    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.1m Views 79 Watching
    • ntxdaveN
      ntxdave
      @hornoxx said:
      Hi Dave - this could be, what you are looking for (I have no idea what it is πŸ˜† )
      On page 9 of this topic, Thomthom is showing a view examples how to cut out (Quad-)holes.
      Will that is what I had tried to do but obviously did something wrong. Will look at it some more. Thanks for sharing the skp file.
      @Hieru Thanks for sharing yours and the feedback as well.
      Some day, I am going to learn ❗ ❗
      Press F1...thank me later
        I think you can get away with even fewer polygons in your control-mesh. I had a quick playaround where I stripped away some of the loops:
        001-test.skp
        • ntxdaveN
          ntxdave
          Again, thanks for sharing. And I will look at this closer again. I had tried this but not sure what the heck I did wrong. All part of the learning process.
          I am glad that people are so willing to share and will put up with all of these questions from someone like me. I REALLY appreciate it.
          • HornOxxH
            HornOxx
            πŸ˜› thats why this topic is named "SubD examples and models"
            @hieru said:
            ...Here's a moderately detailed example...
            ...which is really great! - thanks for sharing!
            never trust a skinny cook
            • ntxdaveN
              ntxdave
              More silly questions:
              • HornOxxH
                HornOxx
                Hi Dave
                most of this particular model is done in Basic SketchUp as shown in the added video.
                So the lines around the hole (your question 2) were simply moved or drawn with
                native SU-tools in this case - there was no magic stick πŸ˜›
                The mesh change 1B (your question 1) I just did to hit the edges of the octagon-hole
                perfectly in order to just get quads.
                For lifting the 4 lines I used Vertex Tools. If you hold CTRL, the lifting of the
                Vertex Tool gizmo will create a new "tube" section. If you donΒ΄t have Vertex Tools,
                you can do all this with basic SU-tools as well but it is important to avoid any internal
                faces. Also the scaling can be done with basic SU-tools as well. But using Vertex Tools
                for scaling, rotating, moving ... is much better in order do get a "clean" Quad mesh...
                Also Quadface Tools are important if you want or need to "divide" your model in certain
                sections or if you want to add, select or edit loops without doing all that manually...
                I am far from understanding all that and am just starting to discover these functions by
                testing and playing πŸ˜‰
                • C
                  cuttingedge
                  QFT, Vertex Tools & SubD, proved to be the most enjoyable tools for modeling. Here's a WIP of my earpods..
                  apple earpods WIP
                    you could wind up with some huge files. Is this normal?
                    Yep! Basically SKetshup is a "box modeling" program, not a "Subdivision" program!
                    It's was not provided for that!
                    We are lucky that works for some little objects, but that will be very difficult for biggest project! πŸ˜‰
                    Manage millions of polygons is not its speciality! πŸ’š
                    • JQLJ
                      JQL
                      If they're working with render engines and if you have Thea Interactive Rendering capabilities, you'll be able to fire up a render with subdivision without Sketchup Open GL viewport even being aware of it!
                      Then it will be fast even for millions of polys, if you have enough power in your CPU+GPU combo, it will actually be a zip!
                      www.casca.pt
                      Visit us on facebook!
                        Yes thanks to Proxies! πŸ˜‰
                        • ntxdaveN
                          ntxdave
                          @HornOxx Thanks a ton. I see what I did wrong. I thought I had used the Ctrl when using the Gizmo tool but I must not have.
                          I tried selecting the grids at both end and scaling at the same time but for some reason it would not do it. I was able to do it by scaling one end at a time.
                          I wish the ConnetEdges tool that is part of the QFT tool would give you a little better control over the division (like being able to split the selected surface evenly) but I also know that you can use the move tool to position the rings/loops so there is more than one way to get the job done. I also like the way you went into wire frame mode and used guide lines to drag the ring/loops. That was pretty neat also.
                          Ultimately, I would like to be able to put together a beginners guide to quad face modeling.
                          Here are the sections I would like to see:
                          • What is Quad Modeling
                          • Why is it necessary/Why would you want to use it
                          • Step by step example
                          • This would be a step by step guide with pictures that showed each step with an explanation of why you are performing it* I think a written guide might work better than a video but maybe some animated gifs because the newbie needs to understand both how and why you are performing the step* The sample model needs to be comprehensive enough to see all (or at least most) of the features yet not so complicated that the beginner cannot understand what is being done
                          • Glossary
                          • Poly* Quad* Tri* N-Gon* Other Terms
                          Just some current thoughts - a long way off though.
                          • ntxdaveN
                            ntxdave
                            Another dumb question: What are Proxies?
                            • BoxB
                              Here's a quicky to show how to slice things up with QFT.
                              http://i155.photobucket.com/albums/s296/storeben/SU/Qft.gif
                              • HornOxxH
                                HornOxx
                                @ntxdave said:
                                What are Proxies?
                                The Proxy in this context is the simple raw geometry.
                                Also for example Artisan uses this term - also there is a simple raw geometry (the proxy)
                                which then gets subdivided in a much complexer and biger geometry. The Proxy allways is the
                                "placeholder"(? donΒ΄t know if that word exists in English?) for something modified.
                                A lot of Render tools replace simple Proxys with most complex replace-geometrys or components.
                                So you can draw (or use) for example a simple line-box in SU, wich then gets replaces within a renderer by a most complex 3D-tree...
                                  Is the colour there from post processing? Or is that actually a SketchUp style?
                                    Indeed. At the moment I'm moving towards using OpenSubdiv as subdivision engine. It actually have support for fast display of the subdivided mesh for OpenGL and DirectX - however the SU API doesn't provide access to the GL pipeline. Otherwise you'd have it override the normal drawing of the mesh in high-poly while SU itself would only know about the control mesh. dreams
                                    But I got some ideas here ... need to make some experiments. πŸ€“
                                      Have you looked at the links on the SUbD site?
                                      http://evilsoftwareempire.com/subd/quads
                                      Currently there are four links to external sites that describe the general concept of tris, quads and ngons. Is there information there you feel is missing?
                                      • jiminy-billy-bobJ
                                        jiminy-billy-bob
                                        Tomasz did it! It needs some heavy hacking, but your colleagues in the core team may help you?
                                        If you do succeed, I'd love to know how πŸ˜„
                                          @jiminy-billy-bob said:
                                          Tomasz did it!
                                          Yea, I know there are way to get access directly to the SU viewport. But I got another idea that might be less hacking. I'm hesitant to dig too deep into host applications like that as it could easily break. I was thinking more in terms of overlays. Separate transparent window in a separate process (that way if it breaks it shouldn't take down SU with it.)
                                          But yea - BaseCamp hackathon? πŸ˜„
                                          • JQLJ
                                            JQL
                                            Damn I love Thea For Sketchup!
                                            www.casca.pt
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 83
                                            • 84
                                            • 15 / 84
