    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 328.0k Views 45 Watching
      Good lad.
      Thought I caught u mapping again.
      • olisheaO Offline
        olishea
        Some examples of how loops can affect hard edges in this recess.
        Left to right:
        Hard edge at base.
        Hard edge at wall.
        Double hard edge.
        No hard edge.
        oli
        • HieruH Offline
          Hieru
          Some subtle but important differences there Oli πŸ‘
          www.davidhier.co.uk
            Cerebral pre modeling! πŸ˜‰
            • olisheaO Offline
              olishea
              @hieru said:
              It was certainly a worthwhile exercise as I learnt that n-gons in your proxy can be used to create better topology (see the areas highlighted in red).
              Don't you mean lack of n-gons? Those highlighted red are quads.
              oli
              • HieruH Offline
                Hieru
                Yes you're right - doh! The proxy modelling and end result make much more sense now.
                Normally I'd triangulate odd shaped quads in the same way I'd deal with n-gons. Now I know better.
                www.davidhier.co.uk
                • olisheaO Offline
                  olishea
                  haha yeah, i was confused for a minute! I couldn't understand how n-gons can make anything better.
                  It doesn't matter how "odd" the quad looks. If it's a quad it's a quad and will perform well. Sometimes you can't avoid triangles. It's too many poles that frustrate me. πŸ˜†
                  oli
                  • HieruH Offline
                    Hieru
                    Lesson learned πŸ˜‰
                    I'll certainly never model proxy circular planes any other way from now on. If this shape is typical, there should be a lot to be learnt from the rest of the examples.
                    www.davidhier.co.uk
                    • HieruH Offline
                      Hieru
                      Had some time to tackle one of the shapes from the topology reference guide. I've changed some of the modelling to make it easier/faster to achieve in Sketchup.
                      Edit: The red areas are quads rather than n-gons. They are however still very important when it comes to creating better topology.
                      BoltHeadPrimitive.skp
                      www.davidhier.co.uk
                      • HieruH Offline
                        Hieru
                        Another example. This time a cylinder with holes.
                        CylinderWithHoles.skp
                        www.davidhier.co.uk
                        • olisheaO Offline
                          olishea
                          Very nice work.
                          Just a quick note: Try using circles with 6 edges instead of 8. When you intersect a 6 sided circle in half with a line you get two halves of quads, if that makes sense. It doesn't really matter for this model, it's just something I should point out. You would end up with less poly too. The starting circle really determines how successful the subdivision is going to be; if you've tried using a strange amount of edges it becomes difficult to keep quads and the model becomes frustrating.
                          oli
                          • olisheaO Offline
                            olishea
                            Can you do something about the marked areas? Looks a bit strange to me having those stray edges, even though it does form a quad. The large triangles could possibly be avoided too, don't have time to look though.
                            oli
                            • HieruH Offline
                              Hieru
                              I was simply copying one of the provided examples, but I'll see if there is a better way of doing it.
                              www.davidhier.co.uk
                              • HieruH Offline
                                Hieru
                                Insets on a curved surface.
                                CurvedInsets.skp
                                www.davidhier.co.uk
                                • HieruH Offline
                                  Hieru
                                  Good point....that's a great tip πŸ‘
                                  www.davidhier.co.uk
                                  • HieruH Offline
                                    Hieru
                                    Is this any better? It generates much neater topology but the poly count goes up.
                                    CylinderWithHoles-V2.skp
                                    www.davidhier.co.uk
                                    • HieruH Offline
                                      Hieru
                                      Or how about this? Here I've rebuilt the form using 6-sided openings...much more economical!
                                      CylinderWithHoles-V3.skp
                                      www.davidhier.co.uk
                                      • HieruH Offline
                                        Hieru
                                        Two versions of a simple cylinder with a bevelled edge. The second version (bottom) is for situations where you can't get away with a 6-sided shape.
                                        Cylinder.skp
                                        www.davidhier.co.uk
                                          Too many poles. 3 and 5 sided converging quads.
                                          • HieruH Offline
                                            Hieru
                                            Last one for today: joining two pipes of the same diameter.
                                            This one is significantly different to the reference as I couldn't figure out how to join the pipes without distorting the bottom pipe and making it non-cylindrical (see circled area).
                                            JoiningPipe.skp
                                            www.davidhier.co.uk
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
