    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 67.3k Views 42 Watching
      c.plassais
      Excellent!!!
      • boofredlayB Offline
        boofredlay
        It might be nice also to have the undo function work for the whole action rather than each individual step in the script. For example I added 6 control points around a 24 segment circle and it took 50 undo clicks to get back to the creation of the circle, when all I did was run the script once. Make sense?
        Not sure how to do this however, just a thought.
        This one is going to be very useful for me indeed.
        Thanks 👍
          @kirill2008 said:
          Maybe to launch a kind of entity scanner each time when new file loads. It will scan entities to link c-points to curve vertices again. But it will slow opening of huge models...
          That's my concern for a plugin I'm working on as well... was curios to hear if there was any other way.
          • olisheaO Offline
            olishea
            this is amazing
            thank you
            oli
            • EarthMoverE Offline
              EarthMover
              FANTASTICO!!!! Awesome Krill! I think an add control point tool would be a great improvement. Also maybe a simple option to add control points only to existing vertices. This would be great for a subdivided or tesselated mesh, but I think it would require an implementation of soft selection to make a further advancement towards organic modeling.
              Thanks again Krill.
              EDIT - DUH! I looked right past the option to add to "each vertex". Nevermind.
              I do vote for a Krill Toolbar though!!!
              Content Creator at Skapeup
              • utilerU Offline
                utiler
                Ditto, EarthMover!!! Toolbar for sure!!!!!
                Will somebody stop this guy............... 😮
                Just Curious...
                  dedmin
                  Да здравствует дружба между народами
                  • wind-borneW Offline
                    wind-borne
                    Very interesting plugin.
                    i am having a strange problem, plugin only shows up on initial opening drawing. If I open a new one without closing Sketchup completely, no plugin.
                    I've tried copy from initial( where it works) and paste to new with real odd results also. The plugin then shows up but misbehaves. If I draw a new object, new construction points are put on the pasted object(even though I have deleted it) instead of new object which was selected.
                    "To read between the lines was easier than to follow the text."OSX 10.11.6
                    %(#BF80BF)[SU 8 pro
                      kirill2008
                      As I can see on attached picture the whole face is selected, but current version of the script (ver. 1.1.) actually processes only curves. So try select only boundary curve without face itself (you may deselect face by pressing shift and single-clicking on face). Make sure that only boundary is selected. Of course script processing does not depend on opened file (old or new). It depends on what entity is the first one selected: if it occures that curve edge is the 1-st item of selected entities collection, then everything works, if the 1-st item is face, then the command does not appear within context menu.
                      So I'll try to make the script more tolerant to the selection in future versions 😄 .
                      Speaking of copy-paste behaviour, I'll try to find out why it processes so strange (don't know why yet).
                        wind-borne
                        kirill,
                        Thanks for your response, the problem is that the plugin only appears in the first file of a session, be it opening Sketchup with an old file or a new one. If I open an old or new after the initial startup, plugin is simply not there, curves or curves/faces selected doesn't make any difference( works both ways in first file opened).
                        The strange behavior is that the plugin follows the copy/paste and works on the original object (even though I have deleted it after pasting) in the new file but not on anything newly drawn.
                        Actually by thinking out loud I can see now how to do what I need to, just a cumbersome path.
                        The plugin, itself, has a nice feel. 😄
                        %(#BF80BF)[SU 8 pro
                        • halroachH Offline
                          halroach
                          very nice plugin!
                          but, there's always a but... 😄
                          1. would be nice if copying and pasting a controlled object between documents would work.
                          2. doesn't work within components
                          3. undo function doesn't quite work well... takes many undos to go back one visual step.
                          keep up the good work!
                          FlexTools - Super Quick Windows, Doors, Slats...
                            Panga
                            Thanks a lot for this one, it'll be very usefull !!
                            • pep75P Offline
                              pep75
                              GREAT WORK!!!!!
                              grtzzzz
                              • MALAISEM Offline
                                MALAISE
                                Kirill , allways a new idea, on the way to interactiv drawing. 😍
                                MALAISE 👍
                                  kirill2008
                                  Deformation of geometry groups in the current version (1.2) has plastic nature. It means when the control point places back to its previous position, previous deformation does not disappear completely (some rest deformation remains).
                                  [flash=425,344:166or01q]http://www.youtube.com/v/mXYjIT-YVRQ&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:166or01q]
                                  I'll try to make deformation nature optional (plastic or elastic) in future versions.
                                    Cynetic 😄
                                      REGIS
                                      Nice Plugin and thanks for your hard work
                                      Works fine but sometime SU6 suddenly crash.
                                      Unfortunately it doesn(t works with SU7(mac).
                                      Cheers
                                      • N Offline
                                        notareal
                                        • CarrozzaC Offline
                                          Carrozza
                                          One of the most powerful plugins I've seen to date! Bravo Kirill!
                                            AcesHigh
                                            FANTASTIC!
                                            • 2 / 6
