    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.3m Views 79 Watching
    • cottyC Offline
      cotty
      @rich o brien said:
      @cuttingedge said:
      Cotty how do you display the subquads without the triangulation showing?
      QuadFace Tools > Unsmooth Quads
      Yes, screenshot here: http://sketchucation.com/forums/viewtopic.php?f=397%26amp;t=63826%26amp;start=30#p585747
      @thomthom said:
      But what about the thicker lines in that render - representing the original edges? How is that done? Multiple passes?
      Since two of your plugins are not enough πŸ˜‰ :
      • SubD
      • Edit group
      • Select all
      • SeletionToys: Select only -> Edges
      • Group selected edges
      • Gropued edges without faces are treated as profiles
      • Increase profile width in the style settings
      • Exit SubD group
      • Unsmooth quads
      my SketchUp gallery
      • HornOxxH Offline
        HornOxx
        not a plane but at least a wing
        plane wing.skp
        never trust a skinny cook
        • JQLJ Offline
          JQL
          That wing rocks HornOxx!
          www.casca.pt
          Visit us on facebook!
          • alvisA Offline
            alvis
            Can you explain to me, why the first attempt fails. Why I should select one edge of triangulated face, that the second attemt must be fine.
            https://youtu.be/XiUtriWV_lo
              The Convert triangulated Mesh to Quads function doesn't always succeed. It's hard, impossible, to reliable determine exactly how the mesh should be converted as it would require AI understanding of the mesh's topology. In your example it's easy for use humans to see what should be a quad, but not for a script. The script doesn't even take into account soft/smooth/hidden properties - it just sees a set of triangles.
              In the case of your mesh there it looks like you have hard edges and then some soft+smooth edges between triangles pairs. Then you want to use the Convert SandboxTools Quads to QuadFace Tools quads instead. (left to the monkey icon). If those edges where hidden you you'd want to use the Blender Quads to QFT Quads function (the monkey icon).
              • dereiD Offline
                derei
                Humm, i was in similar situations... means that either more documentation is needed to make it easier to understand when to use each function, or maybe if you would think appropriate, to make the quad-detection script to be more "intelligent", so it can take into consideration multiple parameters at the same time. For example not all Fredo Tools are good in creating or preserving quads... but they do smoothing. So, would be good to rely better on conversion.
                Thank you! Keep up the good work ! πŸŽ‰
                DESIGNER AND ARTIST DEREI.UK
                  Yes, better documentation is indeed in need - as well as improving the tools. But docs are on the top of my list when I get home from my travels next week.
                  I plan to set up a new site for QFT - move away from the BitBucket wiki.
                  Better text and visuals describing the various features of QFT. GIFs to illustrate common topology pattern.
                  And extend SUbD's site to include more examples of how various topology patterns subdivide.
                    cuttingedge
                    I was thrilled by the panton chair example shared by Ithil3d on youtube. I thought I'll build one trying slightly different method. A good few minutes and here's what i got.
                    model
                    test render
                    • HornOxxH Offline
                      HornOxx
                      @cuttingedge said:
                      ... I thought I'll build one trying slightly different method. A good few minutes and here's what i got...
                      This is a very good SubD example!
                      how often and unsuccessfully I tried exactly this chair πŸ˜›
                        Yes the difficulty with Subdivision modeling against the Nurbs modeling where you have yet all the curves of the model, is to imagine the "rustic" cubic form before it's transformation! πŸ˜„
                        https://s-media-cache-ak0.pinimg.com/236x/1a/d5/a5/1ad5a5b1e29b783619d44f7751f6c285.jpg
                          miikka1978
                          Is there any plugin working like Blender's Add Loop cut, see link below? I think that this would be really useful when using SubD.
                          https://www.blender.org/manual/modeling/meshes/editing/subdividing/loop_subdivide.html
                          https://www.youtube.com/watch?v=_f4XKe8lZEU
                          • ely862meE Offline
                            ely862me
                            If you look back a little you will see that we talk about that too, it's called Quad face tools, you can find it in the plugins library.
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                            • HornOxxH Offline
                              HornOxx
                              ...completed the wing to a plane - certainly not a beauty πŸ˜•
                              plane4_proxy.skp
                              • JQLJ Offline
                                JQL
                                Not bad either... but it was a very promising wing
                                www.casca.pt
                                • HornOxxH Offline
                                  HornOxx
                                  @jql said:
                                  ... but it was a very promising wing...
                                  thanks
                                  πŸ˜† ok - give this wing an other try
                                    Yet a charm certain! πŸ˜‰
                                    • StinkieS Offline
                                      Stinkie
                                      @thomthom said:
                                      There are talks going on with various render engines to allow for them to render high-poly variants from the low-polys.
                                      Nice! πŸ‘
                                      • O Offline
                                        optimaforever
                                        In the same order of idea, can you thomthom develop a quadchamfer4SU?
                                        Ideally it would be a mix between the editability of SubD and the easiness of RoundCorner...
                                        Roundcorner is good but it doesn't allow for editing. I have to keep a non-chamfered version in a temp layer if I need to edit it again. And SubD need manually offsetted lines to control the distance of chamfering. On complex models, it can quicky become a time-consuming burden, just to create chamfered edges, not to mention the file size and the memory footprint.
                                        This TTQuadchamfer would be a quick 3D chamfer/fillet tool that automatically creates the needed lines offsets according to pre-entered parameters, which in return could allow easy re-editing, should the need arise. And afterward, one could tweak the fillet values edge by edge for more flexibility.
                                        What do you think?
                                          Got some visuals to illustrate expected result?
                                          • O Offline
                                            optimaforever
                                            Have you seen http://www.mariussilaghi.com/products/quad-chamfer ?
                                            • 11
                                            • 83
                                            • 84
                                            • 9 / 84
