    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 47.4k Views 32 Watching
      aricfish
      Hi All,
      Is this plugin working in 2024 sketchup? Huge time saver but not working for me in newest version.
      Didier BurD 1 Reply Last reply Reply Quote 0
      • Didier BurD Offline
        Didier Bur @aricfish
        @ SU2024 and Door-Lintel users:
        I don't have SU2024 installed on my PC.
        Maybe some developer (TIG ?) will update the plugin ?
        So here it is.
        Regards,
        # Name :          door_lintel
        # Description :   Draws a lintel above door between wall sides, and window as well
        # Author :        D. Bur
        # Usage :         select face and "Door by reveal" in context menu
        # Date :          May 2008
        # Type :          Tool
        # History:        1.0 (May 2008) - first version
        #                 1.1 (May 2008) - window added
        require 'sketchup.rb'
        # f=Sketchup.active_model.selection[0]
        def trad(word)
        	# tStrings = [["Door" "Porte"],["Window" "Fenetre"]]
        	tStrings={ "Door" => "Porte", "Window" => "Fenêtre"}
        	return word if Sketchup.get_locale != "fr"
        	return tStrings[word]
        def dbe_by_embrasure(type)
        	model=Sketchup.active_model
        	entities=Sketchup.active_model.active_entities
        	@dbe_door_height=2.m if not @dbe_door_height
        	@dbe_window_height=135.cm if not @dbe_window_height
        	@dbe_sill_height=1.m if not @dbe_sill_height
        	org_face=model.selection[0]
        	model.start_operation "Door-window by reveal"
        	  if model.selection.empty?
        		UI.messagebox("Empty selection: please select a vertical face.")
        		return
        	if (model.selection.length !=1)
        		UI.messagebox("Please select only ONE vertical face.")
        		return
        	if  (model.selection[0].class != Sketchup::Face)
        		UI.messagebox("Please select a vertical face.")
        		return
        	if org_face.normal.z>1e-012 or org_face.normal.z<-1e-012
        		UI.messagebox("Please select a VERTICAL face.")
        		return
        	if org_face.outer_loop.edges.length != 4
        		UI.messagebox("Please select a RECTANGULAR vertical face.")
        		return
        	 # Parse edges
        	edges=org_face.edges
        	@verticals={}
        	@horizontals={}
        	edges.each do |e|
        		if e.start.position.z==e.end.position.z
        			@horizontals[e]=e.start.position.z
        		else
        			@verticals[e]=e.start.position.distance e.end.position
        	# Dialog
        	#puts "type " + type.inspect
        	if type=="door"
        		return if !dbe_door_height()
        	else
        		return if !dbe_window_height()
        	# heights control
        	if type=="door"
        		height_ok=false
        		until height_ok
        			if @dbe_door_height<@verticals.values.max #or (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
        				height_ok =true
        			else
        				UI.messagebox("Incorrect height for this door.\nPlease set it to a lower value than " +@verticals.values.max.to_s)
        	if type=="window"
        		heights_ok=false
        		until heights_ok
        			if (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
        				heights_ok =true
        			else
        				UI.messagebox("Incorrect heights for this windows.\nSum of sill and window heights should'nt exceed "  + @verticals.values.max.to_s)
          # Highest edge & lintel height
          high_edge=@horizontals.index(@horizontals.values.max)
          bottom_edge=@horizontals.index(@horizontals.values.min)
          lintel_height=@verticals.values.max-@dbe_door_height if type=="door"
          lintel_height=@verticals.values.max-(@dbe_window_height+@dbe_sill_height) if type=="window"
          # New face of lintel
          p1=high_edge.start.position
          p2=high_edge.end.position
          p3=Geom::Point3d.new(p1.x,p1.y,(p1.z-lintel_height))
          p4=Geom::Point3d.new(p2.x,p2.y,(p2.z-lintel_height))
          # Mid point of lintel
          v=p2.vector_to p3
          v.length=v.length/2.0
          mid=p2.offset(v)
          # Opening width
          v_norm=org_face.normal
          touch=model.raytest([mid,v_norm])
          if touch
            same_object=true
            hitpoint=touch[0]
            hit_obj=touch[1]
            if hit_obj.length>1
              hit_face=hit_obj.last
              hit_parent=hit_obj[0]
              if not hit_parent.entities.include? org_face
                same_object=false
              else
              hit_parent=hit_obj.last
            width=mid.distance hitpoint
            if width > 200
              go=UI.messagebox("Suspicious door width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
              return nil if go==2
            case hit_parent.typename
              when "Face"
                if org_face.normal!=hit_face.normal.reverse
                  UI.messagebox("Opposite reveal not parallel to selected face. Aborting...")
                  return nil
              else
                if same_object==false
                  UI.messagebox("Cannot find opposite wall,\nobstructive "+hit_parent.typename+" found on layer "+hit_parent.layer.name+ ".\nPlease hide it and retry.")
                  return
          else
            UI.messagebox("No opposite wall to connect lintel.")
            return nil
          new_face=entities.add_face p1,p2,p4,p3
          if touch and same_object==true
            v2=new_face.normal
            v2.length=width
            new_face.pushpull width
            else
            UI.messagebox("Cannot pushpull lintel.")
          #Redraw these fucking remaining edges to better kill them
          e1=entities.add_line(p1.offset(v2),p2.offset(v2))
          e2=entities.add_line(p1.offset(v2),p3.offset(v2))
          e3=entities.add_line(p2.offset(v2),p4.offset(v2))
          e1.erase!
          e2.erase!
          e3.erase!
          if type=="window"
            # New face of sill
            p1=bottom_edge.start.position
            p2=bottom_edge.end.position
            p3=Geom::Point3d.new(p1.x,p1.y,(p1.z+@dbe_sill_height))
            p4=Geom::Point3d.new(p2.x,p2.y,(p2.z+@dbe_sill_height))
            # Mid point of sill
            v=p2.vector_to p3
            mid=p2.offset(v)
            # Opening width
            if touch
              same_object=true
              hitpoint=touch[0]
              hit_obj=touch[1]
              if hit_obj.length>1
                #if not hit_parent.entities.include? org_face
                  #same_object=false
                #end
              else
            if width > 200
              go=UI.messagebox("Suspicious window width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
              return nil if go==2
              when "Face"
                if v_norm!=hit_face.normal.reverse
                  return nil
              else
                  return
          else
            UI.messagebox("No opposite wall to connect linter.")
            return nil
            v2=new_face.normal
            v2.length=width
            else
            UI.messagebox("Cannot pushpull sill.")
          e1.erase!
          e2.erase!
          e3.erase!
          end # if window
          model.commit_operation
        def dbe_door_height
        	prompt=["Door height: "]
        	value=[@dbe_door_height]
        	results=inputbox prompt,value,"Door height"
        	puts results.inspect
        	return false if !results
        	@dbe_door_height=results[0]
        def dbe_window_height
        	prompts=["Sill height:  ","Window height:  "]
        	values=[@dbe_sill_height,@dbe_window_height]
        	results=inputbox prompts,values,"Window heights"
        	@dbe_sill_height=results[0]
        	@dbe_window_height=results[1]
        def valid_door_selection
          s=Sketchup.active_model.selection
          return false if s.length!=1
          return false if s[0].typename!="Face"
          return false if s[0].normal.z>1e-012 or s[0].normal.z<-1e-012
          return false  if s[0].outer_loop.edges.length != 4
          return true
        # add menu items
        if !file_loaded?(__FILE__ )
          dbe_menu=UI.menu("Tools").add_submenu("Door/Window by reveal")
          dbe_menu.add_item("Door") { dbe_by_embrasure "door"}
          dbe_menu.add_item("Window") { dbe_by_embrasure "window" }
          dbe_menu.add_separator
           # Context menu
            UI.add_context_menu_handler do |menu|
                if( valid_door_selection )
                		menu.add_separator
                    menu.add_item("Door by reveal") { dbe_by_embrasure "door" }
                    menu.add_item("Window by reveal") { dbe_by_embrasure "window" }
                    menu.add_separator
        file_loaded(__FILE__ )
        DB
        guanjinG 1 Reply Last reply Reply Quote 0
        • guanjinG Offline
          guanjin @Didier Bur
          @Didier-Bur
          It seems that no one has fixed this plugin😞
          TIGT 1 Reply Last reply Reply Quote 0
          • TIGT Online
            TIG Moderator @guanjin
            @guanjin
            It doesn't work in v2024 [various errors], e.g.
            Error: #<NoMethodError: undefined method 'index' for {#Sketchup::Edge:0x0000019daaeab1b0=>0.0, #Sketchup::Edge:0x0000019daaeab160=>39.37007874015748}:Hash>
            C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 100:in 'dbe_by_embrasure'
            C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 274:in `block in <top (required)>'
            @Didier-Bur also obfuscates his code, so without arduously repacking it back into RB code it'd be difficult to say what the issues are...
            • guanjinG Offline
              guanjin
              So many experts, no one can fix this plugin
              The forum is no longer the same as before
              1 Reply Last reply Reply Quote -2
              • TIGT Online
                @Didier-Bur needs to fix this - it's his baby...
                  Didier Bur @TIG
                  Hi all,
                  My baby is quite old now 😉
                  Here is the non-encrypted version. Please unpack in your Plugins dir.
                  No update because I haven't SU2024.
                  Regards,DBUR_Lines2Tubes.zip
                  DB
                    Didier Bur @Didier Bur
                    Me again,
                    Same goes for door_lintel.rb
                    door_lintel_uncrypted.zip
                    DB
                      JGA
                      Didier, thanks for sharing.
                      Regards,
                      JGA
                      1 Reply Last reply Reply Quote -1
                      • guanjinG Offline
                        guanjin
                        Thank you to Didier Bur for the source code, which successfully fixed the work in 2024 and modified the multi-faceted selection stretching.
                        guanjinG L sumasterS 4 Replies Last reply Reply Quote 0
                        • guanjinG Offline
                          guanjin @guanjin
                          This post is deleted!
                          • guanjinG Offline
                            guanjin @guanjin
                            @guanjin said in [Plugin] Door-Lintel Update + Window-Sill:
                            Thank you again, Didier Bur
                            A 1 Reply Last reply Reply Quote 0
                              lamngoaison
                              i got a new problem. SU2025. any one fix it for SU2025 yet? please!!
                              • TIGT Online
                                TIG Moderator @lamngoaison
                                @lamngoaison
                                The linked post contains a ZIP file posted a few days ago
                                link
                                Which can be converted to an RBZ by changing its filetype suffix.
                                It worked in v2024, so should also work in v2025 ?
                                  lamngoaison @TIG
                                  @TIG thanks alot 😁
                                    memaridrue81
                                    hi Didier Bur,
                                    May I request an update for this extension for SketchUp 2023 and higher? it work well with my SKP 2022 but file crashes when I use it in skp 2023 😊
                                    Many thanks!
                                      lamngoaison @guanjin
                                      by unknown problem. it not work anymore in my SU2025. so bro, can you share this version of your with other. thanks alot!!!
                                      • sumasterS Offline
                                        sumaster @guanjin
                                        @guanjin
                                        can you post a new updated script
                                        thanks
                                        Thank you,
                                        SUmaster
                                        • TIGT Online
                                          The linked .ZIP file is still available in the earlier post.
                                          Download it, then just change its filetype to .RBZ as previously explained.
                                          Then install it...
                                          sumasterS 1 Reply Last reply 👍 Reply Quote 0
                                          • sumasterS Offline
                                            sumaster @TIG
                                            @TIG
                                            yes thanks 👍
                                            Thank you,
                                            SUmaster
                                            • 3 / 4
