    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
    • arail1A
      arail1
      @panixia said:
      just discovered a DOH feature of the selection tool..
      if you drag a selection rectangle from left to right it selects only the items completely wrapped in the rectangle, but if you drag the rectangle from right toward left,then also the items wich are only touched (but not fully wrapped) by the rectangle are selected.. never noticed it before.. 😲
      This is important to know also because it's one of the few things that tends to be consistent across most 3D software applications.
        MikeFJaguar
        Ctrl (in Windows) while orbiting lets me turn my model every which way! Fairly useless as an architectural user but a boon for modellers who make widgets. Doh!
        • GaieusG
          That's a "designed feature": Suspending the gravity setting
          • mitcorbM
            mitcorb
            Sort of bootleg Camera Roll. I have used it to get a particular position for precise selection in a busy model. Of course, you could just do a bunch of layering and hiding to avoid this need altogether.
            • olisheaO
              olishea
              I use it for portrait-orientated renders...very useful.
              oli
              • Wo3DanW
                Wo3Dan
                @mikefjaguar said:
                Ctrl (in Windows) while orbiting lets me turn my model every which way! Fairly useless as an architectural user but ......... Doh!
                Rolling the camera (by holding down [Ctrl] when orbiting), to position your model in such a way on screen sometimes helps in order to have the selection window enclose what you want it to select. With gravity ON you might not be able to make that special selection.
                  ...and when you Press the SpaceBar that stop it vigorously! 💚
                  http://www.freebiker.net/FichesPratiques/Freinage_problemes/problemes_freinage.jpg
                  • porch_unpluggedP
                    porch_unplugged
                    ugh, i think i just made myself travel sick trying that out.
                    • porch_unpluggedP
                      porch_unplugged
                      if you are trying to draw something small and the clipping plane is getting in the way, change to parallel projection view.
                        I often find I get clipping issues more quickly with parallel view...
                        • brodieB
                          brodie
                          I'm on board with the parallel projection. I find that when you initially change to PP you'll get some bad clipping, but if you select your geometry and then zoom extents the clipping goes away and you can zoom in as much as you want.
                          -Brodie
                          • V
                            valerostudio
                            Left, Right, Up arrows lock the Red Green Blue Axis when using move! How did it take me 7 years to figure this one out!
                            • gillesG
                              gilles
                              Seven years!
                              You should read the manual, just in case. 😄
                              Error 404 (Not Found)!!1
                              (support.google.com)
                              • V
                                valerostudio
                                There's a manual? 😉
                                • Wo3DanW
                                  Wo3Dan
                                  @gilles said:
                                  Seven years!
                                  Useful reading but here it lacks the information about how to use to rotate a group or component accurately according to the current drawing axes system with angle input.
                                  Also I couldn't find anything about moving vertices. And even more, while doing so, how to lock moving a vertex to its own edge's direction. (=hover over the edge first, press [Shift], only then move the vertex)
                                  • cottyC
                                    cotty
                                    @wo3dan said:
                                    ...lock moving a vertex to its own edge's direction. (=hover over the edge first, press [Shift], only then move the vertex)
                                    New one for me, thank you!
                                    my SketchUp gallery
                                    • gillesG
                                      gilles
                                      Yes nobody is perfect.
                                      • gillesG
                                        gilles
                                        This one is new for me!
                                        Well seven years to learn this too. 😳
                                        • Wo3DanW
                                          Wo3Dan
                                          How true.
                                          Fact is, I learned it (lock vertex to edge) from someone else, .....from Anssi.
                                          And this was also after having used SU for several years. (Doh for me at that time)
                                          • GaieusG
                                            And not only the Move tool but the line tool, too (just in case you needed it) 😉
                                            And yes, I only discovered it about a year ago or so? 😆
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 34
                                            • 35
                                            • 24 / 35
