    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • alvisA
      alvis
      Can you explain to me, why the first attempt fails. Why I should select one edge of triangulated face, that the second attemt must be fine.
      https://youtu.be/XiUtriWV_lo
        The Convert triangulated Mesh to Quads function doesn't always succeed. It's hard, impossible, to reliable determine exactly how the mesh should be converted as it would require AI understanding of the mesh's topology. In your example it's easy for use humans to see what should be a quad, but not for a script. The script doesn't even take into account soft/smooth/hidden properties - it just sees a set of triangles.
        In the case of your mesh there it looks like you have hard edges and then some soft+smooth edges between triangles pairs. Then you want to use the Convert SandboxTools Quads to QuadFace Tools quads instead. (left to the monkey icon). If those edges where hidden you you'd want to use the Blender Quads to QFT Quads function (the monkey icon).
        • dereiD
          derei
          Humm, i was in similar situations... means that either more documentation is needed to make it easier to understand when to use each function, or maybe if you would think appropriate, to make the quad-detection script to be more "intelligent", so it can take into consideration multiple parameters at the same time. For example not all Fredo Tools are good in creating or preserving quads... but they do smoothing. So, would be good to rely better on conversion.
          Thank you! Keep up the good work ! πŸŽ‰
          DESIGNER AND ARTIST DEREI.UK
            Yes, better documentation is indeed in need - as well as improving the tools. But docs are on the top of my list when I get home from my travels next week.
            I plan to set up a new site for QFT - move away from the BitBucket wiki.
            Better text and visuals describing the various features of QFT. GIFs to illustrate common topology pattern.
            And extend SUbD's site to include more examples of how various topology patterns subdivide.
            • C
              cuttingedge
              I was thrilled by the panton chair example shared by Ithil3d on youtube. I thought I'll build one trying slightly different method. A good few minutes and here's what i got.
              model
              test render
              • HornOxxH
                HornOxx
                @cuttingedge said:
                ... I thought I'll build one trying slightly different method. A good few minutes and here's what i got...
                This is a very good SubD example!
                how often and unsuccessfully I tried exactly this chair πŸ˜›
                never trust a skinny cook
                  Yes the difficulty with Subdivision modeling against the Nurbs modeling where you have yet all the curves of the model, is to imagine the "rustic" cubic form before it's transformation! πŸ˜„
                  https://s-media-cache-ak0.pinimg.com/236x/1a/d5/a5/1ad5a5b1e29b783619d44f7751f6c285.jpg
                    miikka1978
                    Is there any plugin working like Blender's Add Loop cut, see link below? I think that this would be really useful when using SubD.
                    https://www.blender.org/manual/modeling/meshes/editing/subdividing/loop_subdivide.html
                    https://www.youtube.com/watch?v=_f4XKe8lZEU
                    • ely862meE
                      ely862me
                      If you look back a little you will see that we talk about that too, it's called Quad face tools, you can find it in the plugins library.
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                      • HornOxxH
                        HornOxx
                        ...completed the wing to a plane - certainly not a beauty πŸ˜•
                        plane4_proxy.skp
                        • JQLJ
                          JQL
                          Not bad either... but it was a very promising wing
                          www.casca.pt
                          Visit us on facebook!
                          • HornOxxH
                            HornOxx
                            @jql said:
                            ... but it was a very promising wing...
                            thanks
                            πŸ˜† ok - give this wing an other try
                              Yet a charm certain! πŸ˜‰
                              • StinkieS
                                Stinkie
                                @thomthom said:
                                There are talks going on with various render engines to allow for them to render high-poly variants from the low-polys.
                                Nice! πŸ‘
                                • O
                                  optimaforever
                                  In the same order of idea, can you thomthom develop a quadchamfer4SU?
                                  Ideally it would be a mix between the editability of SubD and the easiness of RoundCorner...
                                  Roundcorner is good but it doesn't allow for editing. I have to keep a non-chamfered version in a temp layer if I need to edit it again. And SubD need manually offsetted lines to control the distance of chamfering. On complex models, it can quicky become a time-consuming burden, just to create chamfered edges, not to mention the file size and the memory footprint.
                                  This TTQuadchamfer would be a quick 3D chamfer/fillet tool that automatically creates the needed lines offsets according to pre-entered parameters, which in return could allow easy re-editing, should the need arise. And afterward, one could tweak the fillet values edge by edge for more flexibility.
                                  What do you think?
                                    Got some visuals to illustrate expected result?
                                    • O
                                      optimaforever
                                      Have you seen http://www.mariussilaghi.com/products/quad-chamfer ?
                                      • gillesG
                                        gilles
                                        Streamliner, based on Norman E. Timbs 48 buick.
                                        • JQLJ
                                          JQL
                                          What do you think?
                                          Actually I'm simply not using SubD, because it would be the most fun plugin I'd have, but it's not really useful for what I need right now. I would have yet another toy to have fun with and deviate my attention for what I do for a living... I must resist...
                                          If you'd do it, it would be extremelly useful if you'd integrate it with SubD methodology and chamfer it only when subdividing, keeping UV's, allowing for creases worflow to be integrated too and, probably integrate it in the rendering workflow too.
                                          I didn't know it yet but if SubD would be able to produce that, it would turn into the most useful toy an architect that deals with archviz needs apart from the renderers themselves.
                                          Thanks for that feature request Optimaforever, I really hope Thomthom pulls that one off!
                                          www.casca.pt
                                            @: Gilles where is the model ? πŸ˜‰
                                            Inspiration Vrooum, vrooum! πŸ’š
                                            car_v6.zip
                                            • 11
                                            • 83
                                            • 84
                                            • 9 / 84
