    SketchUp 2015 is 64bit
    302 Posts 74 Posters 115.5k Views 74 Watching
    • hellnbakH
      hellnbak
      Was going to wait till some of the inevitable bugs were worked out till I tried 2015, but after reading some of the comments here I decided to give it a shot.
      My needs are very basic, I don't use many plugins, so I wasn't sure what the new 64bit SU would do for me.
      WOW! I loaded one of my largest models (not in size, only 4.87MB, but over 3 million edges, 30,000 component instances, etc) and was immediately impressed with how quickly the shadows regenerated when moving the model. Only a second or two, and with R8 I usually took a nap while waiting for the shadows to eventually reappear. And as Krisidious pointed out, without it going into wire mode, no matter how much I played with the model.
      Don't know how I'll live without my beloved and much used Nudge tool, but with what I've seen so far with 2015, I guess I'll learn to get by without it.
      It'll be worth it, since I don't render I depend on using shadows to make my models look presentable. Now it will be a whole lot easier.
      • Bob JamesB
        Bob James
        Why? Works fine for me. You had me really worried until I checked to make sure 😄
          sketchuh
          Can't wait to Vray render in Sketchup 2015!! excited.
          • hellnbakH
            hellnbak
            My enthusiasm for 2015 has been tempered by the fact that I cannot use the Model Location plugin. The Nudge plugin I can maybe do without, but not the Model Location plugin. Not about to go back to physically rotating the model each time I want to adjust the shadows.
            Knew it was too good to be true 😒
              That's an easy fix Steve I'd imagine.
              One will eventually come.
                Rob D
                The new labeling tools are great in Layout. Finally looks like we have the power of Leaders in SketchUp. I've posted about my thoughts http://robindejongh.com/?p=1019
                The 64 bit experience is the biggie, although I still can't get it to work. Memory on my 8Mb machine is still capped at 4Mb. Anyone with suggestions?
                Memory capped at 50%
                  Rob D
                  Ah, then I switched on shadows 😄
                    Try adding 10000 array of cube and orbiting.
                    • B
                      Bruce Watt
                      In V2014 I had the VCB docked on the left hand side. In V2015 I can seem to move it. How do I move it or is it now fixed?
                      SKUP PRO 2021 latest version / update
                      Windows 10 Pro
                      Dell Alienware Aurora R10 AMD
                      AMD Ryzen™ 9 3900X
                      NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
                      • olisheaO
                        olishea
                        Still can't believe it's 64 bit. Am I dreaming?! 😄
                        oli
                        • BoxB
                          If you mean like this, docked above the bottom status bar. Right click on the top toolbar and select Measurements toolbar and drag it to where you want it.
                          • john2J
                            john2
                            All the plugin gods on this forum. Can we have a list of plugins which will not work in the 2015 version of sketchup or which will certainly won't be updated because their creators are no more interested in their future development? 🎉
                            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                            • hellnbakH
                              hellnbak
                              After much digging I may have found solutions to my problems with 2015 - two of my favorite plugins not working "Model Location" and "Nudge".
                              Seems TIG is on the ball and has updated a plugin that will work in 2015
                              this thread can be found here http://sketchucation.com/forums/viewtopic.php?p=40142#p40142
                              TIG's post can be found down at the bottom of the thread, with a link to download the plugin.
                              As for Nudge, Smustard has apparently updated the plugin to work with newer SU versions
                              although I cannot say for certain that it works with 2015. I purchased the plugin about six hours ago and have yet to receive the email with the download link. I have had good luck with their plugins in the past so I'm hoping for the best.
                              Just thought I would pass along this information in case anyone else was wanting these plugins for the new and improved SU
                              • I
                                ilay7k
                                cool news! Need to test
                                  You might take a few minutes to have a look around. This is already in progress in the Plugins forum.
                                  • B
                                    Bruce Watt
                                    Beautiful!!
                                    Windows 10 Pro
                                    AMD Ryzen™ 9 3900X
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      @bob james said:
                                      As I mentioned in an earlier post in this thread, Nudge **does **work in 2015. To be really sure, I just verified it again.
                                      Yeah, but does it work in SU2015?
                                      • Bob JamesB
                                        Bob James
                                        [attachment=0:1utbndbo]<!-- ia0 -->2014-11-05_055755.png<!-- ia0 -->[/attachment:1utbndbo]
                                        As I mentioned in an earlier post in this thread, Nudge **does **work in SU2015. The version I have is nudge.rb 1.5 dated 2008. To be really sure, I just verified it again.
                                        • Bob JamesB
                                          Bob James
                                          • hellnbakH
                                            hellnbak
                                            @bob james said:
                                            • 15
                                            • 16
                                            • 5 / 16
