    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • HieruH Offline
      Hieru
      Thanks Thomas πŸ‘
      www.davidhier.co.uk
      • HieruH Offline
        Hieru
        @Kaas
        Sometimes you can bend over backwards to keep loops to a minimum (see examples either side of central control meshes)...
        ...only to find that there isn't that much difference in the poly count:
        In this instance you might even find that using RoundCorners is the most economic and efficient way to model this form.
        Corner.skp
        www.davidhier.co.uk
          kaas
          @HorNoxx; thanks for the suggestion. I already found and use that gem by TIG.
          @Hieru; thanks for the effort and insight. It confirms my idea that subD in some cases might lead to more faces than conventional methods like roundcorner or native tools. Still learning though and lots of fun.
          stackStove_cubi_test1.skp
          • HieruH Offline
            Hieru
            Happy to help πŸ‘ . I'll take a look at your model tomorrow, but from the looks of things your workflow is coming along nicely (certainly more advanced than when I was starting out).
            One thing I will add is that sometimes the extra geometry is worth it e.g. for UV mapping or selling models in different formats.
            On the topic of UV mapping, I suspect that my left-hand control mesh might be the better approach for mapping. Hopefully someone who knows more about UV unwrapping will be able to confirm or refute this.
            www.davidhier.co.uk
              kaas
              I was thinking about the mapping as well. there is some stretching visible so need to fix those. Its lots of fun. Artisan experience from few years ago helps a lot - its knife tool as well.
              • HieruH Offline
                Hieru
                I still use Artisan where SubD isn't appropriate, but like you I use it in conjunction with SubD. As well as the knife tool I use it to preview subdivision as I'm modelling - mostly because it won't triangulate areas I haven't finished quad modelling, but also because it can give a more detailed preview of the flow and detail of the subdivision.
                www.davidhier.co.uk
                  kaas
                  Wish: a universal toggle all SubD on/off (selected maybe) as right click option would be welcome. If you have an assembly of several subD's this is nice to have.
                  • HieruH Offline
                    Hieru
                    Isn't that in the works Thomas?
                    www.davidhier.co.uk
                    • HieruH Offline
                      Hieru
                      Just found afew minutes to look at your model properly Kaas. Really nice job.
                      I couldn't help putting on my Quad Police uniform πŸ˜† and tackling a few unwanted tris (I lost a few loops in the process too).
                      I've highlighted the main areas that have been modified.
                      stackStove_cubi_test2.skp
                      www.davidhier.co.uk
                        kaas
                        Much appreciated Hieru, I like the Quad Police. Your changes seem very logical. Thanks.
                        • Rich O BrienR Online
                          http://sketchucation.com/forums/download/file.php?id=142064
                          • ithilI Offline
                            ithil
                            I tried to make a model for cutting plywood
                            • pbacotP Offline
                              Wow, Ithil!
                              • HornOxxH Offline
                                HornOxx
                                I love it!! - please continue this report...
                                never trust a skinny cook
                                • cottyC Offline
                                  cotty
                                  Some very nice SubD examples (together with QuadFaceTools, VertexTools, ...) from "Winning with SketchUp"...
                                  https://www.youtube.com/results?search_query=%22winning+with+sketchup%22+subd
                                  my SketchUp gallery
                                  • soloS Offline
                                    @collage architecture said:
                                    Still learning the workflow in quad and vertices.
                                    Advertising removed and warning issued.
                                    • Collage ArchitectureC Offline
                                      sorry for mistake I've made,I don't know how to post an image..I'm still learning how to manage quads and vertices, Thomthom's toolset is a magic
                                      http://uploads.tapatalk-cdn.com/20161018/0b2e014a72f17d8b0a950a7c0a4e57f3.jpg
                                      I love Sketchup
                                      • cottyC Offline
                                        cotty
                                        Another simple example...
                                        redgreen.skp
                                        my SketchUp gallery
                                        • HornOxxH Offline
                                          HornOxx
                                          It was time to do a little exercise again ...
                                          My sons asked me if I could do Bender from the Futurama series - so I did it πŸ˜‰
                                          Bender - somehow I like that guy πŸ˜„
                                          Bender Proxy.skp
                                            That's a brilliant model!! πŸ˜„
                                            • 11
                                            • 82
                                            • 83
                                            • 9 / 83
