    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
      tomasz
      Hi, Thanks a lot for such an interesting plugin!
      @tak2hata said:
      Creating Too Much Polygon is very slow.
      And to use code "entities.fill_from_mesh" must need blank Group.
      This Plugin executes each selected faces.
      Creating Group each new 800 polygons.
      so it parts.
      I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info (EDIT: transformations of components) from your plugin and translate it into the rendering program entities, without creating it inside SU.
      Would it be possible?
      Cheers
      Tomasz
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
      • olisheaO Offline
        olishea
        one of the best plugins around!!
        i'm making everything furry! 😎
        render cooking πŸ˜„
        oli
          tomasz
          I am testing the plugin and have noticed that it doesn't take an area of a triangle into account. It think it won't be that hard to fix. πŸ˜„
            That's probably because of MaxNumber(/Face) setting you have set. The Dencity(Num/m2) appears to deal with the area, but larger faces needs more fur, so you need to increase the MaxNumber.
            • tridemT Offline
              tridem
              one more THANK YOU
              ...and one more request πŸ˜† in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
                That is easier said than done. It's difficult to get any key press events while scripts are running. Though I thing Fredo has some feature like that...
                • massimoM Offline
                  massimo Moderator
                  Really funny thank you tak2hata! πŸ‘
                    KarinaGM
                    Wow!
                    Amazing tool.
                    I've just downloaded it and can't wait to start (playing) experimenting
                    THANKS!
                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                    -BenjamΓ­n Franklin.**
                    • olisheaO Offline
                      olishea
                      so much fun!!
                      would be nice if there was a "set defaults" button....and if it remembered your settings between tweaking.
                      would also be good if the grass was automatically placed on a new layer so you can quickly turn it off or on....you could render the scene without the geometry even being present.
                      Sketchup view of an old model of mine:
                      http://i654.photobucket.com/albums/uu269/olishea/urchin_hairy.jpg
                      oli
                      • tridemT Offline
                        tridem
                        I believe so... eg 'round corner' can do it
                          tak2hata
                          I updated the plugin. it's version 1.0.
                          I saw some requests now.
                          It seems to be difficult in my skill.
                          Hereafter, I will study Ruby more.
                          by TAK2HATA
                            πŸ˜„ Yea, you've started something. πŸ˜„
                            If you need help with anything just ask at this forum, people are happy to help.
                            • olisheaO Offline
                              olishea
                              beautiful plugin.
                              I placed the grass on hidden layer and replaced the component with a single line. Then rendered in twilight using "render all hidden layers" option.
                              so each line represents blade of grass.
                              close up of components
                              http://i654.photobucket.com/albums/uu269/olishea/FUR2.jpg
                              twilight render
                              http://i654.photobucket.com/albums/uu269/olishea/FUR.jpg
                              oli
                                That's my nostril form inside, Oli 😲
                                Definitely a very promising plugin! I really need to try it out (and Twilight's and Kerkythea's instancing abilities during rendering makes it easy to use hopefully)
                                πŸ‘ πŸ‘ πŸ‘
                                  tak2hata
                                  Hi, thomas.
                                  I am variously studying the article on this site.
                                  Especially, Optimazition tips in Developer forum.
                                  It's very useful.
                                  Thanks.
                                  by TAK2HATA
                                  • olisheaO Offline
                                    olishea
                                    gai: just place the grass on a hidden layer and tell twilight to render all hidden layers. then bobs your uncle. its very very easy to do. you dont even need to rplace the grass with lines, i just did it so i knew where the grass was.
                                    right click>twilight>render all hidden layers
                                    chi ching
                                    and yes it is very nasal!
                                    oli
                                    • DavidBoulderD Offline
                                      DavidBoulder
                                      Looks great, I haven't tried this yet, but I'm surprised nobody has posted a beard on Sang or a chi-Sang with grass growing off his head.
                                      David Goldwasser
                                      OpenStudio Developer
                                      National Renewable Energy Laboratory
                                        Jim
                                        olishea beat you to it:
                                        http://forums.sketchucation.com/viewtopic.php?f=81&t=28127
                                        • olisheaO Offline
                                          olishea
                                          yeah sorry about that πŸ˜„
                                          oli
                                            DavidBoulder
                                            No problem, I just missed it. Looks kind of like bigfoot.
                                            David Goldwasser
                                            • 32
                                            • 33
                                            • 3 / 33
