    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      rickgraham
      @xrok1 said:
      i can hear all the script writers now
      "Why the fook didn't i think of that? ๐Ÿ˜• , its so fookin simple too! ๐Ÿ˜ฒ"
      ๐Ÿคฃ
      awsome, simply awsome! ๐Ÿ˜„
      This is a banner day for me and SU.
      Rick
      • ken28875K
        ken28875
        Wow...I am speechless...fur for Sketchup! ๐Ÿ˜ฎ ๐Ÿ˜ฒ
        ๐Ÿ‘ ๐Ÿ‘
        _KN
        Follow Your Dreams.
          Mandatory:
            ark
            Absolute fantastic
            Somehow I can't seem to generate short hair?
            I set the "Lenght" to 0.0001 but the hair doesn't seem to get shorter then approx. 50 mm!
            It would be nice to be able to save presets!!!
            Great job ๐Ÿ˜Ž
            • soloS
              Teddy fur.
              Which all but choked SU to death.
                minguinhirigue
                Really nice one I missed from a long time... Thanks.
                • Mike LuceyM
                  Mike Lucey
                  Thanks tak2hata,
                  I can see this plugin becoming a great favorite ๐Ÿ‘
                  Mike
                  • utilerU
                    utiler
                    No way!!
                    Now I can see what a woman looks like with a beard.
                    Just Curious...
                    • W
                      Whaat
                      Great plugin! Thanks for sharing!
                      • CadFatherC
                        CadFather
                        Just when you think you've seen it all.. tak2hata comes along with another great idea...thanks! โ˜€
                        • CadFatherC
                          CadFather
                          yes please.. ๐Ÿ‘
                            I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info from your plugin and translate it into the rendering program entities, without creating it inside SU.
                            Oooh! Good idea. Keep all data as attributes per face. And use simple lines (in reduced numbers) to represent the fur.
                            • N
                              notareal
                              Would it be possible?
                              Cheers
                              Tomasz
                              That would be great!
                              • T
                                tomasz
                                Hi, Thanks a lot for such an interesting plugin!
                                @tak2hata said:
                                Creating Too Much Polygon is very slow.
                                And to use code "entities.fill_from_mesh" must need blank Group.
                                This Plugin executes each selected faces.
                                Creating Group each new 800 polygons.
                                so it parts.
                                I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info (EDIT: transformations of components) from your plugin and translate it into the rendering program entities, without creating it inside SU.
                                Cheers
                                Tomasz
                                • olisheaO
                                  olishea
                                  one of the best plugins around!!
                                  i'm making everything furry! ๐Ÿ˜Ž
                                  render cooking ๐Ÿ˜„
                                  oli
                                  • T
                                    tomasz
                                    I am testing the plugin and have noticed that it doesn't take an area of a triangle into account. It think it won't be that hard to fix. ๐Ÿ˜„
                                      That's probably because of MaxNumber(/Face) setting you have set. The Dencity(Num/m2) appears to deal with the area, but larger faces needs more fur, so you need to increase the MaxNumber.
                                      • tridemT
                                        tridem
                                        one more THANK YOU
                                        ...and one more request ๐Ÿ˜† in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
                                          That is easier said than done. It's difficult to get any key press events while scripts are running. Though I thing Fredo has some feature like that...
                                          • massimoM
                                            massimo Moderator
                                            Really funny thank you tak2hata! ๐Ÿ‘
                                            • 32
                                            • 33
                                            • 3 / 33
