    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • samuel_tS
      samuel_t @MikeG73
      @MikeG73 I'm not sure to understand you.
      Universal Importer isn't compatible with recent .blend files but this may change in the future 🙂
      • samuel_tS
        samuel_t @vadhome
        @vadhome I rented a Mac Mini M1 for 24H but I couldn't reproduce the bug shown in your screenshot, at least with macOS Sonoma 14.6.1. However, SketchUp 2025 crashed several times randomly when placing the model to import. I need to investigate further...
        • B
          brianroy2 Newcomers
          Hi Samuel using a Mac Air Running Sequoia 15.1.1 when I am trying to convert a STEP file I am getting this error message
          samuel_tS 1 Reply Last reply
          • samuel_tS
            samuel_t @brianroy2
            @brianroy2
            Hi, thanks for your bug report.
            I would be interested to have a copy of this STEP file (in private if you prefer) to confirm or not if this issue is macOS-specific 🤔
            How did you install Universal Importer, using the Extension Manager or another method?
            Could you please open the Terminal app on your Mac, paste the two commands below (one after the other), and send me their output?
            xattr "/Users/brianroy/Library/Application Support/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Mayo/Mac/mayo-conv"
            "/Users/brianroy/Library/Application Support/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Mayo/Mac/mayo-conv" --system-info
              Hello
              ça faisait longtemps! 🙂 SketchUp Make 2017
              J'ai fait marché le plugin avec des modèles FBX réalisés avec le Free Tripo AI!
              En Retopologie basse résolution Game Asset (3000) pas de problème!
              A la résolution du dessus, (Low 5000) je n'ai pas la proposition de réduction des polygones dans Universal Importer!
              Et donc mon écran reste noir! Et cela échoue!
              Y a-t-il un nombre maximum en entrée ?
              Merci d'avance des conseils! 🙂
              mon modèle :
              https://www.tripo3d.ai/app/model/d122e434-c32d-4bac-adaa-1d47968dd18f
              Le modèle donné par Tripo
              Mon propre modèle
              • samuel_tS
                samuel_t @pilou
                @pilou Hello, how have you been since then?
                I haven't set any hard limits in the Universal Importer plugin code... However, depending on your machine's specifications (especially the amount of system RAM), the import may be slow or even fail.
                Or maybe the second retopology generates an invalid model.
                Can you please send me the files directly in both resolutions? Because I don't wish to spend Tripo credits 😅
                  @samuel_t
                  Med resolution (who don't works)
                  https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_a8a4796d-366a-45ec-b815-09b229a99bbd__2_.fbx
                  Low resolution who works
                  https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_c35581b0-d804-4224-990b-b31022f0afd8.fbx
                  Maybe the textures...
                  https://moiscript.weebly.com/uploads/3/9/3/8/3938813/uir-source.fbx
                  But maybe sure on my latop 12 years old there is only 8G Hard Memory! 🙂
                  • U
                    Uhlala Newcomers
                    Hi, I have the same message as romanencom with Universal Importer 1.2.6
                    Any idea? Thanks.
                    • U
                      Uhlala Newcomers @romanencom
                      @romanencodem Hi, I have the same issue with Universal Importer 1.2.6
                      • B
                        BGUERRE
                        hello
                        thank you to provide universal importer to the SU community.
                        Unfortunately, i did try to dowload .obj file, but get the following error message
                        OBJ fil is about 16 MO and he was generating by 3D Snap an IOS app.
                        Any suggestion ?.
                        thank you
                        Bruno
                        • samuel_tS
                          samuel_t @BGUERRE
                          @BGUERRE Hello,
                          You're welcome!
                          Seems there's an issue in .MTL file paired with .OBJ file.
                          Can you please upload them and send me both (in private if you prefer)?
                          • Rich O BrienR Rich O Brien referenced this topic on
                          • K
                            kevgrn114 Newcomers
                            Hi, Just found your Universal plugin today, I've been wanting something like that for a long time!! It seem to work fine for me exporting dxf files from lightburn except that anything that is a curve is chopped up into dashed lines. Squares come in fine but circles or curves get the dash effect. Any thoughts? Thanks
                            • T
                              titiinorbita
                              This post is deleted!
                                artemisglt
                                hello! and thank you for the great plug in! I am trying to import an obj file of this bed in sketchup.
                                link text
                                I select the option to claim missing textures and select the obj file. In which order do I select the textures?
                                The model has a diffuse map, two normal maps and a displacement map. If I select the diffuse map and the two normal maps, I get an error..
                                Any ideas?
                                panixiaP 1 Reply Last reply
                                • panixiaP
                                  panixia @artemisglt
                                  @artemisglt You just select the diffuse map and call it a day.
                                  (you can add the other maps after the import if you really need them)
                                  A 1 Reply Last reply
                                    artemisglt @panixia
                                    @panixia if i press claim missing textures, then import the obj object, I select the diffuse map and then it asks me to select again another missing texture. if i click the normal map, it asks me for a third texture and if select all three I receive an error. if i select the diffuse map every time again I receive an error.. any ideas?
                                    • panixiaP
                                      panixia @artemisglt
                                      @artemisglt does it happen with a specific model or with all models?
                                        artemisglt @panixia
                                        @panixia it happens with all the models, that is why I asked to see what I am doing wrong. I send the link to the initial model, I referred to, if you can have a look.
                                          mblally Newcomers
                                          Hello, thank you for the community plugin, but I'm getting this error message when I try to import. It looks like you had someone else with a similar error about a year ago. Any solution?
                                          • samuel_tS
                                            samuel_t @mblally
                                            @mblally Hello. You're welcome! This issue will be fixed in the next plugin version.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 23 / 23
