    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 52.0k Views 32 Watching
    • halroachH Offline
      halroach
      This plugin is wonderful!
      Does it work within a component? It seems to work for me only when it's in the "open!?"
      FlexTools - Super Quick Windows, Doors, Slats...
        SyahirXIII
        I have been trying to use it using Profile Builder 3 , it seems to have some kind of problem detecting rectangular vertical face.
        Dont work here
        But it seems to work here
        • Didier BurD Offline
          Didier Bur
          Hi syahirXIII,
          The message shown on your image pops up when the reveal's face loop is made of more than 4 edges.
          Please check if this is the case on the face that doesn't work.
          Regards
          DB
          guanjinG 1 Reply Last reply Reply Quote 0
          • guanjinG Offline
            guanjin @TIG
            @TIG
            hello
            This plugin doesn't seem to support sketchup2024
            A very suitable plugin, can you fix it working on sketchup024?
            thanks
            • guanjinG Offline
              guanjin @Didier Bur
              @Didier-Bur
              hello
              thanks
              • N Offline
                naealmeida Newcomers
                Hello! Can you update the plugin for the new skecthup 2024 please
                  aricfish
                  Hi All,
                  Is this plugin working in 2024 sketchup? Huge time saver but not working for me in newest version.
                  Didier BurD 1 Reply Last reply Reply Quote 0
                    Didier Bur @aricfish
                    @ SU2024 and Door-Lintel users:
                    I don't have SU2024 installed on my PC.
                    Maybe some developer (TIG ?) will update the plugin ?
                    So here it is.
                    Regards,
                    # Name :          door_lintel
                    # Description :   Draws a lintel above door between wall sides, and window as well
                    # Author :        D. Bur
                    # Usage :         select face and "Door by reveal" in context menu
                    # Date :          May 2008
                    # Type :          Tool
                    # History:        1.0 (May 2008) - first version
                    #                 1.1 (May 2008) - window added
                    require 'sketchup.rb'
                    # f=Sketchup.active_model.selection[0]
                    def trad(word)
                    	# tStrings = [["Door" "Porte"],["Window" "Fenetre"]]
                    	tStrings={ "Door" => "Porte", "Window" => "Fenêtre"}
                    	return word if Sketchup.get_locale != "fr"
                    	return tStrings[word]
                    def dbe_by_embrasure(type)
                    	model=Sketchup.active_model
                    	entities=Sketchup.active_model.active_entities
                    	@dbe_door_height=2.m if not @dbe_door_height
                    	@dbe_window_height=135.cm if not @dbe_window_height
                    	@dbe_sill_height=1.m if not @dbe_sill_height
                    	org_face=model.selection[0]
                    	model.start_operation "Door-window by reveal"
                    	  if model.selection.empty?
                    		UI.messagebox("Empty selection: please select a vertical face.")
                    		return
                    	if (model.selection.length !=1)
                    		UI.messagebox("Please select only ONE vertical face.")
                    		return
                    	if  (model.selection[0].class != Sketchup::Face)
                    		UI.messagebox("Please select a vertical face.")
                    		return
                    	if org_face.normal.z>1e-012 or org_face.normal.z<-1e-012
                    		UI.messagebox("Please select a VERTICAL face.")
                    		return
                    	if org_face.outer_loop.edges.length != 4
                    		UI.messagebox("Please select a RECTANGULAR vertical face.")
                    		return
                    	 # Parse edges
                    	edges=org_face.edges
                    	@verticals={}
                    	@horizontals={}
                    	edges.each do |e|
                    		if e.start.position.z==e.end.position.z
                    			@horizontals[e]=e.start.position.z
                    		else
                    			@verticals[e]=e.start.position.distance e.end.position
                    	# Dialog
                    	#puts "type " + type.inspect
                    	if type=="door"
                    		return if !dbe_door_height()
                    	else
                    		return if !dbe_window_height()
                    	# heights control
                    	if type=="door"
                    		height_ok=false
                    		until height_ok
                    			if @dbe_door_height<@verticals.values.max #or (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
                    				height_ok =true
                    			else
                    				UI.messagebox("Incorrect height for this door.\nPlease set it to a lower value than " +@verticals.values.max.to_s)
                    	if type=="window"
                    		heights_ok=false
                    		until heights_ok
                    			if (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
                    				heights_ok =true
                    			else
                    				UI.messagebox("Incorrect heights for this windows.\nSum of sill and window heights should'nt exceed "  + @verticals.values.max.to_s)
                      # Highest edge & lintel height
                      high_edge=@horizontals.index(@horizontals.values.max)
                      bottom_edge=@horizontals.index(@horizontals.values.min)
                      lintel_height=@verticals.values.max-@dbe_door_height if type=="door"
                      lintel_height=@verticals.values.max-(@dbe_window_height+@dbe_sill_height) if type=="window"
                      # New face of lintel
                      p1=high_edge.start.position
                      p2=high_edge.end.position
                      p3=Geom::Point3d.new(p1.x,p1.y,(p1.z-lintel_height))
                      p4=Geom::Point3d.new(p2.x,p2.y,(p2.z-lintel_height))
                      # Mid point of lintel
                      v=p2.vector_to p3
                      v.length=v.length/2.0
                      mid=p2.offset(v)
                      # Opening width
                      v_norm=org_face.normal
                      touch=model.raytest([mid,v_norm])
                      if touch
                        same_object=true
                        hitpoint=touch[0]
                        hit_obj=touch[1]
                        if hit_obj.length>1
                          hit_face=hit_obj.last
                          hit_parent=hit_obj[0]
                          if not hit_parent.entities.include? org_face
                            same_object=false
                          else
                          hit_parent=hit_obj.last
                        width=mid.distance hitpoint
                        if width > 200
                          go=UI.messagebox("Suspicious door width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
                          return nil if go==2
                        case hit_parent.typename
                          when "Face"
                            if org_face.normal!=hit_face.normal.reverse
                              UI.messagebox("Opposite reveal not parallel to selected face. Aborting...")
                              return nil
                          else
                            if same_object==false
                              UI.messagebox("Cannot find opposite wall,\nobstructive "+hit_parent.typename+" found on layer "+hit_parent.layer.name+ ".\nPlease hide it and retry.")
                              return
                      else
                        UI.messagebox("No opposite wall to connect lintel.")
                        return nil
                      new_face=entities.add_face p1,p2,p4,p3
                      if touch and same_object==true
                        v2=new_face.normal
                        v2.length=width
                        new_face.pushpull width
                        else
                        UI.messagebox("Cannot pushpull lintel.")
                      #Redraw these fucking remaining edges to better kill them
                      e1=entities.add_line(p1.offset(v2),p2.offset(v2))
                      e2=entities.add_line(p1.offset(v2),p3.offset(v2))
                      e3=entities.add_line(p2.offset(v2),p4.offset(v2))
                      e1.erase!
                      e2.erase!
                      e3.erase!
                      if type=="window"
                        # New face of sill
                        p1=bottom_edge.start.position
                        p2=bottom_edge.end.position
                        p3=Geom::Point3d.new(p1.x,p1.y,(p1.z+@dbe_sill_height))
                        p4=Geom::Point3d.new(p2.x,p2.y,(p2.z+@dbe_sill_height))
                        # Mid point of sill
                        v=p2.vector_to p3
                        mid=p2.offset(v)
                        # Opening width
                        if touch
                          same_object=true
                          hitpoint=touch[0]
                          hit_obj=touch[1]
                          if hit_obj.length>1
                            #if not hit_parent.entities.include? org_face
                              #same_object=false
                            #end
                          else
                        if width > 200
                          go=UI.messagebox("Suspicious window width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
                          return nil if go==2
                          when "Face"
                            if v_norm!=hit_face.normal.reverse
                              return nil
                          else
                              return
                      else
                        UI.messagebox("No opposite wall to connect linter.")
                        return nil
                        v2=new_face.normal
                        v2.length=width
                        else
                        UI.messagebox("Cannot pushpull sill.")
                      e1.erase!
                      e2.erase!
                      e3.erase!
                      end # if window
                      model.commit_operation
                    def dbe_door_height
                    	prompt=["Door height: "]
                    	value=[@dbe_door_height]
                    	results=inputbox prompt,value,"Door height"
                    	puts results.inspect
                    	return false if !results
                    	@dbe_door_height=results[0]
                    def dbe_window_height
                    	prompts=["Sill height:  ","Window height:  "]
                    	values=[@dbe_sill_height,@dbe_window_height]
                    	results=inputbox prompts,values,"Window heights"
                    	@dbe_sill_height=results[0]
                    	@dbe_window_height=results[1]
                    def valid_door_selection
                      s=Sketchup.active_model.selection
                      return false if s.length!=1
                      return false if s[0].typename!="Face"
                      return false if s[0].normal.z>1e-012 or s[0].normal.z<-1e-012
                      return false  if s[0].outer_loop.edges.length != 4
                      return true
                    # add menu items
                    if !file_loaded?(__FILE__ )
                      dbe_menu=UI.menu("Tools").add_submenu("Door/Window by reveal")
                      dbe_menu.add_item("Door") { dbe_by_embrasure "door"}
                      dbe_menu.add_item("Window") { dbe_by_embrasure "window" }
                      dbe_menu.add_separator
                       # Context menu
                        UI.add_context_menu_handler do |menu|
                            if( valid_door_selection )
                            		menu.add_separator
                                menu.add_item("Door by reveal") { dbe_by_embrasure "door" }
                                menu.add_item("Window by reveal") { dbe_by_embrasure "window" }
                                menu.add_separator
                    file_loaded(__FILE__ )
                    DB
                    • guanjinG Offline
                      guanjin @Didier Bur
                      @Didier-Bur
                      It seems that no one has fixed this plugin😞
                      TIGT 1 Reply Last reply Reply Quote 0
                        TIG Moderator @guanjin
                        @guanjin
                        It doesn't work in v2024 [various errors], e.g.
                        Error: #<NoMethodError: undefined method 'index' for {#Sketchup::Edge:0x0000019daaeab1b0=>0.0, #Sketchup::Edge:0x0000019daaeab160=>39.37007874015748}:Hash>
                        C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 100:in 'dbe_by_embrasure'
                        C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 274:in `block in <top (required)>'
                        @Didier-Bur also obfuscates his code, so without arduously repacking it back into RB code it'd be difficult to say what the issues are...
                        • guanjinG Offline
                          guanjin
                          So many experts, no one can fix this plugin
                          The forum is no longer the same as before
                          1 Reply Last reply Reply Quote -2
                            @Didier-Bur needs to fix this - it's his baby...
                              Didier Bur @TIG
                              Hi all,
                              My baby is quite old now 😉
                              Here is the non-encrypted version. Please unpack in your Plugins dir.
                              No update because I haven't SU2024.
                              Regards,DBUR_Lines2Tubes.zip
                              DB
                                Didier Bur @Didier Bur
                                Me again,
                                Same goes for door_lintel.rb
                                door_lintel_uncrypted.zip
                                DB
                                  JGA
                                  Didier, thanks for sharing.
                                  Regards,
                                  JGA
                                  1 Reply Last reply Reply Quote -1
                                  • guanjinG Offline
                                    guanjin
                                    Thank you to Didier Bur for the source code, which successfully fixed the work in 2024 and modified the multi-faceted selection stretching.
                                    guanjinG L sumasterS 4 Replies Last reply Reply Quote 0
                                    • guanjinG Offline
                                      guanjin @guanjin
                                      This post is deleted!
                                      • guanjinG Offline
                                        guanjin @guanjin
                                        @guanjin said in [Plugin] Door-Lintel Update + Window-Sill:
                                        Thank you again, Didier Bur
                                        A 1 Reply Last reply Reply Quote 0
                                          lamngoaison
                                          i got a new problem. SU2025. any one fix it for SU2025 yet? please!!
                                            TIG Moderator @lamngoaison
                                            @lamngoaison
                                            The linked post contains a ZIP file posted a few days ago
                                            link
                                            Which can be converted to an RBZ by changing its filetype suffix.
                                            It worked in v2024, so should also work in v2025 ?
                                            • 3 / 4
