    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • HieruH
      Hieru
      Quick question.
      What happens if you share a SubD model (without converting to plain mesh) and someone without SubD opens it? Do they just get the control mesh?
      www.davidhier.co.uk
        Yea, it'll appear like any other SketchUp group/component.
        • K
          kaas
          If I could ask the experts; I'm totally new to subD. Trying it out for making furniture.
          Started making the frame for a Stack Stove Cubi. Whats the best strategy for the indicated areas? The easy way is to just continue the lines from the horizontal frame onto the leg. But I'm trying to keep the polycount as low as possible as well.
          Any suggestions?
          stackCubi_leg.skp
          • HornOxxH
            HornOxx
            Hi Kaas
            I would recommend TigΒ΄s Split Tools which generate quads at the connection points like sketched below.
            http://sketchucation.com/forums/viewtopic.php?t=43376
            https://www.youtube.com/watch?v=hcGGcLndeTE
            never trust a skinny cook
            • HieruH
              Hieru
              Thanks Thomas πŸ‘
              www.davidhier.co.uk
              • HieruH
                Hieru
                @Kaas
                Sometimes you can bend over backwards to keep loops to a minimum (see examples either side of central control meshes)...
                ...only to find that there isn't that much difference in the poly count:
                In this instance you might even find that using RoundCorners is the most economic and efficient way to model this form.
                Corner.skp
                www.davidhier.co.uk
                • K
                  kaas
                  @HorNoxx; thanks for the suggestion. I already found and use that gem by TIG.
                  @Hieru; thanks for the effort and insight. It confirms my idea that subD in some cases might lead to more faces than conventional methods like roundcorner or native tools. Still learning though and lots of fun.
                  stackStove_cubi_test1.skp
                  • HieruH
                    Hieru
                    Happy to help πŸ‘ . I'll take a look at your model tomorrow, but from the looks of things your workflow is coming along nicely (certainly more advanced than when I was starting out).
                    One thing I will add is that sometimes the extra geometry is worth it e.g. for UV mapping or selling models in different formats.
                    On the topic of UV mapping, I suspect that my left-hand control mesh might be the better approach for mapping. Hopefully someone who knows more about UV unwrapping will be able to confirm or refute this.
                    www.davidhier.co.uk
                    • K
                      kaas
                      I was thinking about the mapping as well. there is some stretching visible so need to fix those. Its lots of fun. Artisan experience from few years ago helps a lot - its knife tool as well.
                      • HieruH
                        Hieru
                        I still use Artisan where SubD isn't appropriate, but like you I use it in conjunction with SubD. As well as the knife tool I use it to preview subdivision as I'm modelling - mostly because it won't triangulate areas I haven't finished quad modelling, but also because it can give a more detailed preview of the flow and detail of the subdivision.
                        www.davidhier.co.uk
                        • K
                          kaas
                          Wish: a universal toggle all SubD on/off (selected maybe) as right click option would be welcome. If you have an assembly of several subD's this is nice to have.
                          • HieruH
                            Hieru
                            Isn't that in the works Thomas?
                            www.davidhier.co.uk
                            • HieruH
                              Hieru
                              Just found afew minutes to look at your model properly Kaas. Really nice job.
                              I couldn't help putting on my Quad Police uniform πŸ˜† and tackling a few unwanted tris (I lost a few loops in the process too).
                              I've highlighted the main areas that have been modified.
                              stackStove_cubi_test2.skp
                              www.davidhier.co.uk
                              • K
                                kaas
                                Much appreciated Hieru, I like the Quad Police. Your changes seem very logical. Thanks.
                                  http://sketchucation.com/forums/download/file.php?id=142064
                                  • ithilI
                                    ithil
                                    I tried to make a model for cutting plywood
                                    • pbacotP
                                      Wow, Ithil!
                                      • HornOxxH
                                        HornOxx
                                        I love it!! - please continue this report...
                                        • cottyC
                                          cotty
                                          Some very nice SubD examples (together with QuadFaceTools, VertexTools, ...) from "Winning with SketchUp"...
                                          https://www.youtube.com/results?search_query=%22winning+with+sketchup%22+subd
                                          my SketchUp gallery
                                          • soloS
                                            @collage architecture said:
                                            Still learning the workflow in quad and vertices.
                                            Advertising removed and warning issued.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 83
                                            • 84
                                            • 32 / 84
