    [Plugin] SplitUp
    38 Posts 20 Posters 86.8k Views 20 Watching
    • simon le bonS Offline
      simon le bon
      Hi Rich and all,
      Your ruby tools collection is growing very nicely (I'm using your pen tools for a little while and like it a lot 😉 )
      Concerning SplitUp, I am in limbo 😕
      I know what is a displacement map but I can't figure out how SplitUp can help 😳
      Could you give the idea ?
      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map_ball.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneBumpmap_Sim4.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneDispMap_handPainted_Ball_2b.jpg
      Cheers,
      Simon
      • massimoM Offline
        massimo Moderator
        Displacement needs subdivision of the mesh to work better since it does a real "shift" of the geometry. It's something like, for example, the Smoove tool in SU which needs subdivisions in order to work properly. The Thea mat preview is already subdivided. This plugin is useful when you have to apply displacement to a face (lets say a wall or a roof) which in SU is a single and not subdivided surface.
          simon le bon
          Ah OK!
          The explanation is very clear and makes sense. Thank you Massimo 😉
          The other tools I know which are able to subdivide are Artisan and FFD1 and FFD2
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/SplitUP_001.jpg
          In this occurrence, SplitUp is widely the better one 👍 😉 thank you Rich and TIG++
          Simon
          • N Offline
            notareal
            This is a neat little helper! Useful specially when preparing a model for rendering with displacement.
              JGA
              @massimo said:
              Displacement needs subdivision of the mesh to work better ...
              Thanks, got it now!
              Regards,
              JGA
                keyston
                awesome script, thanks
                • N Offline
                  nils-petter
                  thank you so much.
                    Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=377338#p377338
                    The Plugins menu item is now disabled; it is now in Tools > Split Tools submenu / Toolbar.
                    Install TIG-splitTOOLS.rb to add this Toolbar/Tools-submenu...
                    http://forums.sketchucation.com/viewtopic.php?p=386658#p386658
                      Jeggebis
                      Im trying to smoothe out a part of my terrain (Sandbox "from contours") with the artisan plugin. My problem is that the terrain has huge triangles which makes the cross over from the field to the flattened site hard to do (flattened part made by substracting a solid from the solid terrain):
                      I have tried to split the large triangles into smaller ones with the artisan tool:
                      But the result is not satisfying:
                      I now wanted to try the SplitUp plugin to get the large faces divided into squares to get a better result using the Artisan "smoove". But SU (v. 8.0.3161 OSX) crashes every time i try to use this plugin in this model. Same result with TIGs Quadrilateralizer plugin. SU just crashes.
                      I tried to create a small terrain from contours in a new file and here both plugins worked just fine.
                      In my big model I also tried to explode the surface of the terrain so it wasnt a solid, but that changed nothing. Still crashed.
                      Interesting enough, I can get SU to crash (this time it just stops responding) if i draw a contour grid from the Sandbox toolset too! But again, its only in my large landscape file. In a new file, that tool works just fine too.
                      Ive attached the large landscape here if some one wanted to test it out.
                      MODEL that crashes
                        baiduaiya
                        Thanks a lot!but, why can't I download this thing?
                          Why can't I lick my elbow ?
                          You tell me why you can't download it - or at least what difficulties you are experiencing...
                          Can you see the .rb file link on the first page ?
                          Click it and download the one file and then install it, as per the instructions...
                          If you cannot see the link but there's a note about Ad-Blockers... disable 'ad-blocking' and/or 'do-not-follow' add-ons for SCF site so that you can see attachments - in the members' ToS that you agreed to when you joined one of your promise was not to use ad-blockers when visiting the site. This is because we are almost entirely funded by advertising and no one will pay to place ads if no one is reading them!
                          Let us know what was wrong...
                            smicha
                            Is it possible to add extra parameters to the plugin to work separately in RGB directions? Let's say I have a cube and I want to divide each of its plane into quads. 5x5x5 works great - simply select a cube and use the plugin with '5' as a value. But now I'd like the cube to be cut into 6x4x3 as depicted on the screenshot.
                            https://lh6.googleusercontent.com/-gAQ5KTT-sh4/UTRTspfiJoI/AAAAAAAAC8E/vHPOXJJmQuA/s1040/splitup.jpg
                              I think Thomthom has some tools in his Edges set ?
                              Have you look at that...
                              Of course doing the simple splits as you show is easy enough using native copy/array tools and auto-splitting of crossing edges... 😕
                                is easy enough
                                Sure 😄
                                Select "face X" Copy move / 3
                                Select "face Y" Copy move / 4
                                select "face Z" Copy move / 6
                                not a big deal 😄
                                Internal faces. Make one more shift+click to subtract face from selection then perfect 😎
                                  is easy enough
                                  Sure 😄
                                  not a big deal 😄
                                    Internal faces.
                                    If not wanted yes 😄
                                    else Remove inner faces 😉
                                    but
                                    Curiously the Remove inner faces seems don't yet works! 😮
                                    Maybe icompatibility with another plug ?
                                      smicha
                                      TIG, Pilou, Rich,
                                      Thanks for your comments but this was not my question. I just did it manually in even simpler way. This would be great to have 3 parameters in input in the plugin.
                                      • JQLJ Offline
                                        JQL
                                        Hi Tig and Rich,
                                        Thanks for this addition to SU arsenal.
                                        To improve on what you already have, is it somehow possible to make the plugin work also on holes created by "hole cutting components"?
                                        Best regards,
                                        JQL
                                        www.casca.pt
                                        Visit us on facebook!
                                        • romboutR Offline
                                          rombout
                                          Hi guys, tried this plugin again since quite a while. Im still runnin gold SU 8. For me on mac the plugin 'crashes' a lot. with low numbers it works until i try it from about the 3rd time. The mesh start to flikker and SU stops working.
                                          im running os 10.6.8, its a old lady
                                          • 2 / 2
