    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 965.5k Views 79 Watching
    • HornOxxH Offline
      HornOxx
      Hi Dave
      most of this particular model is done in Basic SketchUp as shown in the added video.
      So the lines around the hole (your question 2) were simply moved or drawn with
      native SU-tools in this case - there was no magic stick πŸ˜›
      The mesh change 1B (your question 1) I just did to hit the edges of the octagon-hole
      perfectly in order to just get quads.
      For lifting the 4 lines I used Vertex Tools. If you hold CTRL, the lifting of the
      Vertex Tool gizmo will create a new "tube" section. If you donΒ΄t have Vertex Tools,
      you can do all this with basic SU-tools as well but it is important to avoid any internal
      faces. Also the scaling can be done with basic SU-tools as well. But using Vertex Tools
      for scaling, rotating, moving ... is much better in order do get a "clean" Quad mesh...
      Also Quadface Tools are important if you want or need to "divide" your model in certain
      sections or if you want to add, select or edit loops without doing all that manually...
      I am far from understanding all that and am just starting to discover these functions by
      testing and playing πŸ˜‰
      never trust a skinny cook
        cuttingedge
        QFT, Vertex Tools & SubD, proved to be the most enjoyable tools for modeling. Here's a WIP of my earpods..
        apple earpods WIP
          you could wind up with some huge files. Is this normal?
          Yep! Basically SKetshup is a "box modeling" program, not a "Subdivision" program!
          It's was not provided for that!
          We are lucky that works for some little objects, but that will be very difficult for biggest project! πŸ˜‰
          Manage millions of polygons is not its speciality! πŸ’š
          • JQLJ Offline
            JQL
            If they're working with render engines and if you have Thea Interactive Rendering capabilities, you'll be able to fire up a render with subdivision without Sketchup Open GL viewport even being aware of it!
            Then it will be fast even for millions of polys, if you have enough power in your CPU+GPU combo, it will actually be a zip!
            www.casca.pt
            Visit us on facebook!
              Yes thanks to Proxies! πŸ˜‰
              • ntxdaveN Offline
                ntxdave
                @HornOxx Thanks a ton. I see what I did wrong. I thought I had used the Ctrl when using the Gizmo tool but I must not have.
                I tried selecting the grids at both end and scaling at the same time but for some reason it would not do it. I was able to do it by scaling one end at a time.
                I wish the ConnetEdges tool that is part of the QFT tool would give you a little better control over the division (like being able to split the selected surface evenly) but I also know that you can use the move tool to position the rings/loops so there is more than one way to get the job done. I also like the way you went into wire frame mode and used guide lines to drag the ring/loops. That was pretty neat also.
                Ultimately, I would like to be able to put together a beginners guide to quad face modeling.
                Here are the sections I would like to see:
                • What is Quad Modeling
                • Why is it necessary/Why would you want to use it
                • Step by step example
                • This would be a step by step guide with pictures that showed each step with an explanation of why you are performing it* I think a written guide might work better than a video but maybe some animated gifs because the newbie needs to understand both how and why you are performing the step* The sample model needs to be comprehensive enough to see all (or at least most) of the features yet not so complicated that the beginner cannot understand what is being done
                • Glossary
                • Poly* Quad* Tri* N-Gon* Other Terms
                Just some current thoughts - a long way off though.
                • ntxdaveN Offline
                  ntxdave
                  Another dumb question: What are Proxies?
                  • BoxB Offline
                    Here's a quicky to show how to slice things up with QFT.
                    http://i155.photobucket.com/albums/s296/storeben/SU/Qft.gif
                    • HornOxxH Offline
                      HornOxx
                      @ntxdave said:
                      What are Proxies?
                      The Proxy in this context is the simple raw geometry.
                      Also for example Artisan uses this term - also there is a simple raw geometry (the proxy)
                      which then gets subdivided in a much complexer and biger geometry. The Proxy allways is the
                      "placeholder"(? donΒ΄t know if that word exists in English?) for something modified.
                      A lot of Render tools replace simple Proxys with most complex replace-geometrys or components.
                      So you can draw (or use) for example a simple line-box in SU, wich then gets replaces within a renderer by a most complex 3D-tree...
                        Is the colour there from post processing? Or is that actually a SketchUp style?
                          Indeed. At the moment I'm moving towards using OpenSubdiv as subdivision engine. It actually have support for fast display of the subdivided mesh for OpenGL and DirectX - however the SU API doesn't provide access to the GL pipeline. Otherwise you'd have it override the normal drawing of the mesh in high-poly while SU itself would only know about the control mesh. dreams
                          But I got some ideas here ... need to make some experiments. πŸ€“
                            Have you looked at the links on the SUbD site?
                            http://evilsoftwareempire.com/subd/quads
                            Currently there are four links to external sites that describe the general concept of tris, quads and ngons. Is there information there you feel is missing?
                            • jiminy-billy-bobJ Offline
                              jiminy-billy-bob
                              Tomasz did it! It needs some heavy hacking, but your colleagues in the core team may help you?
                              If you do succeed, I'd love to know how πŸ˜„
                                @jiminy-billy-bob said:
                                Tomasz did it!
                                Yea, I know there are way to get access directly to the SU viewport. But I got another idea that might be less hacking. I'm hesitant to dig too deep into host applications like that as it could easily break. I was thinking more in terms of overlays. Separate transparent window in a separate process (that way if it breaks it shouldn't take down SU with it.)
                                But yea - BaseCamp hackathon? πŸ˜„
                                • JQLJ Offline
                                  JQL
                                  Damn I love Thea For Sketchup!
                                  www.casca.pt
                                  • O Offline
                                    optimaforever
                                    Is there a tut for terrain and especially road modeling in quads?
                                    I'm struggling to find examples for correct crossings topologies...
                                      cuttingedge
                                      Nope i just provided a platform for good contrast against the white.
                                      Thinking about it.. It isnt easy to model perfectly. took me about an hour and half..while it looks okay here.
                                      I had to redo it again to perfectly model it. My target it to actually make my modeling skill usable in the actual production of professional 3d prints.
                                      • Rich O BrienR Online
                                        SketchUp needs Matcaps soooo bad 😞
                                          I might just have to replicate that. I quite liked that colour scheme.
                                          • O Offline
                                            optimaforever
                                            I arrived to this with the roads in quads.
                                            But I have no idea for the topology of the terrain between them...
                                            What's the basic strategy? try to create a complete grid with similar quad size (closest to square as possible)?
                                            And is quad modeling only for volumes? In the present case I'm only working on a plane...
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 82
                                            • 83
                                            • 15 / 83
