    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      Mandatory:
        ark
        Absolute fantastic
        Somehow I can't seem to generate short hair?
        I set the "Lenght" to 0.0001 but the hair doesn't seem to get shorter then approx. 50 mm!
        It would be nice to be able to save presets!!!
        Great job 😎
        • soloS Offline
          Teddy fur.
          Which all but choked SU to death.
            minguinhirigue
            Really nice one I missed from a long time... Thanks.
            • Mike LuceyM Offline
              Mike Lucey
              Thanks tak2hata,
              I can see this plugin becoming a great favorite πŸ‘
              Mike
              • utilerU Offline
                utiler
                No way!!
                Now I can see what a woman looks like with a beard.
                Just Curious...
                • W Offline
                  Whaat
                  Great plugin! Thanks for sharing!
                  • CadFatherC Offline
                    CadFather
                    Just when you think you've seen it all.. tak2hata comes along with another great idea...thanks! β˜€
                      CadFather
                      yes please.. πŸ‘
                        I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info from your plugin and translate it into the rendering program entities, without creating it inside SU.
                        Oooh! Good idea. Keep all data as attributes per face. And use simple lines (in reduced numbers) to represent the fur.
                        • N Offline
                          notareal
                          Would it be possible?
                          Cheers
                          Tomasz
                          That would be great!
                            tomasz
                            Hi, Thanks a lot for such an interesting plugin!
                            @tak2hata said:
                            Creating Too Much Polygon is very slow.
                            And to use code "entities.fill_from_mesh" must need blank Group.
                            This Plugin executes each selected faces.
                            Creating Group each new 800 polygons.
                            so it parts.
                            I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info (EDIT: transformations of components) from your plugin and translate it into the rendering program entities, without creating it inside SU.
                            Cheers
                            Tomasz
                            • olisheaO Offline
                              olishea
                              one of the best plugins around!!
                              i'm making everything furry! 😎
                              render cooking πŸ˜„
                              oli
                                tomasz
                                I am testing the plugin and have noticed that it doesn't take an area of a triangle into account. It think it won't be that hard to fix. πŸ˜„
                                  That's probably because of MaxNumber(/Face) setting you have set. The Dencity(Num/m2) appears to deal with the area, but larger faces needs more fur, so you need to increase the MaxNumber.
                                  • tridemT Offline
                                    tridem
                                    one more THANK YOU
                                    ...and one more request πŸ˜† in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
                                      That is easier said than done. It's difficult to get any key press events while scripts are running. Though I thing Fredo has some feature like that...
                                      • massimoM Offline
                                        massimo Moderator
                                        Really funny thank you tak2hata! πŸ‘
                                          KarinaGM
                                          Wow!
                                          Amazing tool.
                                          I've just downloaded it and can't wait to start (playing) experimenting
                                          THANKS!
                                          **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                                          -BenjamΓ­n Franklin.**
                                          • olisheaO Offline
                                            olishea
                                            so much fun!!
                                            would be nice if there was a "set defaults" button....and if it remembered your settings between tweaking.
                                            would also be good if the grass was automatically placed on a new layer so you can quickly turn it off or on....you could render the scene without the geometry even being present.
                                            Sketchup view of an old model of mine:
                                            http://i654.photobucket.com/albums/uu269/olishea/urchin_hairy.jpg
                                            oli
                                            • 32
                                            • 33
                                            • 3 / 33
