    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
      rv1974
      http://www.scriptspot.com/files/u1362/remesh.gif
      http://www.scriptspot.com/3ds-max/scripts/instant-meshes-bridge
      Fredo, could Toposhaper follow the contours as shown on attached gif?
      And, generally speaking, is doable to make a bridge to this external free retopologizer?
      (https://github.com/wjakob/instant-meshes)
      Or make something similar but independent πŸ˜‰ ?
      • fredo6F
        Well. I know how to constrain the triangulation to the contours. Simply, that's not a trivial development and it requires some time. But it should come.
        • P
          penumbra
          Getting some Ruby errors with latest version,
          Date: 28-Aug-16 15:37:45
          An error occurred in CALCULATING TERRAINS
          The operation is fully aborted
          undefined method `x' for nil:NilClass
          mesh.rb: 134 -- ==
          TopoShaperAlgo.rb: 1996 -- block (2 levels) in hull_exclude_nodes_outside
          TopoShaperAlgo.rb: 1996 -- each
          TopoShaperAlgo.rb: 1996 -- block in hull_exclude_nodes_outside
          TopoShaperAlgo.rb: 1979 -- each
          TopoShaperAlgo.rb: 1979 -- hull_exclude_nodes_outside
          TopoShaperAlgo.rb: 1089 -- grid_mark_contours
          TopoShaperAlgo.rb: 535 -- top_analysis_contour
          TopoShaperAlgo.rb: 418 -- top_processing
          TopoShaperTool.rb: 574 -- algo_processing
          TopoShaperTool.rb: 666 -- execute_validate
          TopoShaperPalette.rb: 130 -- execute_from_palette
          TopoShaperPalette.rb: 76 -- notify_from_palette
          TopoShaperPalette.rb: 518 -- call
          TopoShaperPalette.rb: 518 -- block (2 levels) in palette_validate
          body_Lib6Palette.rb: 3058 -- call
          body_Lib6Palette.rb: 3058 -- execute_button
          body_Lib6Palette.rb: 2865 -- onLButtonUp
          Lib6Palette.rb: 93 -- onLButtonUp
          TopoShaperTool.rb: 984 -- onLButtonUp
          Thoughts? If it is helpful i have attached the file i am having trouble with.
          Topo File
          • P
            penumbra
            OK upon further inspection the errors above were causd by a conflict between toposhaper and the flux.io plugin for sketchup. Hope this is helpful for someone.
            • array81A
              array81
              After created a terrain, is there a way to show the "grid" on it? I see only the surface but would be nice to see the points of the grid for editing.
              • fredo6F
                Are you generating the terrain
                • from Isocontours
                • or from a point cloud ?
                And what is exactly the "grid" you mention. Is it the 'flat' horizontal grid used for projection ?
                  smhbrv
                  Hi everyone.
                  I am an architect in Turkey.
                  I model my terrain but I dont put my road in my terrain.
                  It gives an error. (Unable to triangulate road surface. Try using smaller max road Segment Lenght.)
                  I try lots of times but it gives same error.
                  http://1.1m.yt/z6LbBUo.jpg
                  Please look at attachment. Pls help me.
                  My project
                    smhbrv
                    @smhbrv said:
                    Hi everyone.
                    Who can help me ?
                      Why not use the SandBox / Project ?
                      • C
                        cyclefanatic
                        Hello Fredo: I just started using Toposhaper. It works fine, but the dialog box text is so small I can hardly see the text. Is there a way to adjust the text size? I am using an iMac with Retina display.
                        Thank you for all your contributions...
                        Jim S
                        • fredo6F
                          NEW RELEASE: TopoShaper v1.3a - 17 Jan 17
                          This is a minor release with SU2017 certification
                            dvdstwrt
                            I am having trouble installing the toposhaper extension in SUMaker2017 and get the following after restarting SU. Any suggestions would be appreciated
                              You seem to have missed off the error message ?
                              Have you also installed the needed LibFredo?
                              Also check that both Extensions are activated and restart SketchUp to ensure any changes/additions are fully integrated...
                              • E
                                Einstein
                                Fredo, your plugins are mindblowing!
                                • john2J
                                  john2
                                  Every time I start sketchup I am receiving the following pop up.
                                  All my fredo plugins are updated. I checked it with the feature of fredo tools itself.
                                  What should I do to resolve this issue?
                                  Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                    Have you also installed the very latest LibFredo ?
                                    • john2J
                                      john2
                                      Yes
                                        Have you re-launched SketchUp ?
                                        • john2J
                                          john2
                                          Yes. Every time I start sketchup, I am getting this dialogue box.
                                            Is the LibFredo activated in the Extension Manager dialog ?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
