    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 72.0k Views 42 Watching
    • pep75P Offline
      pep75
      GREAT WORK!!!!!
      grtzzzz
      • MALAISEM Offline
        MALAISE
        Kirill , allways a new idea, on the way to interactiv drawing. 😍
        MALAISE 👍
          kirill2008
          Deformation of geometry groups in the current version (1.2) has plastic nature. It means when the control point places back to its previous position, previous deformation does not disappear completely (some rest deformation remains).
          [flash=425,344:166or01q]http://www.youtube.com/v/mXYjIT-YVRQ&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:166or01q]
          I'll try to make deformation nature optional (plastic or elastic) in future versions.
            Cynetic 😄
              REGIS
              Nice Plugin and thanks for your hard work
              Works fine but sometime SU6 suddenly crash.
              Unfortunately it doesn(t works with SU7(mac).
              Cheers
              • N Offline
                notareal
                • CarrozzaC Offline
                  Carrozza
                  One of the most powerful plugins I've seen to date! Bravo Kirill!
                    AcesHigh
                    FANTASTIC!
                      AcesHigh
                      actually, not so fantastic 😞
                      I just cannot add control points to groups, as its done in the videos. I get no such options at the context menu!
                      • mitcorbM Offline
                        mitcorb
                        Can this script recognize and utilize construction/control points placed by another ruby script?
                        • TIGT Online
                          DIY fix: open the script in a plain text editor, find the 6 occurrences of 'model.entities' in the script and edit it to 'model.active_entities' - it will then work inside group edits etc...
                            kirill2008
                            Cool 👍
                            • mitcorbM Offline
                              mitcorb
                              Let us hope that this (TIG's suggestion) is being considered by the author in a revision.
                              And, I see that it is acknowledged.
                              • X Offline
                                xrok1
                                can't beleive i missed this one! f'n incredible.
                                i would love to be able to select more than 1 point at a time though(wouldn't need FFD anymore)
                                  AcesHigh
                                  as far as I know, you can select more than 1 point at a time.
                                    REGIS
                                    Not sure I wouldn't need FFD anymore, I was thinking in a combination with control points and FFD
                                    @ Kirill
                                    Any idea if this plugin could work in SU7 on mac ?
                                    Cheers
                                    • X Offline
                                      xrok1
                                      well i tried making a cylinder; putting a point on each side, then scaling so they got further apart? it allways tends to pull more to one than the other.
                                      • EarthMoverE Offline
                                        EarthMover
                                        TIG, got a DIY quick fix for one step undo?
                                        Content Creator at Skapeup
                                          paulbarton
                                          I have an issue whereby the initial move does not seem to register. If i then do another move, and undo it (!) the mesh jumps to the previous position. And just to make matters worse, this only happens intermittently!
                                            kirill2008
                                            This is an interesting idea. You mean you want to select a set of existing c-points + geometry group then make c-points not just c-points, but control c-points. I think it's possible, but it is not implemented yet in the current version.
                                            • 2 / 6
