    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 579.8k Views 135 Watching
    • cottyC
      cotty
      You can toggle the "active cut" setting of a section plane with a double click...
      my SketchUp gallery
        d12dozr
        !!! ๐Ÿ‘ ๐ŸŽ‰ ๐Ÿ˜„
        http://goo.gl/f7ooYh
        • panixiaP
          panixia
          just discovered a DOH feature of the selection tool..
          if you drag a selection rectangle from left to right it selects only the items completely wrapped in the rectangle, but if you drag the rectangle from right toward left,then also the items wich are only touched (but not fully wrapped) by the rectangle are selected.. never noticed it before.. ๐Ÿ˜ฒ
          • cottyC
            cotty
            How could you select without this? ๐Ÿ˜›
            (See here for details)
            For complex selections, the combination with the parallel view can help a lot...
            my SketchUp gallery
              And for some Selection / un-selection try some combinaisons of SHIFT and / Or CTRL ๐Ÿ˜‰
              • panixiaP
                panixia
                i know how to use selection and modifier, the only DOH part is about the change of behaviour from left/right direction
                  rv1974
                  Say you worked in Untitled.skp and suddenly your PC crashed. To discover the unknown location of autosave file start the blank file and make 'Save': it will show the folder with autosave folder.
                  • ToboboT
                    Tobobo
                    I have just found by accident that you can drag nested groups and components in the outliner from one to another and it keeps its location. ๐Ÿ˜ฎ
                    Toby
                    Philippians 4:13
                      Ooh! That's nice! I've never used the Outliner much, but that's a nice observation.
                      +1 from me!
                        Yes, highlighting and moving containers within the Outliner works very much like Cut+PasteInPlace when you move groups/instances between 'parents' - just MUCH easier...
                        It's also a useful way to open a nested container for editing, just find it 'by name' in the Outliner [benefit of naming sensibly!] and then select it and double-click it; and it's also best if View > Component Edit > Hide Rest of Model is toggled ON so you can see what you are doing [a shortcut-key to toggle this is de riguer]...
                        • brodieB
                          brodie
                          Just found a new one. You can copy a line over and type 10', then, after hitting enter you can type /10 to get 10 equally spaced lines.
                          I have been doing that as two separate functions forever (copying the line 10' to get the spacing right then copying it back and snapping it to the other line 10' away and THEN hitting /10).
                          -Brodie
                            ... and if you are not satisfy you can continue "*" "/" with any unity even different than settings untill taking another tool! ๐Ÿ˜„
                            • arail1A
                              arail1
                              This is important to know also because it's one of the few things that tends to be consistent across most 3D software applications.
                                MikeFJaguar
                                Ctrl (in Windows) while orbiting lets me turn my model every which way! Fairly useless as an architectural user but a boon for modellers who make widgets. Doh!
                                • GaieusG
                                  That's a "designed feature": Suspending the gravity setting
                                  • mitcorbM
                                    mitcorb
                                    Sort of bootleg Camera Roll. I have used it to get a particular position for precise selection in a busy model. Of course, you could just do a bunch of layering and hiding to avoid this need altogether.
                                    • olisheaO
                                      olishea
                                      I use it for portrait-orientated renders...very useful.
                                      oli
                                      • Wo3DanW
                                        Wo3Dan
                                        @mikefjaguar said:
                                        Ctrl (in Windows) while orbiting lets me turn my model every which way! Fairly useless as an architectural user but ......... Doh!
                                        Rolling the camera (by holding down [Ctrl] when orbiting), to position your model in such a way on screen sometimes helps in order to have the selection window enclose what you want it to select. With gravity ON you might not be able to make that special selection.
                                          ...and when you Press the SpaceBar that stop it vigorously! ๐Ÿ’š
                                          http://www.freebiker.net/FichesPratiques/Freinage_problemes/problemes_freinage.jpg
                                          • porch_unpluggedP
                                            porch_unplugged
                                            ugh, i think i just made myself travel sick trying that out.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 34
                                            • 35
                                            • 24 / 35
