    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.1m Views 79 Watching
      @nlipovac said:
      @thomthom said:
      Nice! That actually looks like a nice model to test OpenSubdiv UV mapping handling with. Do you mind sharing the model?
      How is it coming along, any sneak peek? 😎
      It's been slow over the summer. Currently on vacation. Things will spin up in a few weeks. πŸ˜„
      • cottyC
        cotty
        Of course no problem...
        subd_knife.skp
        my SketchUp gallery
          [edg3d:q5l0hefm]0BS0SdGtKkVqlg4[/edg3d:q5l0hefm]
          • N
            nlipovac
            @rich o brien said:
            [attachment=0:lutopfq9]<!-- ia0 -->grab_22_09_2016_001.png<!-- ia0 -->[/attachment:lutopfq9]
            [edg3d:lutopfq9]0BS0SdGtKkVqlg4[/edg3d:lutopfq9]
            Looks great! πŸ€“
            Texturing inside Substance Designer?
            • HieruH
              Hieru
              Quick question.
              What happens if you share a SubD model (without converting to plain mesh) and someone without SubD opens it? Do they just get the control mesh?
              www.davidhier.co.uk
                Yea, it'll appear like any other SketchUp group/component.
                • K
                  kaas
                  If I could ask the experts; I'm totally new to subD. Trying it out for making furniture.
                  Started making the frame for a Stack Stove Cubi. Whats the best strategy for the indicated areas? The easy way is to just continue the lines from the horizontal frame onto the leg. But I'm trying to keep the polycount as low as possible as well.
                  Any suggestions?
                  stackCubi_leg.skp
                  • HornOxxH
                    HornOxx
                    Hi Kaas
                    I would recommend TigΒ΄s Split Tools which generate quads at the connection points like sketched below.
                    http://sketchucation.com/forums/viewtopic.php?t=43376
                    https://www.youtube.com/watch?v=hcGGcLndeTE
                    never trust a skinny cook
                    • HieruH
                      Hieru
                      Thanks Thomas πŸ‘
                      www.davidhier.co.uk
                      • HieruH
                        Hieru
                        @Kaas
                        Sometimes you can bend over backwards to keep loops to a minimum (see examples either side of central control meshes)...
                        ...only to find that there isn't that much difference in the poly count:
                        In this instance you might even find that using RoundCorners is the most economic and efficient way to model this form.
                        Corner.skp
                        www.davidhier.co.uk
                        • K
                          kaas
                          @HorNoxx; thanks for the suggestion. I already found and use that gem by TIG.
                          @Hieru; thanks for the effort and insight. It confirms my idea that subD in some cases might lead to more faces than conventional methods like roundcorner or native tools. Still learning though and lots of fun.
                          stackStove_cubi_test1.skp
                          • HieruH
                            Hieru
                            Happy to help πŸ‘ . I'll take a look at your model tomorrow, but from the looks of things your workflow is coming along nicely (certainly more advanced than when I was starting out).
                            One thing I will add is that sometimes the extra geometry is worth it e.g. for UV mapping or selling models in different formats.
                            On the topic of UV mapping, I suspect that my left-hand control mesh might be the better approach for mapping. Hopefully someone who knows more about UV unwrapping will be able to confirm or refute this.
                            www.davidhier.co.uk
                            • K
                              kaas
                              I was thinking about the mapping as well. there is some stretching visible so need to fix those. Its lots of fun. Artisan experience from few years ago helps a lot - its knife tool as well.
                              • HieruH
                                Hieru
                                I still use Artisan where SubD isn't appropriate, but like you I use it in conjunction with SubD. As well as the knife tool I use it to preview subdivision as I'm modelling - mostly because it won't triangulate areas I haven't finished quad modelling, but also because it can give a more detailed preview of the flow and detail of the subdivision.
                                www.davidhier.co.uk
                                • K
                                  kaas
                                  Wish: a universal toggle all SubD on/off (selected maybe) as right click option would be welcome. If you have an assembly of several subD's this is nice to have.
                                  • HieruH
                                    Hieru
                                    Isn't that in the works Thomas?
                                    www.davidhier.co.uk
                                    • HieruH
                                      Hieru
                                      Just found afew minutes to look at your model properly Kaas. Really nice job.
                                      I couldn't help putting on my Quad Police uniform πŸ˜† and tackling a few unwanted tris (I lost a few loops in the process too).
                                      I've highlighted the main areas that have been modified.
                                      stackStove_cubi_test2.skp
                                      www.davidhier.co.uk
                                      • K
                                        kaas
                                        Much appreciated Hieru, I like the Quad Police. Your changes seem very logical. Thanks.
                                          http://sketchucation.com/forums/download/file.php?id=142064
                                          • ithilI
                                            ithil
                                            I tried to make a model for cutting plywood
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 83
                                            • 84
                                            • 32 / 84
