    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
      That's probably because of MaxNumber(/Face) setting you have set. The Dencity(Num/m2) appears to deal with the area, but larger faces needs more fur, so you need to increase the MaxNumber.
      • tridemT Offline
        tridem
        one more THANK YOU
        ...and one more request ๐Ÿ˜† in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
          That is easier said than done. It's difficult to get any key press events while scripts are running. Though I thing Fredo has some feature like that...
          • massimoM Offline
            massimo Moderator
            Really funny thank you tak2hata! ๐Ÿ‘
              KarinaGM
              Wow!
              Amazing tool.
              I've just downloaded it and can't wait to start (playing) experimenting
              THANKS!
              **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarรก perdiendo ambas"
              -Benjamรญn Franklin.**
              • olisheaO Offline
                olishea
                so much fun!!
                would be nice if there was a "set defaults" button....and if it remembered your settings between tweaking.
                would also be good if the grass was automatically placed on a new layer so you can quickly turn it off or on....you could render the scene without the geometry even being present.
                Sketchup view of an old model of mine:
                http://i654.photobucket.com/albums/uu269/olishea/urchin_hairy.jpg
                oli
                • tridemT Offline
                  tridem
                  I believe so... eg 'round corner' can do it
                    tak2hata
                    I updated the plugin. it's version 1.0.
                    I saw some requests now.
                    It seems to be difficult in my skill.
                    Hereafter, I will study Ruby more.
                    by TAK2HATA
                      ๐Ÿ˜„ Yea, you've started something. ๐Ÿ˜„
                      If you need help with anything just ask at this forum, people are happy to help.
                      • olisheaO Offline
                        olishea
                        beautiful plugin.
                        I placed the grass on hidden layer and replaced the component with a single line. Then rendered in twilight using "render all hidden layers" option.
                        so each line represents blade of grass.
                        close up of components
                        http://i654.photobucket.com/albums/uu269/olishea/FUR2.jpg
                        twilight render
                        http://i654.photobucket.com/albums/uu269/olishea/FUR.jpg
                        oli
                          That's my nostril form inside, Oli ๐Ÿ˜ฒ
                          Definitely a very promising plugin! I really need to try it out (and Twilight's and Kerkythea's instancing abilities during rendering makes it easy to use hopefully)
                          ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                            tak2hata
                            Hi, thomas.
                            I am variously studying the article on this site.
                            Especially, Optimazition tips in Developer forum.
                            It's very useful.
                            Thanks.
                            by TAK2HATA
                            • olisheaO Offline
                              olishea
                              gai: just place the grass on a hidden layer and tell twilight to render all hidden layers. then bobs your uncle. its very very easy to do. you dont even need to rplace the grass with lines, i just did it so i knew where the grass was.
                              right click>twilight>render all hidden layers
                              chi ching
                              and yes it is very nasal!
                              oli
                              • DavidBoulderD Offline
                                DavidBoulder
                                Looks great, I haven't tried this yet, but I'm surprised nobody has posted a beard on Sang or a chi-Sang with grass growing off his head.
                                David Goldwasser
                                OpenStudio Developer
                                National Renewable Energy Laboratory
                                  Jim
                                  olishea beat you to it:
                                  http://forums.sketchucation.com/viewtopic.php?f=81&t=28127
                                  • olisheaO Offline
                                    olishea
                                    yeah sorry about that ๐Ÿ˜„
                                    oli
                                      DavidBoulder
                                      No problem, I just missed it. Looks kind of like bigfoot.
                                      David Goldwasser
                                      • X Offline
                                        xrok1
                                        the component instance is great but as you can see by the results they're not nearly as nice as without it. ๐Ÿ˜ข is they're any way to improve this? perhaps if thomthom code for 'group to component' were somehow utilized to recognize the individuals even though there are slight variations. or maybe if a small group (6-12~) was made into a component and instanced instead of each individual?
                                        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                                        • U Offline
                                          unclex
                                          it's wonderful
                                          thx
                                          • X Offline
                                            xrok1
                                            if you look at the image it seems to have something to do with rotation (gravity) as well?? ๐Ÿ˜•
                                            • 32
                                            • 33
                                            • 3 / 33
