    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    456 Posts 144 Posters 830.9k Views 143 Watching
    • fredo6F Offline
      Well. I know how to constrain the triangulation to the contours. Simply, that's not a trivial development and it requires some time. But it should come.
        penumbra
        Getting some Ruby errors with latest version,
        Date: 28-Aug-16 15:37:45
        An error occurred in CALCULATING TERRAINS
        The operation is fully aborted
        undefined method `x' for nil:NilClass
        mesh.rb: 134 -- ==
        TopoShaperAlgo.rb: 1996 -- block (2 levels) in hull_exclude_nodes_outside
        TopoShaperAlgo.rb: 1996 -- each
        TopoShaperAlgo.rb: 1996 -- block in hull_exclude_nodes_outside
        TopoShaperAlgo.rb: 1979 -- each
        TopoShaperAlgo.rb: 1979 -- hull_exclude_nodes_outside
        TopoShaperAlgo.rb: 1089 -- grid_mark_contours
        TopoShaperAlgo.rb: 535 -- top_analysis_contour
        TopoShaperAlgo.rb: 418 -- top_processing
        TopoShaperTool.rb: 574 -- algo_processing
        TopoShaperTool.rb: 666 -- execute_validate
        TopoShaperPalette.rb: 130 -- execute_from_palette
        TopoShaperPalette.rb: 76 -- notify_from_palette
        TopoShaperPalette.rb: 518 -- call
        TopoShaperPalette.rb: 518 -- block (2 levels) in palette_validate
        body_Lib6Palette.rb: 3058 -- call
        body_Lib6Palette.rb: 3058 -- execute_button
        body_Lib6Palette.rb: 2865 -- onLButtonUp
        Lib6Palette.rb: 93 -- onLButtonUp
        TopoShaperTool.rb: 984 -- onLButtonUp
        Thoughts? If it is helpful i have attached the file i am having trouble with.
        Topo File
          penumbra
          OK upon further inspection the errors above were causd by a conflict between toposhaper and the flux.io plugin for sketchup. Hope this is helpful for someone.
          • array81A Offline
            array81
            After created a terrain, is there a way to show the "grid" on it? I see only the surface but would be nice to see the points of the grid for editing.
            • fredo6F Offline
              Are you generating the terrain
              • from Isocontours
              • or from a point cloud ?
              And what is exactly the "grid" you mention. Is it the 'flat' horizontal grid used for projection ?
                smhbrv
                Hi everyone.
                I am an architect in Turkey.
                I model my terrain but I dont put my road in my terrain.
                It gives an error. (Unable to triangulate road surface. Try using smaller max road Segment Lenght.)
                I try lots of times but it gives same error.
                http://1.1m.yt/z6LbBUo.jpg
                Please look at attachment. Pls help me.
                My project
                  smhbrv
                  @smhbrv said:
                  Hi everyone.
                  Who can help me ?
                    Why not use the SandBox / Project ?
                      cyclefanatic
                      Hello Fredo: I just started using Toposhaper. It works fine, but the dialog box text is so small I can hardly see the text. Is there a way to adjust the text size? I am using an iMac with Retina display.
                      Thank you for all your contributions...
                      Jim S
                      • fredo6F Offline
                        NEW RELEASE: TopoShaper v1.3a - 17 Jan 17
                        This is a minor release with SU2017 certification
                          dvdstwrt
                          I am having trouble installing the toposhaper extension in SUMaker2017 and get the following after restarting SU. Any suggestions would be appreciated
                          • TIGT Online
                            You seem to have missed off the error message ?
                            Have you also installed the needed LibFredo?
                            Also check that both Extensions are activated and restart SketchUp to ensure any changes/additions are fully integrated...
                            • E Offline
                              Einstein
                              Fredo, your plugins are mindblowing!
                              • john2J Offline
                                john2
                                Every time I start sketchup I am receiving the following pop up.
                                All my fredo plugins are updated. I checked it with the feature of fredo tools itself.
                                What should I do to resolve this issue?
                                Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                • TIGT Online
                                  Have you also installed the very latest LibFredo ?
                                  • john2J Offline
                                    john2
                                    Yes
                                      Have you re-launched SketchUp ?
                                      • john2J Offline
                                        john2
                                        Yes. Every time I start sketchup, I am getting this dialogue box.
                                        • TIGT Online
                                          Is the LibFredo activated in the Extension Manager dialog ?
                                          • john2J Offline
                                            john2
                                            I am using Sketchup 2016 version. The libfredo is activated and I see a tick mark right next to its name in the list which I accessed by going to System preferences>extensions
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
