    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 67.1k Views 42 Watching
      kirill2008
      Deformation of geometry groups in the current version (1.2) has plastic nature. It means when the control point places back to its previous position, previous deformation does not disappear completely (some rest deformation remains).
      [flash=425,344:166or01q]http://www.youtube.com/v/mXYjIT-YVRQ&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:166or01q]
      I'll try to make deformation nature optional (plastic or elastic) in future versions.
        Cynetic 😄
          REGIS
          Nice Plugin and thanks for your hard work
          Works fine but sometime SU6 suddenly crash.
          Unfortunately it doesn(t works with SU7(mac).
          Cheers
          • N Offline
            notareal
            • CarrozzaC Offline
              Carrozza
              One of the most powerful plugins I've seen to date! Bravo Kirill!
                AcesHigh
                FANTASTIC!
                  AcesHigh
                  actually, not so fantastic 😞
                  I just cannot add control points to groups, as its done in the videos. I get no such options at the context menu!
                  • mitcorbM Offline
                    mitcorb
                    Can this script recognize and utilize construction/control points placed by another ruby script?
                      DIY fix: open the script in a plain text editor, find the 6 occurrences of 'model.entities' in the script and edit it to 'model.active_entities' - it will then work inside group edits etc...
                        kirill2008
                        Cool 👍
                        • mitcorbM Offline
                          mitcorb
                          Let us hope that this (TIG's suggestion) is being considered by the author in a revision.
                          And, I see that it is acknowledged.
                          • X Offline
                            xrok1
                            can't beleive i missed this one! f'n incredible.
                            i would love to be able to select more than 1 point at a time though(wouldn't need FFD anymore)
                              AcesHigh
                              as far as I know, you can select more than 1 point at a time.
                                REGIS
                                Not sure I wouldn't need FFD anymore, I was thinking in a combination with control points and FFD
                                @ Kirill
                                Any idea if this plugin could work in SU7 on mac ?
                                Cheers
                                • X Offline
                                  xrok1
                                  well i tried making a cylinder; putting a point on each side, then scaling so they got further apart? it allways tends to pull more to one than the other.
                                  • EarthMoverE Offline
                                    EarthMover
                                    TIG, got a DIY quick fix for one step undo?
                                    Content Creator at Skapeup
                                      paulbarton
                                      I have an issue whereby the initial move does not seem to register. If i then do another move, and undo it (!) the mesh jumps to the previous position. And just to make matters worse, this only happens intermittently!
                                        kirill2008
                                        This is an interesting idea. You mean you want to select a set of existing c-points + geometry group then make c-points not just c-points, but control c-points. I think it's possible, but it is not implemented yet in the current version.
                                          kirill2008
                                          Speaking of undo: the work on improving 'undo' behavior is in progress (I want to make it more 'natural', not sure if I can but I'll try). In the current version it is necessary to make undo several times to get everything to the initial state.
                                          Note: it is not necessary to wait until geometry transformation finishes, you may undo previous c-point movement while the group refreshes.
                                          For example, you moved c-point, then immidiately decided to get everything back: press 'ctrl+z' combination 3-times immediately to get the c-point back and to cancel group transformation.
                                          I'll try to find out why the initial move does not seem to register.
                                          • mitcorbM Offline
                                            mitcorb
                                            Kirill:
                                            On the outside c-points question, I thought I had a ruby script loaded prior to install of that placed construction points. I cannot find it now. What I did not fully realize is that cpoints could mean construction point or control point. Evidently your cpoints do more than simply highlight a target point in space.
                                            Sooo-- maybe my question was a bit naive.
                                            But thanks for the reply.
                                            I am putting this script through some modeling tests to learn its use.
                                            Thanks for the opportunity.
                                            mitcorb
                                            • 2 / 6
