    SketchUp 2015 is 64bit
    302 Posts 74 Posters 96.5k Views 74 Watching
      @john2 said:
      All the plugin gods on this forum. Can we have a list of plugins which will not work in the 2015 version of sketchup or which will certainly won't be updated because their creators are no more interested in their future development? 🎉
      You might take a few minutes to have a look around. This is already in progress in the Plugins forum.
        Bruce Watt
        @box said:
        @bruce watt said:
        In V2014 I had the VCB docked on the left hand side. In V2015 I can seem to move it. How do I move it or is it now fixed?
        If you mean like this, docked above the bottom status bar. Right click on the top toolbar and select Measurements toolbar and drag it to where you want it.
        Beautiful!!
        SKUP PRO 2021 latest version / update
        Windows 10 Pro
        Dell Alienware Aurora R10 AMD
        AMD Ryzen™ 9 3900X
        NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          @bob james said:
          As I mentioned in an earlier post in this thread, Nudge **does **work in 2015. To be really sure, I just verified it again.
          Yeah, but does it work in SU2015?
          • Bob JamesB Offline
            Bob James
            @hellnbak said:
            After much digging I may have found solutions to my problems with 2015 - two of my favorite plugins not working "Model Location" and "Nudge".
            As for Nudge, Smustard has apparently updated the plugin to work with newer SU versions
            [attachment=0:1utbndbo]<!-- ia0 -->2014-11-05_055755.png<!-- ia0 -->[/attachment:1utbndbo]
            although I cannot say for certain that it works with 2015. I purchased the plugin about six hours ago and have yet to receive the email with the download link. I have had good luck with their plugins in the past so I'm hoping for the best.
            As I mentioned in an earlier post in this thread, Nudge **does **work in SU2015. The version I have is nudge.rb 1.5 dated 2008. To be really sure, I just verified it again.
              Bob James
              • hellnbakH Offline
                hellnbak
                @bob james said:
                • JonFarJ Offline
                  JonFar
                  so... im getting frustrated by having the same poor performance by SU 2015 in complex models, and then i saw Rob D's post on how his pc responded when switching on the shadows...
                  i dont have a high end PC like you guys, but i think i should notice some navigation improvement with this 64bit version, but no... its the same performance i get with SU 2014...
                  i even took a printscreen, and its strange cause even orbiting with shadows on, my SU 2015 only uses a fraction of my RAM and only one core of my CPU...
                  sorry, my windows is in portuguese
                  help?
                  • Mistro11M Offline
                    Mistro11
                    I was able to test some of my heavy models and I can confirm that the performance is much better. I also did a test with Thea that would usually crash SU. This time SU did not crash. So far so good. Thanks team! 👍
                    i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                    Structural Integrity is Not Just Physical...It's in the Design and Purpose
                      kaas
                      @jonfar said:
                      help?
                      Maybe post your system specs? Details about CPU / GPU / MOBO / RAM etc. Maybe there's something useful in there.
                      • jeff hammondJ Offline
                        [attachment=0:zzttatg3]<!-- ia0 -->1.jpg<!-- ia0 -->[/attachment:zzttatg3]
                        help?
                        it's sort of hard to tell but i'm guessing some of those chairs, pillows, couch details, drapes (etc) are high poly objects and if so, they're going to slow down navigation..
                        can you post the info in Window-> Model Info-> Statistics ?
                        (namely, the edge and face count of the model)
                        • JonFarJ Offline
                          JonFar
                          yes, of course...
                          Gigabyte F2A88XM-DS2
                          AMD A10-5800k (quadcore at stock speed 3.8ghz and turbo at 4.1ghz)
                          Radeon HD 7660D (part of the APU, with 720mb)
                          2x GSKILL PC3-17000 CL11 (8Gb in dual-channel @ 2133mhz)
                          WD CAVIAR BLUE 7200RPM 16MB SATA III
                          CORSAIR VS 450W
                          i know its not a high end system, but i shouldnt have any navigation lag with that 47mb model with less than 2000 edges...
                          and whats strange is that i get the navigation lag and my system is almost running idle, with only one core working full speed and a fraction of the ram being used
                          i thought it was a 32bit issue, but its exactly the same with SU 2015
                          (oh, and every other app like C4D or AutoCAD work fine, both 64bit of course)
                          here is the model info
                            mcpcorey
                            Hey Guys, I am trying out 2015 here. I have not yet loaded any of my plug-ins yet, because I notice right away that my 3DConnexion Space Mouse Pro, will not yet work in SU 2015. (never realized how dependent I had become on it, until I tried to work without it!)
                            I reloaded the most recent drivers, but no improvement for 2015, still works fine in 2014!.
                            I would guess that 3DXware needs a driver update to be compatible with 2015 and the 64 bit application?
                            I did send a note / tech request this morning to 3DConnexion regarding this.
                            Has anyone had success with a 3DConnexion device in SU2015 ?
                            Corey
                              [attachment=0:26eb8lrv]<!-- ia0 -->2.jpg<!-- ia0 -->[/attachment:26eb8lrv]
                              click the box 'show nested components'
                              I'm thinking the model is in the hundreds of thousands entities range.
                              • JonFarJ Offline
                                JonFar
                                sorry, forgot to do that..
                                you are right, as always
                                but even so, i thing its strange that i get this navigation lag with my system running idle... shouldnt it be using all 4 cores and a bit more RAM than the 2014 SU?
                                  kaas
                                  600k edges and 300k faces might be too much for embedded gfx? Ever tried putting a gfx-card in your system? The fact SU is now 64 bits doesn't mean it will use more than 1 core. That's something totally different.
                                    [attachment=0:2mjb4eyu]<!-- ia0 -->3.jpg<!-- ia0 -->[/attachment:2mjb4eyu]
                                    fwiw, your model is what i personally consider 'a huge sketchup model'.
                                    i don't think ram has anything to do with navigation speed.. (well, i imagine it's part of the process.. just that the ram provided with 32bit is plenty to keep up with the other calculations which must occur.. as in- the available ram of an average computer was never a bottleneck in the navigation speed)
                                    re: multicore.
                                    should it be using all 4 cores? i really don't know.. up til a few weeks ago, i've always thought a program couldn't use more than one core for things like navigation/redraw..
                                    but it appears michael gibson of MOI3D has found a way..
                                    http://moi3d.com/3.0/whatsnew.htm
                                    Multiple CPU cores are now used in the draw engine, typical display speed-up of around 2x to 3x on complex models.
                                    • JonFarJ Offline
                                      JonFar
                                      hmmmm i see...
                                      so my navigation lag is due to my system being an APU? if that's a GPU issue, i can understand
                                      and i will look into that michael gibson's findings
                                      sorry for clogging this thread with my issues, i just wasnt understanding why you guys had such great improvement in performance and i didnt...
                                      i guess i need to invest in a more powerfull machine 😐
                                      thanks guys for your help and patience 👍
                                        @mcpcorey said:
                                        ... because I notice right away that my 3DConnexion Space Mouse Pro, will not yet work in SU 2015.
                                        This has already been covered. They are working on an updated driver package. Check the manufacturer's site.
                                          mcpcorey
                                          Thanks Dave, That is what I suspected, (I knew you would have that answer)
                                          I missed where it has already been covered, and I cannot find any reference to it at their web site.
                                            @jonfar said:
                                            hmmmm i see...
                                            well, nobody's machine, no matter how good or expensive, is going to run that model much(if any) better than you're seeing.
                                            I'm not sure how 3.8ghz AMD translates to intel clock speed but I assume it's decently fast.. you just can't buy faster processors. they're not available.. but sketchup was written at a time when clock speed was doubling every couple of years so for a while, you could upgrade your hardware and get noticeable performance gains in sketchup.. that quit around 6-7 years ago.
                                            • 15
                                            • 16
                                            • 5 / 16
