    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 240.5k Views 45 Watching
    • HieruH Offline
      Hieru
      No problem Cotty.
      When I get time, I think I'll try and reproduce some of the examples with SU. It would also be great if we could get people to post requests/advice for SU proxies.
      www.davidhier.co.uk
      • olisheaO Offline
        olishea
        @charly2008 said:
        I Need your Help. How do I get this quad faces with artisan. I only get this result (see photo below).
        You have an internal face where the hoops meet. Also you need to use "split donut" to split the ngons into quads.
        oli
        • Rich O BrienR Online
          Shame you weren't around in December when he needed to know πŸ˜•
          • olisheaO Offline
            olishea
            And everyone else! πŸ˜„ His query was answered, but not fully. πŸ˜›
            oli
              Good lad.
              Thought I caught u mapping again.
              • olisheaO Offline
                olishea
                Some examples of how loops can affect hard edges in this recess.
                Left to right:
                Hard edge at base.
                Hard edge at wall.
                Double hard edge.
                No hard edge.
                oli
                • HieruH Offline
                  Hieru
                  Some subtle but important differences there Oli πŸ‘
                  www.davidhier.co.uk
                    Cerebral pre modeling! πŸ˜‰
                    • olisheaO Offline
                      olishea
                      @hieru said:
                      It was certainly a worthwhile exercise as I learnt that n-gons in your proxy can be used to create better topology (see the areas highlighted in red).
                      Don't you mean lack of n-gons? Those highlighted red are quads.
                      oli
                      • HieruH Offline
                        Hieru
                        Yes you're right - doh! The proxy modelling and end result make much more sense now.
                        Normally I'd triangulate odd shaped quads in the same way I'd deal with n-gons. Now I know better.
                        www.davidhier.co.uk
                        • olisheaO Offline
                          olishea
                          haha yeah, i was confused for a minute! I couldn't understand how n-gons can make anything better.
                          It doesn't matter how "odd" the quad looks. If it's a quad it's a quad and will perform well. Sometimes you can't avoid triangles. It's too many poles that frustrate me. πŸ˜†
                          oli
                          • HieruH Offline
                            Hieru
                            Lesson learned πŸ˜‰
                            I'll certainly never model proxy circular planes any other way from now on. If this shape is typical, there should be a lot to be learnt from the rest of the examples.
                            www.davidhier.co.uk
                            • HieruH Offline
                              Hieru
                              Had some time to tackle one of the shapes from the topology reference guide. I've changed some of the modelling to make it easier/faster to achieve in Sketchup.
                              Edit: The red areas are quads rather than n-gons. They are however still very important when it comes to creating better topology.
                              BoltHeadPrimitive.skp
                              www.davidhier.co.uk
                              • HieruH Offline
                                Hieru
                                Another example. This time a cylinder with holes.
                                CylinderWithHoles.skp
                                www.davidhier.co.uk
                                • olisheaO Offline
                                  olishea
                                  Very nice work.
                                  Just a quick note: Try using circles with 6 edges instead of 8. When you intersect a 6 sided circle in half with a line you get two halves of quads, if that makes sense. It doesn't really matter for this model, it's just something I should point out. You would end up with less poly too. The starting circle really determines how successful the subdivision is going to be; if you've tried using a strange amount of edges it becomes difficult to keep quads and the model becomes frustrating.
                                  oli
                                  • olisheaO Offline
                                    olishea
                                    Can you do something about the marked areas? Looks a bit strange to me having those stray edges, even though it does form a quad. The large triangles could possibly be avoided too, don't have time to look though.
                                    oli
                                    • HieruH Offline
                                      Hieru
                                      I was simply copying one of the provided examples, but I'll see if there is a better way of doing it.
                                      www.davidhier.co.uk
                                      • HieruH Offline
                                        Hieru
                                        Insets on a curved surface.
                                        CurvedInsets.skp
                                        www.davidhier.co.uk
                                        • HieruH Offline
                                          Hieru
                                          Good point....that's a great tip πŸ‘
                                          www.davidhier.co.uk
                                          • HieruH Offline
                                            Hieru
                                            Is this any better? It generates much neater topology but the poly count goes up.
                                            CylinderWithHoles-V2.skp
                                            www.davidhier.co.uk
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
