    [Plugin] SplitUp
    38 Posts 20 Posters 86.8k Views 20 Watching
      JGA
      Still none the wiser though...
      Regards,
      JGA
      • massimoM Offline
        massimo Moderator
        Well JGA it's useful if you want to subdivide a surface in order to use it in a rendering software which supports displacement. 😉
        • Rich O BrienR Online
          ...and displacement is like bumps on steroids.
            I know nothing...
            I was only acting on orders.
            • massimoM Offline
              massimo Moderator
                He's been a good pupil. Bit cranky but certainly has potential. 👍
                • FletchF Offline
                  Fletch
                  Very nice, thank you gentlemen!
                  Fletch
                    Panga
                    Thanks a lot for this one !!! 👍
                    • simon le bonS Offline
                      simon le bon
                      Hi Rich and all,
                      Your ruby tools collection is growing very nicely (I'm using your pen tools for a little while and like it a lot 😉 )
                      Concerning SplitUp, I am in limbo 😕
                      I know what is a displacement map but I can't figure out how SplitUp can help 😳
                      Could you give the idea ?
                      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map_ball.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneBumpmap_Sim4.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneDispMap_handPainted_Ball_2b.jpg
                      Cheers,
                      Simon
                      • massimoM Offline
                        massimo Moderator
                        Displacement needs subdivision of the mesh to work better since it does a real "shift" of the geometry. It's something like, for example, the Smoove tool in SU which needs subdivisions in order to work properly. The Thea mat preview is already subdivided. This plugin is useful when you have to apply displacement to a face (lets say a wall or a roof) which in SU is a single and not subdivided surface.
                          simon le bon
                          Ah OK!
                          The explanation is very clear and makes sense. Thank you Massimo 😉
                          The other tools I know which are able to subdivide are Artisan and FFD1 and FFD2
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/SplitUP_001.jpg
                          In this occurrence, SplitUp is widely the better one 👍 😉 thank you Rich and TIG++
                          Simon
                          • N Offline
                            notareal
                            This is a neat little helper! Useful specially when preparing a model for rendering with displacement.
                              JGA
                              @massimo said:
                              Displacement needs subdivision of the mesh to work better ...
                              Thanks, got it now!
                              Regards,
                              JGA
                                keyston
                                awesome script, thanks
                                • N Offline
                                  nils-petter
                                  thank you so much.
                                    Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=377338#p377338
                                    The Plugins menu item is now disabled; it is now in Tools > Split Tools submenu / Toolbar.
                                    Install TIG-splitTOOLS.rb to add this Toolbar/Tools-submenu...
                                    http://forums.sketchucation.com/viewtopic.php?p=386658#p386658
                                      Jeggebis
                                      Im trying to smoothe out a part of my terrain (Sandbox "from contours") with the artisan plugin. My problem is that the terrain has huge triangles which makes the cross over from the field to the flattened site hard to do (flattened part made by substracting a solid from the solid terrain):
                                      I have tried to split the large triangles into smaller ones with the artisan tool:
                                      But the result is not satisfying:
                                      I now wanted to try the SplitUp plugin to get the large faces divided into squares to get a better result using the Artisan "smoove". But SU (v. 8.0.3161 OSX) crashes every time i try to use this plugin in this model. Same result with TIGs Quadrilateralizer plugin. SU just crashes.
                                      I tried to create a small terrain from contours in a new file and here both plugins worked just fine.
                                      In my big model I also tried to explode the surface of the terrain so it wasnt a solid, but that changed nothing. Still crashed.
                                      Interesting enough, I can get SU to crash (this time it just stops responding) if i draw a contour grid from the Sandbox toolset too! But again, its only in my large landscape file. In a new file, that tool works just fine too.
                                      Ive attached the large landscape here if some one wanted to test it out.
                                      MODEL that crashes
                                        baiduaiya
                                        Thanks a lot!but, why can't I download this thing?
                                          Why can't I lick my elbow ?
                                          You tell me why you can't download it - or at least what difficulties you are experiencing...
                                          Can you see the .rb file link on the first page ?
                                          Click it and download the one file and then install it, as per the instructions...
                                          If you cannot see the link but there's a note about Ad-Blockers... disable 'ad-blocking' and/or 'do-not-follow' add-ons for SCF site so that you can see attachments - in the members' ToS that you agreed to when you joined one of your promise was not to use ad-blockers when visiting the site. This is because we are almost entirely funded by advertising and no one will pay to place ads if no one is reading them!
                                          Let us know what was wrong...
                                            smicha
                                            Is it possible to add extra parameters to the plugin to work separately in RGB directions? Let's say I have a cube and I want to divide each of its plane into quads. 5x5x5 works great - simply select a cube and use the plugin with '5' as a value. But now I'd like the cube to be cut into 6x4x3 as depicted on the screenshot.
                                            https://lh6.googleusercontent.com/-gAQ5KTT-sh4/UTRTspfiJoI/AAAAAAAAC8E/vHPOXJJmQuA/s1040/splitup.jpg
                                            • 2 / 2
