    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 59.9k Views 42 Watching
    • wind-borneW Offline
      wind-borne
      kirill,
      Thanks for your response, the problem is that the plugin only appears in the first file of a session, be it opening Sketchup with an old file or a new one. If I open an old or new after the initial startup, plugin is simply not there, curves or curves/faces selected doesn't make any difference( works both ways in first file opened).
      The strange behavior is that the plugin follows the copy/paste and works on the original object (even though I have deleted it after pasting) in the new file but not on anything newly drawn.
      Actually by thinking out loud I can see now how to do what I need to, just a cumbersome path.
      The plugin, itself, has a nice feel. 😄
      "To read between the lines was easier than to follow the text."OSX 10.11.6
      %(#BF80BF)[SU 8 pro
      • halroachH Offline
        halroach
        very nice plugin!
        but, there's always a but... 😄
        1. would be nice if copying and pasting a controlled object between documents would work.
        2. doesn't work within components
        3. undo function doesn't quite work well... takes many undos to go back one visual step.
        keep up the good work!
        FlexTools - Super Quick Windows, Doors, Slats...
        • P Offline
          Panga
          Thanks a lot for this one, it'll be very usefull !!
          • pep75P Offline
            pep75
            GREAT WORK!!!!!
            grtzzzz
            • MALAISEM Offline
              MALAISE
              Kirill , allways a new idea, on the way to interactiv drawing. 😍
              MALAISE 👍
              • K Offline
                kirill2008
                Deformation of geometry groups in the current version (1.2) has plastic nature. It means when the control point places back to its previous position, previous deformation does not disappear completely (some rest deformation remains).
                [flash=425,344:166or01q]http://www.youtube.com/v/mXYjIT-YVRQ&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:166or01q]
                I'll try to make deformation nature optional (plastic or elastic) in future versions.
                  Cynetic 😄
                    REGIS
                    Nice Plugin and thanks for your hard work
                    Works fine but sometime SU6 suddenly crash.
                    Unfortunately it doesn(t works with SU7(mac).
                    Cheers
                    • N Offline
                      notareal
                      Thanks!
                      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                      • CarrozzaC Offline
                        Carrozza
                        One of the most powerful plugins I've seen to date! Bravo Kirill!
                          AcesHigh
                          FANTASTIC!
                            AcesHigh
                            actually, not so fantastic 😞
                            I just cannot add control points to groups, as its done in the videos. I get no such options at the context menu!
                            • mitcorbM Offline
                              mitcorb
                              Can this script recognize and utilize construction/control points placed by another ruby script?
                                DIY fix: open the script in a plain text editor, find the 6 occurrences of 'model.entities' in the script and edit it to 'model.active_entities' - it will then work inside group edits etc...
                                • K Offline
                                  kirill2008
                                  Cool 👍
                                  • mitcorbM Offline
                                    mitcorb
                                    Let us hope that this (TIG's suggestion) is being considered by the author in a revision.
                                    And, I see that it is acknowledged.
                                    • X Offline
                                      xrok1
                                      can't beleive i missed this one! f'n incredible.
                                      i would love to be able to select more than 1 point at a time though(wouldn't need FFD anymore)
                                      “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                        AcesHigh
                                        as far as I know, you can select more than 1 point at a time.
                                          REGIS
                                          Not sure I wouldn't need FFD anymore, I was thinking in a combination with control points and FFD
                                          @ Kirill
                                          Any idea if this plugin could work in SU7 on mac ?
                                          Cheers
                                          • X Offline
                                            xrok1
                                            well i tried making a cylinder; putting a point on each side, then scaling so they got further apart? it allways tends to pull more to one than the other.
                                            • 6
                                            • 2 / 6
