    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 53.9k Views 32 Watching
      pankaj_tamore
      Dear Didier Bur,
      This so magical very easy to use and give incredible result. because it saves lot of time which is consumed by conventional method(which is very cumbersome) of putting doors And windows. your this plug-in has put an end on that ordeal of deleting every single vertical and horizontal line on faces of walls, which very irritating thank you very much and keep it up!
      • jujuJ Offline
        juju
        @tig said:
        Sorry, but although I had updated the RBZ I forgot to click 'Publish' in the PluginStore Dev-page...
        NOW its Download link should work !
        EXCELLENT! THX
        • halroachH Offline
          halroach
          This plugin is wonderful!
          Does it work within a component? It seems to work for me only when it's in the "open!?"
          FlexTools - Super Quick Windows, Doors, Slats...
            SyahirXIII
            I have been trying to use it using Profile Builder 3 , it seems to have some kind of problem detecting rectangular vertical face.
            Dont work here
            But it seems to work here
            • Didier BurD Offline
              Didier Bur
              Hi syahirXIII,
              The message shown on your image pops up when the reveal's face loop is made of more than 4 edges.
              Please check if this is the case on the face that doesn't work.
              Regards
              DB
              guanjinG 1 Reply Last reply Reply Quote 0
              • guanjinG Offline
                guanjin @TIG
                @TIG
                hello
                This plugin doesn't seem to support sketchup2024
                A very suitable plugin, can you fix it working on sketchup024?
                thanks
                • guanjinG Offline
                  guanjin @Didier Bur
                  @Didier-Bur
                  hello
                  thanks
                  • N Offline
                    naealmeida Newcomers
                    Hello! Can you update the plugin for the new skecthup 2024 please
                      aricfish
                      Hi All,
                      Is this plugin working in 2024 sketchup? Huge time saver but not working for me in newest version.
                      Didier BurD 1 Reply Last reply Reply Quote 0
                        Didier Bur @aricfish
                        @ SU2024 and Door-Lintel users:
                        I don't have SU2024 installed on my PC.
                        Maybe some developer (TIG ?) will update the plugin ?
                        So here it is.
                        Regards,
                        # Name :          door_lintel
                        # Description :   Draws a lintel above door between wall sides, and window as well
                        # Author :        D. Bur
                        # Usage :         select face and "Door by reveal" in context menu
                        # Date :          May 2008
                        # Type :          Tool
                        # History:        1.0 (May 2008) - first version
                        #                 1.1 (May 2008) - window added
                        require 'sketchup.rb'
                        # f=Sketchup.active_model.selection[0]
                        def trad(word)
                        	# tStrings = [["Door" "Porte"],["Window" "Fenetre"]]
                        	tStrings={ "Door" => "Porte", "Window" => "Fenêtre"}
                        	return word if Sketchup.get_locale != "fr"
                        	return tStrings[word]
                        def dbe_by_embrasure(type)
                        	model=Sketchup.active_model
                        	entities=Sketchup.active_model.active_entities
                        	@dbe_door_height=2.m if not @dbe_door_height
                        	@dbe_window_height=135.cm if not @dbe_window_height
                        	@dbe_sill_height=1.m if not @dbe_sill_height
                        	org_face=model.selection[0]
                        	model.start_operation "Door-window by reveal"
                        	  if model.selection.empty?
                        		UI.messagebox("Empty selection: please select a vertical face.")
                        		return
                        	if (model.selection.length !=1)
                        		UI.messagebox("Please select only ONE vertical face.")
                        		return
                        	if  (model.selection[0].class != Sketchup::Face)
                        		UI.messagebox("Please select a vertical face.")
                        		return
                        	if org_face.normal.z>1e-012 or org_face.normal.z<-1e-012
                        		UI.messagebox("Please select a VERTICAL face.")
                        		return
                        	if org_face.outer_loop.edges.length != 4
                        		UI.messagebox("Please select a RECTANGULAR vertical face.")
                        		return
                        	 # Parse edges
                        	edges=org_face.edges
                        	@verticals={}
                        	@horizontals={}
                        	edges.each do |e|
                        		if e.start.position.z==e.end.position.z
                        			@horizontals[e]=e.start.position.z
                        		else
                        			@verticals[e]=e.start.position.distance e.end.position
                        	# Dialog
                        	#puts "type " + type.inspect
                        	if type=="door"
                        		return if !dbe_door_height()
                        	else
                        		return if !dbe_window_height()
                        	# heights control
                        	if type=="door"
                        		height_ok=false
                        		until height_ok
                        			if @dbe_door_height<@verticals.values.max #or (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
                        				height_ok =true
                        			else
                        				UI.messagebox("Incorrect height for this door.\nPlease set it to a lower value than " +@verticals.values.max.to_s)
                        	if type=="window"
                        		heights_ok=false
                        		until heights_ok
                        			if (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
                        				heights_ok =true
                        			else
                        				UI.messagebox("Incorrect heights for this windows.\nSum of sill and window heights should'nt exceed "  + @verticals.values.max.to_s)
                          # Highest edge & lintel height
                          high_edge=@horizontals.index(@horizontals.values.max)
                          bottom_edge=@horizontals.index(@horizontals.values.min)
                          lintel_height=@verticals.values.max-@dbe_door_height if type=="door"
                          lintel_height=@verticals.values.max-(@dbe_window_height+@dbe_sill_height) if type=="window"
                          # New face of lintel
                          p1=high_edge.start.position
                          p2=high_edge.end.position
                          p3=Geom::Point3d.new(p1.x,p1.y,(p1.z-lintel_height))
                          p4=Geom::Point3d.new(p2.x,p2.y,(p2.z-lintel_height))
                          # Mid point of lintel
                          v=p2.vector_to p3
                          v.length=v.length/2.0
                          mid=p2.offset(v)
                          # Opening width
                          v_norm=org_face.normal
                          touch=model.raytest([mid,v_norm])
                          if touch
                            same_object=true
                            hitpoint=touch[0]
                            hit_obj=touch[1]
                            if hit_obj.length>1
                              hit_face=hit_obj.last
                              hit_parent=hit_obj[0]
                              if not hit_parent.entities.include? org_face
                                same_object=false
                              else
                              hit_parent=hit_obj.last
                            width=mid.distance hitpoint
                            if width > 200
                              go=UI.messagebox("Suspicious door width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
                              return nil if go==2
                            case hit_parent.typename
                              when "Face"
                                if org_face.normal!=hit_face.normal.reverse
                                  UI.messagebox("Opposite reveal not parallel to selected face. Aborting...")
                                  return nil
                              else
                                if same_object==false
                                  UI.messagebox("Cannot find opposite wall,\nobstructive "+hit_parent.typename+" found on layer "+hit_parent.layer.name+ ".\nPlease hide it and retry.")
                                  return
                          else
                            UI.messagebox("No opposite wall to connect lintel.")
                            return nil
                          new_face=entities.add_face p1,p2,p4,p3
                          if touch and same_object==true
                            v2=new_face.normal
                            v2.length=width
                            new_face.pushpull width
                            else
                            UI.messagebox("Cannot pushpull lintel.")
                          #Redraw these fucking remaining edges to better kill them
                          e1=entities.add_line(p1.offset(v2),p2.offset(v2))
                          e2=entities.add_line(p1.offset(v2),p3.offset(v2))
                          e3=entities.add_line(p2.offset(v2),p4.offset(v2))
                          e1.erase!
                          e2.erase!
                          e3.erase!
                          if type=="window"
                            # New face of sill
                            p1=bottom_edge.start.position
                            p2=bottom_edge.end.position
                            p3=Geom::Point3d.new(p1.x,p1.y,(p1.z+@dbe_sill_height))
                            p4=Geom::Point3d.new(p2.x,p2.y,(p2.z+@dbe_sill_height))
                            # Mid point of sill
                            v=p2.vector_to p3
                            mid=p2.offset(v)
                            # Opening width
                            if touch
                              same_object=true
                              hitpoint=touch[0]
                              hit_obj=touch[1]
                              if hit_obj.length>1
                                #if not hit_parent.entities.include? org_face
                                  #same_object=false
                                #end
                              else
                            if width > 200
                              go=UI.messagebox("Suspicious window width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
                              return nil if go==2
                              when "Face"
                                if v_norm!=hit_face.normal.reverse
                                  return nil
                              else
                                  return
                          else
                            UI.messagebox("No opposite wall to connect linter.")
                            return nil
                            v2=new_face.normal
                            v2.length=width
                            else
                            UI.messagebox("Cannot pushpull sill.")
                          e1.erase!
                          e2.erase!
                          e3.erase!
                          end # if window
                          model.commit_operation
                        def dbe_door_height
                        	prompt=["Door height: "]
                        	value=[@dbe_door_height]
                        	results=inputbox prompt,value,"Door height"
                        	puts results.inspect
                        	return false if !results
                        	@dbe_door_height=results[0]
                        def dbe_window_height
                        	prompts=["Sill height:  ","Window height:  "]
                        	values=[@dbe_sill_height,@dbe_window_height]
                        	results=inputbox prompts,values,"Window heights"
                        	@dbe_sill_height=results[0]
                        	@dbe_window_height=results[1]
                        def valid_door_selection
                          s=Sketchup.active_model.selection
                          return false if s.length!=1
                          return false if s[0].typename!="Face"
                          return false if s[0].normal.z>1e-012 or s[0].normal.z<-1e-012
                          return false  if s[0].outer_loop.edges.length != 4
                          return true
                        # add menu items
                        if !file_loaded?(__FILE__ )
                          dbe_menu=UI.menu("Tools").add_submenu("Door/Window by reveal")
                          dbe_menu.add_item("Door") { dbe_by_embrasure "door"}
                          dbe_menu.add_item("Window") { dbe_by_embrasure "window" }
                          dbe_menu.add_separator
                           # Context menu
                            UI.add_context_menu_handler do |menu|
                                if( valid_door_selection )
                                		menu.add_separator
                                    menu.add_item("Door by reveal") { dbe_by_embrasure "door" }
                                    menu.add_item("Window by reveal") { dbe_by_embrasure "window" }
                                    menu.add_separator
                        file_loaded(__FILE__ )
                        DB
                        • guanjinG Offline
                          guanjin @Didier Bur
                          @Didier-Bur
                          It seems that no one has fixed this plugin😞
                          TIGT 1 Reply Last reply Reply Quote 0
                            TIG Moderator @guanjin
                            @guanjin
                            It doesn't work in v2024 [various errors], e.g.
                            Error: #<NoMethodError: undefined method 'index' for {#Sketchup::Edge:0x0000019daaeab1b0=>0.0, #Sketchup::Edge:0x0000019daaeab160=>39.37007874015748}:Hash>
                            C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 100:in 'dbe_by_embrasure'
                            C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 274:in `block in <top (required)>'
                            @Didier-Bur also obfuscates his code, so without arduously repacking it back into RB code it'd be difficult to say what the issues are...
                            • guanjinG Offline
                              guanjin
                              So many experts, no one can fix this plugin
                              The forum is no longer the same as before
                              1 Reply Last reply Reply Quote -2
                                @Didier-Bur needs to fix this - it's his baby...
                                  Didier Bur @TIG
                                  Hi all,
                                  My baby is quite old now 😉
                                  Here is the non-encrypted version. Please unpack in your Plugins dir.
                                  No update because I haven't SU2024.
                                  Regards,DBUR_Lines2Tubes.zip
                                  DB
                                    Didier Bur @Didier Bur
                                    Me again,
                                    Same goes for door_lintel.rb
                                    door_lintel_uncrypted.zip
                                    DB
                                      JGA
                                      Didier, thanks for sharing.
                                      Regards,
                                      JGA
                                      1 Reply Last reply Reply Quote -1
                                      • guanjinG Offline
                                        guanjin
                                        Thank you to Didier Bur for the source code, which successfully fixed the work in 2024 and modified the multi-faceted selection stretching.
                                        guanjinG L sumasterS 4 Replies Last reply Reply Quote 0
                                        • guanjinG Offline
                                          guanjin @guanjin
                                          This post is deleted!
                                          • guanjinG Offline
                                            guanjin @guanjin
                                            @guanjin said in [Plugin] Door-Lintel Update + Window-Sill:
                                            Thank you again, Didier Bur
                                            A 1 Reply Last reply Reply Quote 0
                                            • 3 / 4
