    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 67.3k Views 42 Watching
    • MALAISEM Offline
      MALAISE
      Kirill , allways a new idea, on the way to interactiv drawing. 😍
      MALAISE 👍
        kirill2008
        Deformation of geometry groups in the current version (1.2) has plastic nature. It means when the control point places back to its previous position, previous deformation does not disappear completely (some rest deformation remains).
        [flash=425,344:166or01q]http://www.youtube.com/v/mXYjIT-YVRQ&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:166or01q]
        I'll try to make deformation nature optional (plastic or elastic) in future versions.
          Cynetic 😄
            REGIS
            Nice Plugin and thanks for your hard work
            Works fine but sometime SU6 suddenly crash.
            Unfortunately it doesn(t works with SU7(mac).
            Cheers
            • N Offline
              notareal
              • CarrozzaC Offline
                Carrozza
                One of the most powerful plugins I've seen to date! Bravo Kirill!
                  AcesHigh
                  FANTASTIC!
                    AcesHigh
                    actually, not so fantastic 😞
                    I just cannot add control points to groups, as its done in the videos. I get no such options at the context menu!
                    • mitcorbM Offline
                      mitcorb
                      Can this script recognize and utilize construction/control points placed by another ruby script?
                        DIY fix: open the script in a plain text editor, find the 6 occurrences of 'model.entities' in the script and edit it to 'model.active_entities' - it will then work inside group edits etc...
                          kirill2008
                          Cool 👍
                          • mitcorbM Offline
                            mitcorb
                            Let us hope that this (TIG's suggestion) is being considered by the author in a revision.
                            And, I see that it is acknowledged.
                            • X Offline
                              xrok1
                              can't beleive i missed this one! f'n incredible.
                              i would love to be able to select more than 1 point at a time though(wouldn't need FFD anymore)
                                AcesHigh
                                as far as I know, you can select more than 1 point at a time.
                                  REGIS
                                  Not sure I wouldn't need FFD anymore, I was thinking in a combination with control points and FFD
                                  @ Kirill
                                  Any idea if this plugin could work in SU7 on mac ?
                                  Cheers
                                  • X Offline
                                    xrok1
                                    well i tried making a cylinder; putting a point on each side, then scaling so they got further apart? it allways tends to pull more to one than the other.
                                    • EarthMoverE Offline
                                      EarthMover
                                      TIG, got a DIY quick fix for one step undo?
                                      Content Creator at Skapeup
                                        paulbarton
                                        I have an issue whereby the initial move does not seem to register. If i then do another move, and undo it (!) the mesh jumps to the previous position. And just to make matters worse, this only happens intermittently!
                                          kirill2008
                                          This is an interesting idea. You mean you want to select a set of existing c-points + geometry group then make c-points not just c-points, but control c-points. I think it's possible, but it is not implemented yet in the current version.
                                            kirill2008
                                            Speaking of undo: the work on improving 'undo' behavior is in progress (I want to make it more 'natural', not sure if I can but I'll try). In the current version it is necessary to make undo several times to get everything to the initial state.
                                            Note: it is not necessary to wait until geometry transformation finishes, you may undo previous c-point movement while the group refreshes.
                                            For example, you moved c-point, then immidiately decided to get everything back: press 'ctrl+z' combination 3-times immediately to get the c-point back and to cancel group transformation.
                                            I'll try to find out why the initial move does not seem to register.
                                            • 2 / 6
