    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • P
      penumbra
      Getting some Ruby errors with latest version,
      Date: 28-Aug-16 15:37:45
      An error occurred in CALCULATING TERRAINS
      The operation is fully aborted
      undefined method `x' for nil:NilClass
      mesh.rb: 134 -- ==
      TopoShaperAlgo.rb: 1996 -- block (2 levels) in hull_exclude_nodes_outside
      TopoShaperAlgo.rb: 1996 -- each
      TopoShaperAlgo.rb: 1996 -- block in hull_exclude_nodes_outside
      TopoShaperAlgo.rb: 1979 -- each
      TopoShaperAlgo.rb: 1979 -- hull_exclude_nodes_outside
      TopoShaperAlgo.rb: 1089 -- grid_mark_contours
      TopoShaperAlgo.rb: 535 -- top_analysis_contour
      TopoShaperAlgo.rb: 418 -- top_processing
      TopoShaperTool.rb: 574 -- algo_processing
      TopoShaperTool.rb: 666 -- execute_validate
      TopoShaperPalette.rb: 130 -- execute_from_palette
      TopoShaperPalette.rb: 76 -- notify_from_palette
      TopoShaperPalette.rb: 518 -- call
      TopoShaperPalette.rb: 518 -- block (2 levels) in palette_validate
      body_Lib6Palette.rb: 3058 -- call
      body_Lib6Palette.rb: 3058 -- execute_button
      body_Lib6Palette.rb: 2865 -- onLButtonUp
      Lib6Palette.rb: 93 -- onLButtonUp
      TopoShaperTool.rb: 984 -- onLButtonUp
      Thoughts? If it is helpful i have attached the file i am having trouble with.
      Topo File
      • P
        penumbra
        OK upon further inspection the errors above were causd by a conflict between toposhaper and the flux.io plugin for sketchup. Hope this is helpful for someone.
        • array81A
          array81
          After created a terrain, is there a way to show the "grid" on it? I see only the surface but would be nice to see the points of the grid for editing.
          • fredo6F
            Are you generating the terrain
            • from Isocontours
            • or from a point cloud ?
            And what is exactly the "grid" you mention. Is it the 'flat' horizontal grid used for projection ?
              smhbrv
              Hi everyone.
              I am an architect in Turkey.
              I model my terrain but I dont put my road in my terrain.
              It gives an error. (Unable to triangulate road surface. Try using smaller max road Segment Lenght.)
              I try lots of times but it gives same error.
              http://1.1m.yt/z6LbBUo.jpg
              Please look at attachment. Pls help me.
              My project
                smhbrv
                @smhbrv said:
                Hi everyone.
                Who can help me ?
                  Why not use the SandBox / Project ?
                  • C
                    cyclefanatic
                    Hello Fredo: I just started using Toposhaper. It works fine, but the dialog box text is so small I can hardly see the text. Is there a way to adjust the text size? I am using an iMac with Retina display.
                    Thank you for all your contributions...
                    Jim S
                    • fredo6F
                      NEW RELEASE: TopoShaper v1.3a - 17 Jan 17
                      This is a minor release with SU2017 certification
                        dvdstwrt
                        I am having trouble installing the toposhaper extension in SUMaker2017 and get the following after restarting SU. Any suggestions would be appreciated
                          You seem to have missed off the error message ?
                          Have you also installed the needed LibFredo?
                          Also check that both Extensions are activated and restart SketchUp to ensure any changes/additions are fully integrated...
                          • E
                            Einstein
                            Fredo, your plugins are mindblowing!
                            • john2J
                              john2
                              Every time I start sketchup I am receiving the following pop up.
                              All my fredo plugins are updated. I checked it with the feature of fredo tools itself.
                              What should I do to resolve this issue?
                              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                Have you also installed the very latest LibFredo ?
                                • john2J
                                  john2
                                  Yes
                                    Have you re-launched SketchUp ?
                                    • john2J
                                      john2
                                      Yes. Every time I start sketchup, I am getting this dialogue box.
                                        Is the LibFredo activated in the Extension Manager dialog ?
                                        • john2J
                                          john2
                                          I am using Sketchup 2016 version. The libfredo is activated and I see a tick mark right next to its name in the list which I accessed by going to System preferences>extensions
                                          • fredo6F
                                            I think the best would be to have a snapshot of your Sketchup Plugins Directory. It looks like there is an old LibFredo6 somewhere.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
