    [Plugin] SplitUp
    38 Posts 20 Posters 85.8k Views 20 Watching
      ktslambieng
      woa... thank u verry much.
      I have found,
      I asked,
      I have now found
      • massimoM Offline
        massimo Moderator
        Thanks Rich&TIG. πŸ‘ Will test it.
        • N Offline
          numerobis
          πŸ‘ looks VERY useful! Thanks! 😎
          • andybotA Offline
            andybot
            THANK YOU!!! I've been doing this manually for the longest time. This is perfect!!!
              JGA
              Thanks for sharing the ruby & providing the clear video, but can I ask what this would be used for?
              I thought the mantra for SKUP was to minimise the numbers of edges & faces.
              Regards,
              JGA
              • massimoM Offline
                massimo Moderator
                From Rich's first post...
                Here's a tool you might find useful for displacement.
                πŸ˜„
                  You could also use it for crosswords or sudoku. It has a myriad of uses πŸ‘
                  • massimoM Offline
                    massimo Moderator
                      JGA
                      Still none the wiser though...
                      Regards,
                      JGA
                      • massimoM Offline
                        massimo Moderator
                        Well JGA it's useful if you want to subdivide a surface in order to use it in a rendering software which supports displacement. πŸ˜‰
                          ...and displacement is like bumps on steroids.
                            I know nothing...
                            I was only acting on orders.
                            • massimoM Offline
                              massimo Moderator
                              πŸ˜†
                                He's been a good pupil. Bit cranky but certainly has potential. πŸ‘
                                • FletchF Offline
                                  Fletch
                                  Very nice, thank you gentlemen!
                                  Fletch
                                    Panga
                                    Thanks a lot for this one !!! πŸ‘
                                    • simon le bonS Offline
                                      simon le bon
                                      Hi Rich and all,
                                      Your ruby tools collection is growing very nicely (I'm using your pen tools for a little while and like it a lot πŸ˜‰ )
                                      Concerning SplitUp, I am in limbo πŸ˜•
                                      I know what is a displacement map but I can't figure out how SplitUp can help 😳
                                      Could you give the idea ?
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map_ball.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneBumpmap_Sim4.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneDispMap_handPainted_Ball_2b.jpg
                                      Cheers,
                                      Simon
                                      • massimoM Offline
                                        massimo Moderator
                                        Displacement needs subdivision of the mesh to work better since it does a real "shift" of the geometry. It's something like, for example, the Smoove tool in SU which needs subdivisions in order to work properly. The Thea mat preview is already subdivided. This plugin is useful when you have to apply displacement to a face (lets say a wall or a roof) which in SU is a single and not subdivided surface.
                                          simon le bon
                                          Ah OK!
                                          The explanation is very clear and makes sense. Thank you Massimo πŸ˜‰
                                          The other tools I know which are able to subdivide are Artisan and FFD1 and FFD2
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/SplitUP_001.jpg
                                          In this occurrence, SplitUp is widely the better one πŸ‘ πŸ˜‰ thank you Rich and TIG++
                                          Simon
                                          • N Offline
                                            notareal
                                            This is a neat little helper! Useful specially when preparing a model for rendering with displacement.
                                            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
