    [Plugin] SplitUp
    38 Posts 20 Posters 84.9k Views 20 Watching
      You could also use it for crosswords or sudoku. It has a myriad of uses 👍
      • massimoM Offline
        massimo Moderator
          JGA
          Still none the wiser though...
          Regards,
          JGA
          • massimoM Offline
            massimo Moderator
            Well JGA it's useful if you want to subdivide a surface in order to use it in a rendering software which supports displacement. 😉
              ...and displacement is like bumps on steroids.
                I know nothing...
                I was only acting on orders.
                • massimoM Offline
                  massimo Moderator
                    He's been a good pupil. Bit cranky but certainly has potential. 👍
                    • F Offline
                      Fletch
                      Very nice, thank you gentlemen!
                      Fletch
                      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                        Panga
                        Thanks a lot for this one !!! 👍
                        • simon le bonS Offline
                          simon le bon
                          Hi Rich and all,
                          Your ruby tools collection is growing very nicely (I'm using your pen tools for a little while and like it a lot 😉 )
                          Concerning SplitUp, I am in limbo 😕
                          I know what is a displacement map but I can't figure out how SplitUp can help 😳
                          Could you give the idea ?
                          http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map.jpg
                          http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map_ball.jpg
                          http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneBumpmap_Sim4.jpg
                          http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneDispMap_handPainted_Ball_2b.jpg
                          Cheers,
                          Simon
                          • massimoM Offline
                            massimo Moderator
                            Displacement needs subdivision of the mesh to work better since it does a real "shift" of the geometry. It's something like, for example, the Smoove tool in SU which needs subdivisions in order to work properly. The Thea mat preview is already subdivided. This plugin is useful when you have to apply displacement to a face (lets say a wall or a roof) which in SU is a single and not subdivided surface.
                              simon le bon
                              Ah OK!
                              The explanation is very clear and makes sense. Thank you Massimo 😉
                              The other tools I know which are able to subdivide are Artisan and FFD1 and FFD2
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/SplitUP_001.jpg
                              In this occurrence, SplitUp is widely the better one 👍 😉 thank you Rich and TIG++
                              Simon
                              • N Offline
                                notareal
                                This is a neat little helper! Useful specially when preparing a model for rendering with displacement.
                                  JGA
                                  @massimo said:
                                  Displacement needs subdivision of the mesh to work better ...
                                  Thanks, got it now!
                                  Regards,
                                  JGA
                                    keyston
                                    awesome script, thanks
                                    • N Offline
                                      nils-petter
                                      thank you so much.
                                        Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=377338#p377338
                                        The Plugins menu item is now disabled; it is now in Tools > Split Tools submenu / Toolbar.
                                        Install TIG-splitTOOLS.rb to add this Toolbar/Tools-submenu...
                                        http://forums.sketchucation.com/viewtopic.php?p=386658#p386658
                                          Jeggebis
                                          Im trying to smoothe out a part of my terrain (Sandbox "from contours") with the artisan plugin. My problem is that the terrain has huge triangles which makes the cross over from the field to the flattened site hard to do (flattened part made by substracting a solid from the solid terrain):
                                          I have tried to split the large triangles into smaller ones with the artisan tool:
                                          But the result is not satisfying:
                                          I now wanted to try the SplitUp plugin to get the large faces divided into squares to get a better result using the Artisan "smoove". But SU (v. 8.0.3161 OSX) crashes every time i try to use this plugin in this model. Same result with TIGs Quadrilateralizer plugin. SU just crashes.
                                          I tried to create a small terrain from contours in a new file and here both plugins worked just fine.
                                          In my big model I also tried to explode the surface of the terrain so it wasnt a solid, but that changed nothing. Still crashed.
                                          Interesting enough, I can get SU to crash (this time it just stops responding) if i draw a contour grid from the Sandbox toolset too! But again, its only in my large landscape file. In a new file, that tool works just fine too.
                                          Ive attached the large landscape here if some one wanted to test it out.
                                          MODEL that crashes
                                            baiduaiya
                                            Thanks a lot!but, why can't I download this thing?
