    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 323.1k Views 45 Watching
      @olishea said:
      You have an internal face where the hoops meet. Also you need to use "split donut" to split the ngons into quads.
      Shame you weren't around in December when he needed to know πŸ˜•
      • olisheaO Offline
        olishea
        And everyone else! πŸ˜„ His query was answered, but not fully. πŸ˜›
        oli
          Good lad.
          Thought I caught u mapping again.
          • olisheaO Offline
            olishea
            Some examples of how loops can affect hard edges in this recess.
            Left to right:
            Hard edge at base.
            Hard edge at wall.
            Double hard edge.
            No hard edge.
            oli
            • HieruH Offline
              Hieru
              Some subtle but important differences there Oli πŸ‘
              www.davidhier.co.uk
                Cerebral pre modeling! πŸ˜‰
                • olisheaO Offline
                  olishea
                  @hieru said:
                  It was certainly a worthwhile exercise as I learnt that n-gons in your proxy can be used to create better topology (see the areas highlighted in red).
                  Don't you mean lack of n-gons? Those highlighted red are quads.
                  oli
                  • HieruH Offline
                    Hieru
                    Yes you're right - doh! The proxy modelling and end result make much more sense now.
                    Normally I'd triangulate odd shaped quads in the same way I'd deal with n-gons. Now I know better.
                    www.davidhier.co.uk
                    • olisheaO Offline
                      olishea
                      haha yeah, i was confused for a minute! I couldn't understand how n-gons can make anything better.
                      It doesn't matter how "odd" the quad looks. If it's a quad it's a quad and will perform well. Sometimes you can't avoid triangles. It's too many poles that frustrate me. πŸ˜†
                      oli
                      • HieruH Offline
                        Hieru
                        Lesson learned πŸ˜‰
                        I'll certainly never model proxy circular planes any other way from now on. If this shape is typical, there should be a lot to be learnt from the rest of the examples.
                        www.davidhier.co.uk
                        • HieruH Offline
                          Hieru
                          Had some time to tackle one of the shapes from the topology reference guide. I've changed some of the modelling to make it easier/faster to achieve in Sketchup.
                          Edit: The red areas are quads rather than n-gons. They are however still very important when it comes to creating better topology.
                          BoltHeadPrimitive.skp
                          www.davidhier.co.uk
                          • HieruH Offline
                            Hieru
                            Another example. This time a cylinder with holes.
                            CylinderWithHoles.skp
                            www.davidhier.co.uk
                            • olisheaO Offline
                              olishea
                              Very nice work.
                              Just a quick note: Try using circles with 6 edges instead of 8. When you intersect a 6 sided circle in half with a line you get two halves of quads, if that makes sense. It doesn't really matter for this model, it's just something I should point out. You would end up with less poly too. The starting circle really determines how successful the subdivision is going to be; if you've tried using a strange amount of edges it becomes difficult to keep quads and the model becomes frustrating.
                              oli
                              • olisheaO Offline
                                olishea
                                Can you do something about the marked areas? Looks a bit strange to me having those stray edges, even though it does form a quad. The large triangles could possibly be avoided too, don't have time to look though.
                                oli
                                • HieruH Offline
                                  Hieru
                                  I was simply copying one of the provided examples, but I'll see if there is a better way of doing it.
                                  www.davidhier.co.uk
                                  • HieruH Offline
                                    Hieru
                                    Insets on a curved surface.
                                    CurvedInsets.skp
                                    www.davidhier.co.uk
                                    • HieruH Offline
                                      Hieru
                                      Good point....that's a great tip πŸ‘
                                      www.davidhier.co.uk
                                      • HieruH Offline
                                        Hieru
                                        Is this any better? It generates much neater topology but the poly count goes up.
                                        CylinderWithHoles-V2.skp
                                        www.davidhier.co.uk
                                        • HieruH Offline
                                          Hieru
                                          Or how about this? Here I've rebuilt the form using 6-sided openings...much more economical!
                                          CylinderWithHoles-V3.skp
                                          www.davidhier.co.uk
                                          • HieruH Offline
                                            Hieru
                                            Two versions of a simple cylinder with a bevelled edge. The second version (bottom) is for situations where you can't get away with a 6-sided shape.
                                            Cylinder.skp
                                            www.davidhier.co.uk
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
