    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 327.9k Views 45 Watching
      Cerebral pre modeling! πŸ˜‰
      • olisheaO Offline
        olishea
        @hieru said:
        It was certainly a worthwhile exercise as I learnt that n-gons in your proxy can be used to create better topology (see the areas highlighted in red).
        Don't you mean lack of n-gons? Those highlighted red are quads.
        oli
        • HieruH Offline
          Hieru
          Yes you're right - doh! The proxy modelling and end result make much more sense now.
          Normally I'd triangulate odd shaped quads in the same way I'd deal with n-gons. Now I know better.
          www.davidhier.co.uk
          • olisheaO Offline
            olishea
            haha yeah, i was confused for a minute! I couldn't understand how n-gons can make anything better.
            It doesn't matter how "odd" the quad looks. If it's a quad it's a quad and will perform well. Sometimes you can't avoid triangles. It's too many poles that frustrate me. πŸ˜†
            oli
            • HieruH Offline
              Hieru
              Lesson learned πŸ˜‰
              I'll certainly never model proxy circular planes any other way from now on. If this shape is typical, there should be a lot to be learnt from the rest of the examples.
              www.davidhier.co.uk
              • HieruH Offline
                Hieru
                Had some time to tackle one of the shapes from the topology reference guide. I've changed some of the modelling to make it easier/faster to achieve in Sketchup.
                Edit: The red areas are quads rather than n-gons. They are however still very important when it comes to creating better topology.
                BoltHeadPrimitive.skp
                www.davidhier.co.uk
                • HieruH Offline
                  Hieru
                  Another example. This time a cylinder with holes.
                  CylinderWithHoles.skp
                  www.davidhier.co.uk
                  • olisheaO Offline
                    olishea
                    Very nice work.
                    Just a quick note: Try using circles with 6 edges instead of 8. When you intersect a 6 sided circle in half with a line you get two halves of quads, if that makes sense. It doesn't really matter for this model, it's just something I should point out. You would end up with less poly too. The starting circle really determines how successful the subdivision is going to be; if you've tried using a strange amount of edges it becomes difficult to keep quads and the model becomes frustrating.
                    oli
                    • olisheaO Offline
                      olishea
                      Can you do something about the marked areas? Looks a bit strange to me having those stray edges, even though it does form a quad. The large triangles could possibly be avoided too, don't have time to look though.
                      oli
                      • HieruH Offline
                        Hieru
                        I was simply copying one of the provided examples, but I'll see if there is a better way of doing it.
                        www.davidhier.co.uk
                        • HieruH Offline
                          Hieru
                          Insets on a curved surface.
                          CurvedInsets.skp
                          www.davidhier.co.uk
                          • HieruH Offline
                            Hieru
                            Good point....that's a great tip πŸ‘
                            www.davidhier.co.uk
                            • HieruH Offline
                              Hieru
                              Is this any better? It generates much neater topology but the poly count goes up.
                              CylinderWithHoles-V2.skp
                              www.davidhier.co.uk
                              • HieruH Offline
                                Hieru
                                Or how about this? Here I've rebuilt the form using 6-sided openings...much more economical!
                                CylinderWithHoles-V3.skp
                                www.davidhier.co.uk
                                • HieruH Offline
                                  Hieru
                                  Two versions of a simple cylinder with a bevelled edge. The second version (bottom) is for situations where you can't get away with a 6-sided shape.
                                  Cylinder.skp
                                  www.davidhier.co.uk
                                    Too many poles. 3 and 5 sided converging quads.
                                    • HieruH Offline
                                      Hieru
                                      Last one for today: joining two pipes of the same diameter.
                                      This one is significantly different to the reference as I couldn't figure out how to join the pipes without distorting the bottom pipe and making it non-cylindrical (see circled area).
                                      JoiningPipe.skp
                                      www.davidhier.co.uk
                                      • HieruH Offline
                                        Hieru
                                        Presumably that makes it difficult for UV mapping?
                                        Edit: I was obviously over-thinking things again...
                                        www.davidhier.co.uk
                                        • olisheaO Offline
                                          olishea
                                          Yeah you nailed it with CylinderWithHoles-V3. Sometimes you think there is no other possible way of doing it....then you come back to the model and think Ohhhhhh! Great examples and thanks for posting here! πŸ‘
                                          Your pipe is better than the example. The area you circled is an N-gon. πŸ˜‰ I guess the reason they did that was to reduce the "pinch" of the pole that you have in your model. They should have used another loop though. I love subdivision modelling; so many different outcomes from very subtle changes. πŸ˜„
                                          Would be cool if we had a "circularize" plugin for sketchup, you could click on specific rectangles and convert them into squares. Or maybe create an offset square face within the rectangle. Would be nice to be able to specify how many edges so you could even offset a triangle, square, pentagon etc etc....
                                          This would help creating circular holes in peculiar shapes. I use this tool in Wings 3D quite often, maybe I'll ask TIG about it....maybe call it Offset Circle where you can choose the amount of edges the offset circle has.
                                          oli
                                          • HieruH Offline
                                            Hieru
                                            Thanks πŸ‘
                                            +1 Definitely sounds like something that would come in handy.
                                            www.davidhier.co.uk
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
