    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 314.1k Views 135 Watching
      I was reading a topic and realized that I did not understand a word.
      Then looked up and also realized I was in the Developers Forum. πŸ˜’
        0101011101101000011000010111010000101100001000000111100101101111011101010010000001100100011011110010000001101110011011110111010000100000011101010110111001100100011001010111001001110011011101000110000101101110011001000010000001100010011010010110111001100001011100100111100100111111
          Didn't you mean
          010110010110111101110101001000000110010001101111001000000110111001101111011101000010000001110101011011100110010001100101011100100111001101110100011000010110111001100100001000000110001001101001011011100110000101110010011110010010000000100001
          πŸ˜• πŸ˜‰
          • Rich O BrienR Online
            01101000 01101111 01110111 00100000 01110010 01110101 01100100 01100101 00100001
              It wasn't... but
              0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
                mrossk
                I think I got geek all over me πŸ˜‰
                https://www.mkaplanfinefurniture.com/
                  πŸ’š
                  	100001
                  	11000
                  	1110
                  	100011
                  	1100
                  	10001
                  	100100
                  	11110
                    Found a cool one today.
                    Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
                    What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
                    However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                    -Brodie
                    Duh!
                    That is sweet!
                    The manual doesn't even mention this!
                    http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
                    • H Offline
                      Heaps
                      It even works with circular arrays - just type in the angle in degrees
                      • brodieB Offline
                        brodie
                        However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                        -Brodie
                        • broomstickB Offline
                          broomstick
                          -Brodie
                          This, sir, just made my day!
                          • Bob JamesB Offline
                            Bob James
                            • jgbJ Offline
                              jgb
                              Found a cool one today. πŸ˜’
                              -Brodie
                              I just wish you found this last week, when I needed it. πŸ˜†
                              jgb
                                d12dozr
                                -Brodie
                                I learned that just a couple months ago from Dave R at a local meetup πŸ‘
                                http://goo.gl/f7ooYh
                                • aarondietzenA Offline
                                  aarondietzen
                                  Shift + Eraser to smooth...
                                  I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
                                  Ah... feels good to share my stupidity!
                                  "Imagination is more important than knowledge..."
                                  - Albert Einstein
                                  • massimoM Offline
                                    massimo Moderator
                                    Ctrl+ eraser is to smooth. Shift+eraser is to hide. πŸ˜‰
                                      aarondietzen
                                      Stupidity x2! πŸ˜†
                                      - Albert Einstein
                                        Ctrl+Erase = Soft+Smooth
                                        Shift+Erase = Hide
                                        Ctrl+Shift+Erase = Un-soft+Smooth (But not Unhide!)
                                          Shift+Erase = Hide
                                          Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']...
                                            aarondietzen
                                            @tig said:
                                            Shift+Erase = Hide
                                            "Learn something new everyday!"
                                            In this case... several new things.
                                            - Albert Einstein
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
