    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 543.0k Views 135 Watching
      ... and if you are not satisfy you can continue "*" "/" with any unity even different than settings untill taking another tool! 😄
      • arail1A Offline
        arail1
        @panixia said:
        just discovered a DOH feature of the selection tool..
        if you drag a selection rectangle from left to right it selects only the items completely wrapped in the rectangle, but if you drag the rectangle from right toward left,then also the items wich are only touched (but not fully wrapped) by the rectangle are selected.. never noticed it before.. 😲
        This is important to know also because it's one of the few things that tends to be consistent across most 3D software applications.
          MikeFJaguar
          Ctrl (in Windows) while orbiting lets me turn my model every which way! Fairly useless as an architectural user but a boon for modellers who make widgets. Doh!
            That's a "designed feature": Suspending the gravity setting
            • mitcorbM Offline
              mitcorb
              Sort of bootleg Camera Roll. I have used it to get a particular position for precise selection in a busy model. Of course, you could just do a bunch of layering and hiding to avoid this need altogether.
              • olisheaO Offline
                olishea
                I use it for portrait-orientated renders...very useful.
                oli
                • Wo3DanW Offline
                  Wo3Dan
                  @mikefjaguar said:
                  Ctrl (in Windows) while orbiting lets me turn my model every which way! Fairly useless as an architectural user but ......... Doh!
                  Rolling the camera (by holding down [Ctrl] when orbiting), to position your model in such a way on screen sometimes helps in order to have the selection window enclose what you want it to select. With gravity ON you might not be able to make that special selection.
                    ...and when you Press the SpaceBar that stop it vigorously! 💚
                    http://www.freebiker.net/FichesPratiques/Freinage_problemes/problemes_freinage.jpg
                    • porch_unpluggedP Offline
                      porch_unplugged
                      ugh, i think i just made myself travel sick trying that out.
                        porch_unplugged
                        if you are trying to draw something small and the clipping plane is getting in the way, change to parallel projection view.
                          I often find I get clipping issues more quickly with parallel view...
                          • brodieB Offline
                            brodie
                            I'm on board with the parallel projection. I find that when you initially change to PP you'll get some bad clipping, but if you select your geometry and then zoom extents the clipping goes away and you can zoom in as much as you want.
                            -Brodie
                            • V Offline
                              valerostudio
                              Left, Right, Up arrows lock the Red Green Blue Axis when using move! How did it take me 7 years to figure this one out!
                              • gillesG Offline
                                gilles
                                Seven years!
                                You should read the manual, just in case. 😄
                                Error 404 (Not Found)!!1
                                (support.google.com)
                                • V Offline
                                  valerostudio
                                  There's a manual? 😉
                                  • Wo3DanW Offline
                                    Wo3Dan
                                    @gilles said:
                                    Seven years!
                                    Useful reading but here it lacks the information about how to use to rotate a group or component accurately according to the current drawing axes system with angle input.
                                    Also I couldn't find anything about moving vertices. And even more, while doing so, how to lock moving a vertex to its own edge's direction. (=hover over the edge first, press [Shift], only then move the vertex)
                                    • cottyC Offline
                                      cotty
                                      @wo3dan said:
                                      ...lock moving a vertex to its own edge's direction. (=hover over the edge first, press [Shift], only then move the vertex)
                                      New one for me, thank you!
                                      my SketchUp gallery
                                      • gillesG Offline
                                        gilles
                                        Yes nobody is perfect.
                                        • gillesG Offline
                                          gilles
                                          This one is new for me!
                                          Well seven years to learn this too. 😳
                                          • Wo3DanW Offline
                                            Wo3Dan
                                            How true.
                                            Fact is, I learned it (lock vertex to edge) from someone else, .....from Anssi.
                                            And this was also after having used SU for several years. (Doh for me at that time)
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 34
                                            • 35
                                            • 24 / 35
