    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 68.0k Views 42 Watching
      kirill2008
      @wind-borne said:
      i am having a strange problem, plugin only shows up on initial opening drawing. If I open a new one without closing Sketchup completely, no plugin.
      As I can see on attached picture the whole face is selected, but current version of the script (ver. 1.1.) actually processes only curves. So try select only boundary curve without face itself (you may deselect face by pressing shift and single-clicking on face). Make sure that only boundary is selected. Of course script processing does not depend on opened file (old or new). It depends on what entity is the first one selected: if it occures that curve edge is the 1-st item of selected entities collection, then everything works, if the 1-st item is face, then the command does not appear within context menu.
      So I'll try to make the script more tolerant to the selection in future versions 😄 .
      Speaking of copy-paste behaviour, I'll try to find out why it processes so strange (don't know why yet).
      • wind-borneW Offline
        wind-borne
        kirill,
        Thanks for your response, the problem is that the plugin only appears in the first file of a session, be it opening Sketchup with an old file or a new one. If I open an old or new after the initial startup, plugin is simply not there, curves or curves/faces selected doesn't make any difference( works both ways in first file opened).
        The strange behavior is that the plugin follows the copy/paste and works on the original object (even though I have deleted it after pasting) in the new file but not on anything newly drawn.
        Actually by thinking out loud I can see now how to do what I need to, just a cumbersome path.
        The plugin, itself, has a nice feel. 😄
        "To read between the lines was easier than to follow the text."OSX 10.11.6
        %(#BF80BF)[SU 8 pro
        • halroachH Offline
          halroach
          very nice plugin!
          but, there's always a but... 😄
          1. would be nice if copying and pasting a controlled object between documents would work.
          2. doesn't work within components
          3. undo function doesn't quite work well... takes many undos to go back one visual step.
          keep up the good work!
          FlexTools - Super Quick Windows, Doors, Slats...
            Panga
            Thanks a lot for this one, it'll be very usefull !!
            • pep75P Offline
              pep75
              GREAT WORK!!!!!
              grtzzzz
              • MALAISEM Offline
                MALAISE
                Kirill , allways a new idea, on the way to interactiv drawing. 😍
                MALAISE 👍
                  kirill2008
                  Deformation of geometry groups in the current version (1.2) has plastic nature. It means when the control point places back to its previous position, previous deformation does not disappear completely (some rest deformation remains).
                  [flash=425,344:166or01q]http://www.youtube.com/v/mXYjIT-YVRQ&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:166or01q]
                  I'll try to make deformation nature optional (plastic or elastic) in future versions.
                    Cynetic 😄
                      REGIS
                      Nice Plugin and thanks for your hard work
                      Works fine but sometime SU6 suddenly crash.
                      Unfortunately it doesn(t works with SU7(mac).
                      Cheers
                      • N Offline
                        notareal
                        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                        • CarrozzaC Offline
                          Carrozza
                          One of the most powerful plugins I've seen to date! Bravo Kirill!
                            AcesHigh
                            FANTASTIC!
                              AcesHigh
                              actually, not so fantastic 😞
                              I just cannot add control points to groups, as its done in the videos. I get no such options at the context menu!
                              • mitcorbM Offline
                                mitcorb
                                Can this script recognize and utilize construction/control points placed by another ruby script?
                                  DIY fix: open the script in a plain text editor, find the 6 occurrences of 'model.entities' in the script and edit it to 'model.active_entities' - it will then work inside group edits etc...
                                    kirill2008
                                    Cool 👍
                                    • mitcorbM Offline
                                      mitcorb
                                      Let us hope that this (TIG's suggestion) is being considered by the author in a revision.
                                      And, I see that it is acknowledged.
                                      • X Offline
                                        xrok1
                                        can't beleive i missed this one! f'n incredible.
                                        i would love to be able to select more than 1 point at a time though(wouldn't need FFD anymore)
                                          AcesHigh
                                          as far as I know, you can select more than 1 point at a time.
                                            REGIS
                                            Not sure I wouldn't need FFD anymore, I was thinking in a combination with control points and FFD
                                            @ Kirill
                                            Any idea if this plugin could work in SU7 on mac ?
                                            Cheers
                                            • 2 / 6
