    [Plugin] Door-Lintel Update + Window-Sill
    71 Posts 31 Posters 45.2k Views 31 Watching
      Sorry, but although I had updated the RBZ I forgot to click 'Publish' in the PluginStore Dev-page...
      NOW its Download link should work !
      • KrisidiousK Offline
        Krisidious
        It was gone when I went to look, but after a few seconds it was there.
        By: Kristoff Rand
        • P Offline
          pankaj_tamore
          Dear Didier Bur,
          This so magical very easy to use and give incredible result. because it saves lot of time which is consumed by conventional method(which is very cumbersome) of putting doors And windows. your this plug-in has put an end on that ordeal of deleting every single vertical and horizontal line on faces of walls, which very irritating thank you very much and keep it up!
          • jujuJ Offline
            juju
            EXCELLENT! THX
            • halroachH Offline
              halroach
              This plugin is wonderful!
              Does it work within a component? It seems to work for me only when it's in the "open!?"
              FlexTools - Super Quick Windows, Doors, Slats...
                SyahirXIII
                I have been trying to use it using Profile Builder 3 , it seems to have some kind of problem detecting rectangular vertical face.
                Dont work here
                But it seems to work here
                • Didier BurD Offline
                  Didier Bur
                  Hi syahirXIII,
                  The message shown on your image pops up when the reveal's face loop is made of more than 4 edges.
                  Please check if this is the case on the face that doesn't work.
                  Regards
                  DB
                  guanjinG 1 Reply Last reply Reply Quote 0
                  • guanjinG Offline
                    guanjin @TIG
                    @TIG
                    hello
                    This plugin doesn't seem to support sketchup2024
                    A very suitable plugin, can you fix it working on sketchup024?
                    thanks
                    I come from China, is to learn
                    • guanjinG Offline
                      guanjin @Didier Bur
                      @Didier-Bur
                      hello
                      thanks
                      • N Offline
                        naealmeida Newcomers
                        Hello! Can you update the plugin for the new skecthup 2024 please
                          aricfish
                          Hi All,
                          Is this plugin working in 2024 sketchup? Huge time saver but not working for me in newest version.
                          Didier BurD 1 Reply Last reply Reply Quote 0
                            Didier Bur @aricfish
                            @ SU2024 and Door-Lintel users:
                            I don't have SU2024 installed on my PC.
                            Maybe some developer (TIG ?) will update the plugin ?
                            So here it is.
                            Regards,
                            # Name :          door_lintel
                            # Description :   Draws a lintel above door between wall sides, and window as well
                            # Author :        D. Bur
                            # Usage :         select face and "Door by reveal" in context menu
                            # Date :          May 2008
                            # Type :          Tool
                            # History:        1.0 (May 2008) - first version
                            #                 1.1 (May 2008) - window added
                            require 'sketchup.rb'
                            # f=Sketchup.active_model.selection[0]
                            def trad(word)
                            	# tStrings = [["Door" "Porte"],["Window" "Fenetre"]]
                            	tStrings={ "Door" => "Porte", "Window" => "Fenêtre"}
                            	return word if Sketchup.get_locale != "fr"
                            	return tStrings[word]
                            def dbe_by_embrasure(type)
                            	model=Sketchup.active_model
                            	entities=Sketchup.active_model.active_entities
                            	@dbe_door_height=2.m if not @dbe_door_height
                            	@dbe_window_height=135.cm if not @dbe_window_height
                            	@dbe_sill_height=1.m if not @dbe_sill_height
                            	org_face=model.selection[0]
                            	model.start_operation "Door-window by reveal"
                            	  if model.selection.empty?
                            		UI.messagebox("Empty selection: please select a vertical face.")
                            		return
                            	if (model.selection.length !=1)
                            		UI.messagebox("Please select only ONE vertical face.")
                            		return
                            	if  (model.selection[0].class != Sketchup::Face)
                            		UI.messagebox("Please select a vertical face.")
                            		return
                            	if org_face.normal.z>1e-012 or org_face.normal.z<-1e-012
                            		UI.messagebox("Please select a VERTICAL face.")
                            		return
                            	if org_face.outer_loop.edges.length != 4
                            		UI.messagebox("Please select a RECTANGULAR vertical face.")
                            		return
                            	 # Parse edges
                            	edges=org_face.edges
                            	@verticals={}
                            	@horizontals={}
                            	edges.each do |e|
                            		if e.start.position.z==e.end.position.z
                            			@horizontals[e]=e.start.position.z
                            		else
                            			@verticals[e]=e.start.position.distance e.end.position
                            	# Dialog
                            	#puts "type " + type.inspect
                            	if type=="door"
                            		return if !dbe_door_height()
                            	else
                            		return if !dbe_window_height()
                            	# heights control
                            	if type=="door"
                            		height_ok=false
                            		until height_ok
                            			if @dbe_door_height<@verticals.values.max #or (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
                            				height_ok =true
                            			else
                            				UI.messagebox("Incorrect height for this door.\nPlease set it to a lower value than " +@verticals.values.max.to_s)
                            	if type=="window"
                            		heights_ok=false
                            		until heights_ok
                            			if (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
                            				heights_ok =true
                            			else
                            				UI.messagebox("Incorrect heights for this windows.\nSum of sill and window heights should'nt exceed "  + @verticals.values.max.to_s)
                              # Highest edge & lintel height
                              high_edge=@horizontals.index(@horizontals.values.max)
                              bottom_edge=@horizontals.index(@horizontals.values.min)
                              lintel_height=@verticals.values.max-@dbe_door_height if type=="door"
                              lintel_height=@verticals.values.max-(@dbe_window_height+@dbe_sill_height) if type=="window"
                              # New face of lintel
                              p1=high_edge.start.position
                              p2=high_edge.end.position
                              p3=Geom::Point3d.new(p1.x,p1.y,(p1.z-lintel_height))
                              p4=Geom::Point3d.new(p2.x,p2.y,(p2.z-lintel_height))
                              # Mid point of lintel
                              v=p2.vector_to p3
                              v.length=v.length/2.0
                              mid=p2.offset(v)
                              # Opening width
                              v_norm=org_face.normal
                              touch=model.raytest([mid,v_norm])
                              if touch
                                same_object=true
                                hitpoint=touch[0]
                                hit_obj=touch[1]
                                if hit_obj.length>1
                                  hit_face=hit_obj.last
                                  hit_parent=hit_obj[0]
                                  if not hit_parent.entities.include? org_face
                                    same_object=false
                                  else
                                  hit_parent=hit_obj.last
                                width=mid.distance hitpoint
                                if width > 200
                                  go=UI.messagebox("Suspicious door width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
                                  return nil if go==2
                                case hit_parent.typename
                                  when "Face"
                                    if org_face.normal!=hit_face.normal.reverse
                                      UI.messagebox("Opposite reveal not parallel to selected face. Aborting...")
                                      return nil
                                  else
                                    if same_object==false
                                      UI.messagebox("Cannot find opposite wall,\nobstructive "+hit_parent.typename+" found on layer "+hit_parent.layer.name+ ".\nPlease hide it and retry.")
                                      return
                              else
                                UI.messagebox("No opposite wall to connect lintel.")
                                return nil
                              new_face=entities.add_face p1,p2,p4,p3
                              if touch and same_object==true
                                v2=new_face.normal
                                v2.length=width
                                new_face.pushpull width
                                else
                                UI.messagebox("Cannot pushpull lintel.")
                              #Redraw these fucking remaining edges to better kill them
                              e1=entities.add_line(p1.offset(v2),p2.offset(v2))
                              e2=entities.add_line(p1.offset(v2),p3.offset(v2))
                              e3=entities.add_line(p2.offset(v2),p4.offset(v2))
                              e1.erase!
                              e2.erase!
                              e3.erase!
                              if type=="window"
                                # New face of sill
                                p1=bottom_edge.start.position
                                p2=bottom_edge.end.position
                                p3=Geom::Point3d.new(p1.x,p1.y,(p1.z+@dbe_sill_height))
                                p4=Geom::Point3d.new(p2.x,p2.y,(p2.z+@dbe_sill_height))
                                # Mid point of sill
                                v=p2.vector_to p3
                                mid=p2.offset(v)
                                # Opening width
                                if touch
                                  same_object=true
                                  hitpoint=touch[0]
                                  hit_obj=touch[1]
                                  if hit_obj.length>1
                                    #if not hit_parent.entities.include? org_face
                                      #same_object=false
                                    #end
                                  else
                                if width > 200
                                  go=UI.messagebox("Suspicious window width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
                                  return nil if go==2
                                  when "Face"
                                    if v_norm!=hit_face.normal.reverse
                                      return nil
                                  else
                                      return
                              else
                                UI.messagebox("No opposite wall to connect linter.")
                                return nil
                                v2=new_face.normal
                                v2.length=width
                                else
                                UI.messagebox("Cannot pushpull sill.")
                              e1.erase!
                              e2.erase!
                              e3.erase!
                              end # if window
                              model.commit_operation
                            def dbe_door_height
                            	prompt=["Door height: "]
                            	value=[@dbe_door_height]
                            	results=inputbox prompt,value,"Door height"
                            	puts results.inspect
                            	return false if !results
                            	@dbe_door_height=results[0]
                            def dbe_window_height
                            	prompts=["Sill height:  ","Window height:  "]
                            	values=[@dbe_sill_height,@dbe_window_height]
                            	results=inputbox prompts,values,"Window heights"
                            	@dbe_sill_height=results[0]
                            	@dbe_window_height=results[1]
                            def valid_door_selection
                              s=Sketchup.active_model.selection
                              return false if s.length!=1
                              return false if s[0].typename!="Face"
                              return false if s[0].normal.z>1e-012 or s[0].normal.z<-1e-012
                              return false  if s[0].outer_loop.edges.length != 4
                              return true
                            # add menu items
                            if !file_loaded?(__FILE__ )
                              dbe_menu=UI.menu("Tools").add_submenu("Door/Window by reveal")
                              dbe_menu.add_item("Door") { dbe_by_embrasure "door"}
                              dbe_menu.add_item("Window") { dbe_by_embrasure "window" }
                              dbe_menu.add_separator
                               # Context menu
                                UI.add_context_menu_handler do |menu|
                                    if( valid_door_selection )
                                    		menu.add_separator
                                        menu.add_item("Door by reveal") { dbe_by_embrasure "door" }
                                        menu.add_item("Window by reveal") { dbe_by_embrasure "window" }
                                        menu.add_separator
                            file_loaded(__FILE__ )
                            DB
                            • guanjinG Offline
                              guanjin @Didier Bur
                              @Didier-Bur
                              It seems that no one has fixed this plugin😞
                              TIGT 1 Reply Last reply Reply Quote 0
                                TIG Moderator @guanjin
                                @guanjin
                                It doesn't work in v2024 [various errors], e.g.
                                Error: #<NoMethodError: undefined method 'index' for {#Sketchup::Edge:0x0000019daaeab1b0=>0.0, #Sketchup::Edge:0x0000019daaeab160=>39.37007874015748}:Hash>
                                C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 100:in 'dbe_by_embrasure'
                                C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 274:in `block in <top (required)>'
                                @Didier-Bur also obfuscates his code, so without arduously repacking it back into RB code it'd be difficult to say what the issues are...
                                • guanjinG Offline
                                  guanjin
                                  So many experts, no one can fix this plugin
                                  The forum is no longer the same as before
                                  1 Reply Last reply Reply Quote -2
                                    @Didier-Bur needs to fix this - it's his baby...
                                      Didier Bur @TIG
                                      Hi all,
                                      My baby is quite old now 😉
                                      Here is the non-encrypted version. Please unpack in your Plugins dir.
                                      No update because I haven't SU2024.
                                      Regards,DBUR_Lines2Tubes.zip
                                      DB
                                        Didier Bur @Didier Bur
                                        Me again,
                                        Same goes for door_lintel.rb
                                        door_lintel_uncrypted.zip
                                        DB
                                          JGA
                                          Didier, thanks for sharing.
                                          Regards,
                                          JGA
                                          1 Reply Last reply Reply Quote -1
                                          • guanjinG Offline
                                            guanjin
                                            Thank you to Didier Bur for the source code, which successfully fixed the work in 2024 and modified the multi-faceted selection stretching.
                                            guanjinG L sumasterS 4 Replies Last reply Reply Quote 0
                                            • 3 / 4
