    SketchUp 2015 is 64bit
    302 Posts 74 Posters 115.4k Views 74 Watching
      That's an easy fix Steve I'd imagine.
      One will eventually come.
      • R
        Rob D
        The new labeling tools are great in Layout. Finally looks like we have the power of Leaders in SketchUp. I've posted about my thoughts http://robindejongh.com/?p=1019
        The 64 bit experience is the biggie, although I still can't get it to work. Memory on my 8Mb machine is still capped at 4Mb. Anyone with suggestions?
        Memory capped at 50%
        • R
          Rob D
          Ah, then I switched on shadows 😄
            Try adding 10000 array of cube and orbiting.
            • B
              Bruce Watt
              In V2014 I had the VCB docked on the left hand side. In V2015 I can seem to move it. How do I move it or is it now fixed?
              SKUP PRO 2021 latest version / update
              Windows 10 Pro
              Dell Alienware Aurora R10 AMD
              AMD Ryzen™ 9 3900X
              NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
              • olisheaO
                olishea
                Still can't believe it's 64 bit. Am I dreaming?! 😄
                oli
                • BoxB
                  If you mean like this, docked above the bottom status bar. Right click on the top toolbar and select Measurements toolbar and drag it to where you want it.
                  • john2J
                    john2
                    All the plugin gods on this forum. Can we have a list of plugins which will not work in the 2015 version of sketchup or which will certainly won't be updated because their creators are no more interested in their future development? 🎉
                    • hellnbakH
                      hellnbak
                      After much digging I may have found solutions to my problems with 2015 - two of my favorite plugins not working "Model Location" and "Nudge".
                      Seems TIG is on the ball and has updated a plugin that will work in 2015
                      this thread can be found here http://sketchucation.com/forums/viewtopic.php?p=40142#p40142
                      TIG's post can be found down at the bottom of the thread, with a link to download the plugin.
                      As for Nudge, Smustard has apparently updated the plugin to work with newer SU versions
                      although I cannot say for certain that it works with 2015. I purchased the plugin about six hours ago and have yet to receive the email with the download link. I have had good luck with their plugins in the past so I'm hoping for the best.
                      Just thought I would pass along this information in case anyone else was wanting these plugins for the new and improved SU
                      • I
                        ilay7k
                        cool news! Need to test
                          You might take a few minutes to have a look around. This is already in progress in the Plugins forum.
                          • B
                            Bruce Watt
                            Beautiful!!
                            Windows 10 Pro
                            AMD Ryzen™ 9 3900X
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              @bob james said:
                              As I mentioned in an earlier post in this thread, Nudge **does **work in 2015. To be really sure, I just verified it again.
                              Yeah, but does it work in SU2015?
                              • Bob JamesB
                                Bob James
                                [attachment=0:1utbndbo]<!-- ia0 -->2014-11-05_055755.png<!-- ia0 -->[/attachment:1utbndbo]
                                As I mentioned in an earlier post in this thread, Nudge **does **work in SU2015. The version I have is nudge.rb 1.5 dated 2008. To be really sure, I just verified it again.
                                • Bob JamesB
                                  Bob James
                                  • hellnbakH
                                    hellnbak
                                    @bob james said:
                                    • JonFarJ
                                      JonFar
                                      so... im getting frustrated by having the same poor performance by SU 2015 in complex models, and then i saw Rob D's post on how his pc responded when switching on the shadows...
                                      i dont have a high end PC like you guys, but i think i should notice some navigation improvement with this 64bit version, but no... its the same performance i get with SU 2014...
                                      i even took a printscreen, and its strange cause even orbiting with shadows on, my SU 2015 only uses a fraction of my RAM and only one core of my CPU...
                                      sorry, my windows is in portuguese
                                      help?
                                      • Mistro11M
                                        Mistro11
                                        I was able to test some of my heavy models and I can confirm that the performance is much better. I also did a test with Thea that would usually crash SU. This time SU did not crash. So far so good. Thanks team! 👍
                                        Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                        • K
                                          kaas
                                          @jonfar said:
                                          help?
                                          Maybe post your system specs? Details about CPU / GPU / MOBO / RAM etc. Maybe there's something useful in there.
                                          • jeff hammondJ
                                            jeff hammond
                                            [attachment=0:zzttatg3]<!-- ia0 -->1.jpg<!-- ia0 -->[/attachment:zzttatg3]
                                            help?
                                            it's sort of hard to tell but i'm guessing some of those chairs, pillows, couch details, drapes (etc) are high poly objects and if so, they're going to slow down navigation..
                                            can you post the info in Window-> Model Info-> Statistics ?
                                            (namely, the edge and face count of the model)
                                            dotdotdot
                                            • 6
                                            • 7
                                            • 15
                                            • 16
                                            • 5 / 16
