    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.0k Views 135 Watching
      MikeFJaguar
      Ctrl (in Windows) while orbiting lets me turn my model every which way! Fairly useless as an architectural user but a boon for modellers who make widgets. Doh!
      • GaieusG
        That's a "designed feature": Suspending the gravity setting
        • mitcorbM
          mitcorb
          Sort of bootleg Camera Roll. I have used it to get a particular position for precise selection in a busy model. Of course, you could just do a bunch of layering and hiding to avoid this need altogether.
          • olisheaO
            olishea
            I use it for portrait-orientated renders...very useful.
            oli
            • Wo3DanW
              Wo3Dan
              @mikefjaguar said:
              Ctrl (in Windows) while orbiting lets me turn my model every which way! Fairly useless as an architectural user but ......... Doh!
              Rolling the camera (by holding down [Ctrl] when orbiting), to position your model in such a way on screen sometimes helps in order to have the selection window enclose what you want it to select. With gravity ON you might not be able to make that special selection.
                ...and when you Press the SpaceBar that stop it vigorously! 💚
                http://www.freebiker.net/FichesPratiques/Freinage_problemes/problemes_freinage.jpg
                • porch_unpluggedP
                  porch_unplugged
                  ugh, i think i just made myself travel sick trying that out.
                  • porch_unpluggedP
                    porch_unplugged
                    if you are trying to draw something small and the clipping plane is getting in the way, change to parallel projection view.
                      I often find I get clipping issues more quickly with parallel view...
                      • brodieB
                        brodie
                        I'm on board with the parallel projection. I find that when you initially change to PP you'll get some bad clipping, but if you select your geometry and then zoom extents the clipping goes away and you can zoom in as much as you want.
                        -Brodie
                        • V
                          valerostudio
                          Left, Right, Up arrows lock the Red Green Blue Axis when using move! How did it take me 7 years to figure this one out!
                          • gillesG
                            gilles
                            Seven years!
                            You should read the manual, just in case. 😄
                            Error 404 (Not Found)!!1
                            (support.google.com)
                            • V
                              valerostudio
                              There's a manual? 😉
                              • Wo3DanW
                                Wo3Dan
                                @gilles said:
                                Seven years!
                                Useful reading but here it lacks the information about how to use to rotate a group or component accurately according to the current drawing axes system with angle input.
                                Also I couldn't find anything about moving vertices. And even more, while doing so, how to lock moving a vertex to its own edge's direction. (=hover over the edge first, press [Shift], only then move the vertex)
                                • cottyC
                                  cotty
                                  @wo3dan said:
                                  ...lock moving a vertex to its own edge's direction. (=hover over the edge first, press [Shift], only then move the vertex)
                                  New one for me, thank you!
                                  my SketchUp gallery
                                  • gillesG
                                    gilles
                                    Yes nobody is perfect.
                                    • gillesG
                                      gilles
                                      This one is new for me!
                                      Well seven years to learn this too. 😳
                                      • Wo3DanW
                                        Wo3Dan
                                        How true.
                                        Fact is, I learned it (lock vertex to edge) from someone else, .....from Anssi.
                                        And this was also after having used SU for several years. (Doh for me at that time)
                                        • GaieusG
                                          And not only the Move tool but the line tool, too (just in case you needed it) 😉
                                          And yes, I only discovered it about a year ago or so? 😆
                                          • broomstickB
                                            broomstick
                                            There's always something new to learn..
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 34
                                            • 35
                                            • 24 / 35
