    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
      RizkySyahputra
      it's amazing πŸ‘ πŸ˜›
      • fredo6F Offline
        NEW RELEASE
        version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
        Note that the parameter "angle of influence" is no longer used.
        See main post for download.
          Thanks Fredo. Much appreciated πŸ‘
          • bazB Offline
            baz
            Great stuff Fredo, thanks.
            Baz
            • fredo6F Offline
              NEW RELEASE
              version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
              Version 2.0b also includes the Italian translation
                πŸ‘ πŸ‘
                • pep75P Offline
                  pep75
                  Fredo is the man!
                  grtzzz
                  Pep
                  • N Offline
                    niks
                    just wanted to say THANK YOU πŸ‘Š
                      BBLV
                      Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
                      Example of desired finished result:
                      http://www.glumber.com/WoodTopSubpages/Details/EdgeTreatmentData/EdgeTreatmentSubPages/Edge_Profile_Photos/Roundover/HalfInchRoundover.jpg
                      • mitcorbM Offline
                        mitcorb
                        Hi, BBLV:
                        You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
                          rock1
                          using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
                          Signature removed by SCF Admin
                            With face and tool selected...
                            Press TAB to open dialogue box
                            Choose Finishing Options
                            Pick option
                              rock1
                              Pick option
                              http://i.imgur.com/BOHLQ.jpg
                              I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
                                What is your question? Your image doesn't show anything useful as far as a problem is concerned.
                                  It's not a telepathic tool - just erase lines and faces that YOU don't want!
                                  • fredo6F Offline
                                    yes it works like a Ctrl+pull.
                                    Actually, doing like the native push pull is much more complex for:
                                    • creating holes
                                    • merging the surfaces after push pull
                                      Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
                                    I suggest you simply erase the unwanted lines.
                                    Fred
                                      rock1
                                      Fred
                                      In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
                                      • massimoM Offline
                                        massimo Moderator
                                        If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools.
                                          Feature request: Option to disable the Context Menu.
                                            +1 πŸ‘
                                            [I have already tweaked my copy so that there's no context-menu, as there are already too many things clogging mine up!]
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 17 / 19
