    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 360.0k Views 45 Watching
    • pbacotP
      Not simple, Simply Mind Boggling!
      • cottyC
        cotty
        Nice find, thanks for sharing the link!
        (I've added an image as a preview, hope you don't mind)
        my SketchUp gallery
        • HieruH
          Hieru
          Just found this useful reference for subdivision proxies. These aren't Sketchup examples, but a lot of the methods should work well with Artisan and help people understand how to approach fairly common shapes.
          Fastly error: unknown domain 199.232.192.193
          (imgur.com)
          www.davidhier.co.uk
          • HieruH
            Hieru
            No problem Cotty.
            When I get time, I think I'll try and reproduce some of the examples with SU. It would also be great if we could get people to post requests/advice for SU proxies.
            www.davidhier.co.uk
            • olisheaO
              olishea
              @charly2008 said:
              I Need your Help. How do I get this quad faces with artisan. I only get this result (see photo below).
              You have an internal face where the hoops meet. Also you need to use "split donut" to split the ngons into quads.
              oli
                Shame you weren't around in December when he needed to know πŸ˜•
                • olisheaO
                  olishea
                  And everyone else! πŸ˜„ His query was answered, but not fully. πŸ˜›
                  oli
                    Good lad.
                    Thought I caught u mapping again.
                    • olisheaO
                      olishea
                      Some examples of how loops can affect hard edges in this recess.
                      Left to right:
                      Hard edge at base.
                      Hard edge at wall.
                      Double hard edge.
                      No hard edge.
                      oli
                      • HieruH
                        Hieru
                        Some subtle but important differences there Oli πŸ‘
                        www.davidhier.co.uk
                          Cerebral pre modeling! πŸ˜‰
                          • olisheaO
                            olishea
                            @hieru said:
                            It was certainly a worthwhile exercise as I learnt that n-gons in your proxy can be used to create better topology (see the areas highlighted in red).
                            Don't you mean lack of n-gons? Those highlighted red are quads.
                            oli
                            • HieruH
                              Hieru
                              Yes you're right - doh! The proxy modelling and end result make much more sense now.
                              Normally I'd triangulate odd shaped quads in the same way I'd deal with n-gons. Now I know better.
                              www.davidhier.co.uk
                              • olisheaO
                                olishea
                                haha yeah, i was confused for a minute! I couldn't understand how n-gons can make anything better.
                                It doesn't matter how "odd" the quad looks. If it's a quad it's a quad and will perform well. Sometimes you can't avoid triangles. It's too many poles that frustrate me. πŸ˜†
                                oli
                                • HieruH
                                  Hieru
                                  Lesson learned πŸ˜‰
                                  I'll certainly never model proxy circular planes any other way from now on. If this shape is typical, there should be a lot to be learnt from the rest of the examples.
                                  www.davidhier.co.uk
                                  • HieruH
                                    Hieru
                                    Had some time to tackle one of the shapes from the topology reference guide. I've changed some of the modelling to make it easier/faster to achieve in Sketchup.
                                    Edit: The red areas are quads rather than n-gons. They are however still very important when it comes to creating better topology.
                                    BoltHeadPrimitive.skp
                                    www.davidhier.co.uk
                                    • HieruH
                                      Hieru
                                      Another example. This time a cylinder with holes.
                                      CylinderWithHoles.skp
                                      www.davidhier.co.uk
                                      • olisheaO
                                        olishea
                                        Very nice work.
                                        Just a quick note: Try using circles with 6 edges instead of 8. When you intersect a 6 sided circle in half with a line you get two halves of quads, if that makes sense. It doesn't really matter for this model, it's just something I should point out. You would end up with less poly too. The starting circle really determines how successful the subdivision is going to be; if you've tried using a strange amount of edges it becomes difficult to keep quads and the model becomes frustrating.
                                        oli
                                        • olisheaO
                                          olishea
                                          Can you do something about the marked areas? Looks a bit strange to me having those stray edges, even though it does form a quad. The large triangles could possibly be avoided too, don't have time to look though.
                                          oli
                                          • HieruH
                                            Hieru
                                            I was simply copying one of the provided examples, but I'll see if there is a better way of doing it.
                                            www.davidhier.co.uk
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
