    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Thanks tak2hata,
      I can see this plugin becoming a great favorite πŸ‘
      Mike
      • utilerU Offline
        utiler
        No way!!
        Now I can see what a woman looks like with a beard.
        Just Curious...
        • W Offline
          Whaat
          Great plugin! Thanks for sharing!
          • CadFatherC Offline
            CadFather
            Just when you think you've seen it all.. tak2hata comes along with another great idea...thanks! β˜€
              CadFather
              yes please.. πŸ‘
                I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info from your plugin and translate it into the rendering program entities, without creating it inside SU.
                Oooh! Good idea. Keep all data as attributes per face. And use simple lines (in reduced numbers) to represent the fur.
                • N Offline
                  notareal
                  Would it be possible?
                  Cheers
                  Tomasz
                  That would be great!
                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                    tomasz
                    Hi, Thanks a lot for such an interesting plugin!
                    @tak2hata said:
                    Creating Too Much Polygon is very slow.
                    And to use code "entities.fill_from_mesh" must need blank Group.
                    This Plugin executes each selected faces.
                    Creating Group each new 800 polygons.
                    so it parts.
                    I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info (EDIT: transformations of components) from your plugin and translate it into the rendering program entities, without creating it inside SU.
                    Cheers
                    Tomasz
                    Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                    • olisheaO Offline
                      olishea
                      one of the best plugins around!!
                      i'm making everything furry! 😎
                      render cooking πŸ˜„
                      oli
                        tomasz
                        I am testing the plugin and have noticed that it doesn't take an area of a triangle into account. It think it won't be that hard to fix. πŸ˜„
                          That's probably because of MaxNumber(/Face) setting you have set. The Dencity(Num/m2) appears to deal with the area, but larger faces needs more fur, so you need to increase the MaxNumber.
                          • tridemT Offline
                            tridem
                            one more THANK YOU
                            ...and one more request πŸ˜† in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
                              That is easier said than done. It's difficult to get any key press events while scripts are running. Though I thing Fredo has some feature like that...
                              • massimoM Offline
                                massimo Moderator
                                Really funny thank you tak2hata! πŸ‘
                                • K Offline
                                  KarinaGM
                                  Wow!
                                  Amazing tool.
                                  I've just downloaded it and can't wait to start (playing) experimenting
                                  THANKS!
                                  **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                                  -BenjamΓ­n Franklin.**
                                  • olisheaO Offline
                                    olishea
                                    so much fun!!
                                    would be nice if there was a "set defaults" button....and if it remembered your settings between tweaking.
                                    would also be good if the grass was automatically placed on a new layer so you can quickly turn it off or on....you could render the scene without the geometry even being present.
                                    Sketchup view of an old model of mine:
                                    http://i654.photobucket.com/albums/uu269/olishea/urchin_hairy.jpg
                                    oli
                                    • tridemT Offline
                                      tridem
                                      I believe so... eg 'round corner' can do it
                                        tak2hata
                                        I updated the plugin. it's version 1.0.
                                        I saw some requests now.
                                        It seems to be difficult in my skill.
                                        Hereafter, I will study Ruby more.
                                        by TAK2HATA
                                          πŸ˜„ Yea, you've started something. πŸ˜„
                                          If you need help with anything just ask at this forum, people are happy to help.
                                          • olisheaO Offline
                                            olishea
                                            beautiful plugin.
                                            I placed the grass on hidden layer and replaced the component with a single line. Then rendered in twilight using "render all hidden layers" option.
                                            so each line represents blade of grass.
                                            close up of components
                                            http://i654.photobucket.com/albums/uu269/olishea/FUR2.jpg
                                            twilight render
                                            http://i654.photobucket.com/albums/uu269/olishea/FUR.jpg
                                            oli
                                            • 32
                                            • 33
                                            • 3 / 33
