    [Plugin] SplitUp
    38 Posts 20 Posters 85.8k Views 20 Watching
      I know nothing...
      I was only acting on orders.
      • massimoM Offline
        massimo Moderator
          He's been a good pupil. Bit cranky but certainly has potential. 👍
          • FletchF Offline
            Fletch
            Very nice, thank you gentlemen!
            Fletch
              Panga
              Thanks a lot for this one !!! 👍
              • simon le bonS Offline
                simon le bon
                Hi Rich and all,
                Your ruby tools collection is growing very nicely (I'm using your pen tools for a little while and like it a lot 😉 )
                Concerning SplitUp, I am in limbo 😕
                I know what is a displacement map but I can't figure out how SplitUp can help 😳
                Could you give the idea ?
                http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Khashak-map_ball.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneBumpmap_Sim4.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/StoneDispMap_handPainted_Ball_2b.jpg
                Cheers,
                Simon
                • massimoM Offline
                  massimo Moderator
                  Displacement needs subdivision of the mesh to work better since it does a real "shift" of the geometry. It's something like, for example, the Smoove tool in SU which needs subdivisions in order to work properly. The Thea mat preview is already subdivided. This plugin is useful when you have to apply displacement to a face (lets say a wall or a roof) which in SU is a single and not subdivided surface.
                    simon le bon
                    Ah OK!
                    The explanation is very clear and makes sense. Thank you Massimo 😉
                    The other tools I know which are able to subdivide are Artisan and FFD1 and FFD2
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/SplitUP_001.jpg
                    In this occurrence, SplitUp is widely the better one 👍 😉 thank you Rich and TIG++
                    Simon
                    • N Offline
                      notareal
                      This is a neat little helper! Useful specially when preparing a model for rendering with displacement.
                      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                        JGA
                        @massimo said:
                        Displacement needs subdivision of the mesh to work better ...
                        Thanks, got it now!
                        Regards,
                        JGA
                          keyston
                          awesome script, thanks
                          • N Offline
                            nils-petter
                            thank you so much.
                              Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=377338#p377338
                              The Plugins menu item is now disabled; it is now in Tools > Split Tools submenu / Toolbar.
                              Install TIG-splitTOOLS.rb to add this Toolbar/Tools-submenu...
                              http://forums.sketchucation.com/viewtopic.php?p=386658#p386658
                                Jeggebis
                                Im trying to smoothe out a part of my terrain (Sandbox "from contours") with the artisan plugin. My problem is that the terrain has huge triangles which makes the cross over from the field to the flattened site hard to do (flattened part made by substracting a solid from the solid terrain):
                                I have tried to split the large triangles into smaller ones with the artisan tool:
                                But the result is not satisfying:
                                I now wanted to try the SplitUp plugin to get the large faces divided into squares to get a better result using the Artisan "smoove". But SU (v. 8.0.3161 OSX) crashes every time i try to use this plugin in this model. Same result with TIGs Quadrilateralizer plugin. SU just crashes.
                                I tried to create a small terrain from contours in a new file and here both plugins worked just fine.
                                In my big model I also tried to explode the surface of the terrain so it wasnt a solid, but that changed nothing. Still crashed.
                                Interesting enough, I can get SU to crash (this time it just stops responding) if i draw a contour grid from the Sandbox toolset too! But again, its only in my large landscape file. In a new file, that tool works just fine too.
                                Ive attached the large landscape here if some one wanted to test it out.
                                MODEL that crashes
                                  baiduaiya
                                  Thanks a lot!but, why can't I download this thing?
                                    Why can't I lick my elbow ?
                                    You tell me why you can't download it - or at least what difficulties you are experiencing...
                                    Can you see the .rb file link on the first page ?
                                    Click it and download the one file and then install it, as per the instructions...
                                    If you cannot see the link but there's a note about Ad-Blockers... disable 'ad-blocking' and/or 'do-not-follow' add-ons for SCF site so that you can see attachments - in the members' ToS that you agreed to when you joined one of your promise was not to use ad-blockers when visiting the site. This is because we are almost entirely funded by advertising and no one will pay to place ads if no one is reading them!
                                    Let us know what was wrong...
                                      smicha
                                      Is it possible to add extra parameters to the plugin to work separately in RGB directions? Let's say I have a cube and I want to divide each of its plane into quads. 5x5x5 works great - simply select a cube and use the plugin with '5' as a value. But now I'd like the cube to be cut into 6x4x3 as depicted on the screenshot.
                                      https://lh6.googleusercontent.com/-gAQ5KTT-sh4/UTRTspfiJoI/AAAAAAAAC8E/vHPOXJJmQuA/s1040/splitup.jpg
                                        I think Thomthom has some tools in his Edges set ?
                                        Have you look at that...
                                        Of course doing the simple splits as you show is easy enough using native copy/array tools and auto-splitting of crossing edges... 😕
                                          is easy enough
                                          Sure 😄
                                          Select "face X" Copy move / 3
                                          Select "face Y" Copy move / 4
                                          select "face Z" Copy move / 6
                                          not a big deal 😄
                                          Internal faces. Make one more shift+click to subtract face from selection then perfect 😎
                                            is easy enough
                                            Sure 😄
                                            not a big deal 😄
                                            • 2 / 2
