpful i have attached the file i am having trouble with.
              Topo File
              • P
                penumbra
                OK upon further inspection the errors above were causd by a conflict between toposhaper and the flux.io plugin for sketchup. Hope this is helpful for someone.
                • array81A
                  array81
                  After created a terrain, is there a way to show the "grid" on it? I see only the surface but would be nice to see the points of the grid for editing.
                  • fredo6F
                    Are you generating the terrain
                    • from Isocontours
                    • or from a point cloud ?
                    And what is exactly the "grid" you mention. Is it the 'flat' horizontal grid used for projection ?
                      smhbrv
                      Hi everyone.
                      I am an architect in Turkey.
                      I model my terrain but I dont put my road in my terrain.
                      It gives an error. (Unable to triangulate road surface. Try using smaller max road Segment Lenght.)
                      I try lots of times but it gives same error.
                      http://1.1m.yt/z6LbBUo.jpg
                      Please look at attachment. Pls help me.
                      My project
                        smhbrv
                        @smhbrv said:
                        Hi everyone.
                        Who can help me ?
                          Why not use the SandBox / Project ?
                          • C
                            cyclefanatic
                            Hello Fredo: I just started using Toposhaper. It works fine, but the dialog box text is so small I can hardly see the text. Is there a way to adjust the text size? I am using an iMac with Retina display.
                            Thank you for all your contributions...
                            Jim S
                            • fredo6F
                              NEW RELEASE: TopoShaper v1.3a - 17 Jan 17
                              This is a minor release with SU2017 certification
                                dvdstwrt
                                I am having trouble installing the toposhaper extension in SUMaker2017 and get the following after restarting SU. Any suggestions would be appreciated
                                  You seem to have missed off the error message ?
                                  Have you also installed the needed LibFredo?
                                  Also check that both Extensions are activated and restart SketchUp to ensure any changes/additions are fully integrated...
                                  • E
                                    Einstein
                                    Fredo, your plugins are mindblowing!
                                    • john2J
                                      john2
                                      Every time I start sketchup I am receiving the following pop up.
                                      All my fredo plugins are updated. I checked it with the feature of fredo tools itself.
                                      What should I do to resolve this issue?
                                      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                        Have you also installed the very latest LibFredo ?
                                        • john2J
                                          john2
                                          Yes
                                            Have you re-launched SketchUp ?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
