    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
    • jeff hammondJ Offline
      @tak2hata said:
      Hi, Jeff and rick.
      I update Fur_en.rb
      The WebDialog has problem in Mac OSX.
      So I put another menu for the correspondence of this problem.
      The menu named "fur!(MAC)".
      Using InputBox Dialog.
      How in this?
      yep, we're growing some fur now ๐Ÿ˜„
      thanks!
      • soloS Offline
        Was just a matter of time until someone posted hairy balls. ๐Ÿ’š
        • X Offline
          xrok1
          i can hear all the script writers now
          "Why the fook didn't i think of that? ๐Ÿ˜• , its so fookin simple too! ๐Ÿ˜ฒ"
          ๐Ÿคฃ
          awsome, simply awsome! ๐Ÿ˜„
          โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            rickgraham
            ๐Ÿคฃ
            This is a banner day for me and SU.
            Rick
            • ken28875K Offline
              ken28875
              Wow...I am speechless...fur for Sketchup! ๐Ÿ˜ฎ ๐Ÿ˜ฒ
              ๐Ÿ‘ ๐Ÿ‘
              _KN
              Follow Your Dreams.
                Mandatory:
                  ark
                  Absolute fantastic
                  Somehow I can't seem to generate short hair?
                  I set the "Lenght" to 0.0001 but the hair doesn't seem to get shorter then approx. 50 mm!
                  It would be nice to be able to save presets!!!
                  Great job ๐Ÿ˜Ž
                  • soloS Offline
                    Teddy fur.
                    Which all but choked SU to death.
                      minguinhirigue
                      Really nice one I missed from a long time... Thanks.
                      • Mike LuceyM Offline
                        Mike Lucey
                        Thanks tak2hata,
                        I can see this plugin becoming a great favorite ๐Ÿ‘
                        Mike
                        • utilerU Offline
                          utiler
                          No way!!
                          Now I can see what a woman looks like with a beard.
                          Just Curious...
                          • W Offline
                            Whaat
                            Great plugin! Thanks for sharing!
                            • CadFatherC Offline
                              CadFather
                              Just when you think you've seen it all.. tak2hata comes along with another great idea...thanks! โ˜€
                                CadFather
                                yes please.. ๐Ÿ‘
                                  I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info from your plugin and translate it into the rendering program entities, without creating it inside SU.
                                  Oooh! Good idea. Keep all data as attributes per face. And use simple lines (in reduced numbers) to represent the fur.
                                  • N Offline
                                    notareal
                                    Would it be possible?
                                    Cheers
                                    Tomasz
                                    That would be great!
                                      tomasz
                                      Hi, Thanks a lot for such an interesting plugin!
                                      @tak2hata said:
                                      Creating Too Much Polygon is very slow.
                                      And to use code "entities.fill_from_mesh" must need blank Group.
                                      This Plugin executes each selected faces.
                                      Creating Group each new 800 polygons.
                                      so it parts.
                                      I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info (EDIT: transformations of components) from your plugin and translate it into the rendering program entities, without creating it inside SU.
                                      Cheers
                                      Tomasz
                                      • olisheaO Offline
                                        olishea
                                        one of the best plugins around!!
                                        i'm making everything furry! ๐Ÿ˜Ž
                                        render cooking ๐Ÿ˜„
                                        oli
                                          tomasz
                                          I am testing the plugin and have noticed that it doesn't take an area of a triangle into account. It think it won't be that hard to fix. ๐Ÿ˜„
                                            That's probably because of MaxNumber(/Face) setting you have set. The Dencity(Num/m2) appears to deal with the area, but larger faces needs more fur, so you need to increase the MaxNumber.
                                            • 32
                                            • 33
                                            • 3 / 33
