    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 875.7k Views 144 Watching
    • fredo6F
      Are you generating the terrain
      • from Isocontours
      • or from a point cloud ?
      And what is exactly the "grid" you mention. Is it the 'flat' horizontal grid used for projection ?
        smhbrv
        Hi everyone.
        I am an architect in Turkey.
        I model my terrain but I dont put my road in my terrain.
        It gives an error. (Unable to triangulate road surface. Try using smaller max road Segment Lenght.)
        I try lots of times but it gives same error.
        http://1.1m.yt/z6LbBUo.jpg
        Please look at attachment. Pls help me.
        My project
          smhbrv
          @smhbrv said:
          Hi everyone.
          Who can help me ?
            Why not use the SandBox / Project ?
            • C
              cyclefanatic
              Hello Fredo: I just started using Toposhaper. It works fine, but the dialog box text is so small I can hardly see the text. Is there a way to adjust the text size? I am using an iMac with Retina display.
              Thank you for all your contributions...
              Jim S
              • fredo6F
                NEW RELEASE: TopoShaper v1.3a - 17 Jan 17
                This is a minor release with SU2017 certification
                  dvdstwrt
                  I am having trouble installing the toposhaper extension in SUMaker2017 and get the following after restarting SU. Any suggestions would be appreciated
                    You seem to have missed off the error message ?
                    Have you also installed the needed LibFredo?
                    Also check that both Extensions are activated and restart SketchUp to ensure any changes/additions are fully integrated...
                    • E
                      Einstein
                      Fredo, your plugins are mindblowing!
                      • john2J
                        john2
                        Every time I start sketchup I am receiving the following pop up.
                        All my fredo plugins are updated. I checked it with the feature of fredo tools itself.
                        What should I do to resolve this issue?
                        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                          Have you also installed the very latest LibFredo ?
                          • john2J
                            john2
                            Yes
                              Have you re-launched SketchUp ?
                              • john2J
                                john2
                                Yes. Every time I start sketchup, I am getting this dialogue box.
                                  Is the LibFredo activated in the Extension Manager dialog ?
                                  • john2J
                                    john2
                                    I am using Sketchup 2016 version. The libfredo is activated and I see a tick mark right next to its name in the list which I accessed by going to System preferences>extensions
                                    • fredo6F
                                      I think the best would be to have a snapshot of your Sketchup Plugins Directory. It looks like there is an old LibFredo6 somewhere.
                                      • fredo6F
                                        WARNING: Potential issues in TopoShaper (IsoContour) with LibFredo6 7.7d.
                                        I will publish a fix in LibFredo6 v7.7e as soon as the Extension Ware House site works again.
                                        • H
                                          hiryfi
                                          Greetings,
                                          I am a extreme beginner with SU and am trying to use toposhaper to generate a topo of a piece of land I recently purchased. Reading, researching, and a lot of trial and error!
                                          I am using previous survey data and septic design plans to do this. I have a .txt file with 144 points of xyz data. I imported that into SU with point gadget in a .csv file and have all the points imported. My problem is getting toposhaper to accept the points. I either get a I have tried to install toposhaper with libfredo6_v7.7e prior multiple times with no luck. I could not find the auto-installer and have installed via the extension manager. I'm sure I am screwing something up, just can't pinpoint what I am doing wrong. Any tips are much appreciated. I will continue to search through the libfredo post as well. I have attached my data and some screen shots of the messages I am generating. I see others have had similar issues so I'm sure its some user issue on my end.
                                          I am using SU Make 2017, Windows 7
                                          Thanks,
                                          hiryfi
                                          Lot 19S Topo 7.25.15 (1).txt
                                          pdf given from data, firm would not give .dwg due to liability.
                                          LibFredo6Trace_17_1506099534865.txt
                                          SU17
                                          Very Green
                                          • fredo6F
                                            @hiryfi
                                            From the trace, it seems you have installed LibFredo6, TopoShaper (and FredoTools) correctly. Can you confirm?
                                            For generating a terrain from the point cloud, Toposhaper requires that the points are
                                            • Construction point (Guide Point in Sketchup), positioned at their altitude.
                                            • all enclosed within a group
                                            • If you add one or several faces within the group, they will delimit the boundary of the terrain by projection.
                                            There are tools to import point clouds from CSV or TXT file (one by Didier Bur and one by TIG), I think.
                                            Also, have a look at the videos in the first post of this thread for TopoShaper generation of terrain from point clouds.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
