    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
      sashapepperspray @sashapepperspray
      @sashapepperspray
      I have installed an older version of the plugin (1.1.9) and I now can do poligon reduction, but I can't import, I get the following error messageScreenshot 2024-11-21 201114.png Screenshot 2024-11-21 201155.png
      do you have any ideas?
      samuel_tS 1 Reply Last reply
      • E
        esthery Newcomers
        getting this error.. any solution?
        • samuel_tS
          samuel_t @shagrat
          @shagrat Sorry, I didn't see your posts. I think it's too late now...
          This issue could be related to importing a model from a remote server (here \\fileserver).
          • samuel_tS
            samuel_t @vadhome
            @vadhome Hi! Someone else reported an issue importing CAD files (such as STEP) on macOS with Universal Importer. I plan to rent a Mac to investigate...
            • samuel_tS
              samuel_t @sashapepperspray
              @sashapepperspray, @esthery Can you please send me (in private if you prefer) the source model you're trying to import?
                sashapepperspray @samuel_t
                @samuel_t Any model I try doesn't work, but here is onejuggler.obj
                • MikeG73M
                  MikeG73
                  The importer does not seem to except .blend files either
                  Cheers!
                  • samuel_tS
                    @sashapepperspray Thanks for the example model file! I successfully imported it with Universal Importer v1.2.6.
                    Something goes wrong on your system... 😕 You can try once again to reinstall the Microsoft Visual C++ library.
                    • samuel_tS
                      samuel_t @MikeG73
                      @MikeG73 I'm not sure to understand you.
                      Universal Importer isn't compatible with recent .blend files but this may change in the future 🙂
                      • samuel_tS
                        samuel_t @vadhome
                        @vadhome I rented a Mac Mini M1 for 24H but I couldn't reproduce the bug shown in your screenshot, at least with macOS Sonoma 14.6.1. However, SketchUp 2025 crashed several times randomly when placing the model to import. I need to investigate further...
                        • B
                          brianroy2 Newcomers
                          Hi Samuel using a Mac Air Running Sequoia 15.1.1 when I am trying to convert a STEP file I am getting this error message
                          • samuel_tS
                            samuel_t @brianroy2
                            @brianroy2
                            Hi, thanks for your bug report.
                            I would be interested to have a copy of this STEP file (in private if you prefer) to confirm or not if this issue is macOS-specific 🤔
                            How did you install Universal Importer, using the Extension Manager or another method?
                            Could you please open the Terminal app on your Mac, paste the two commands below (one after the other), and send me their output?
                            xattr "/Users/brianroy/Library/Application Support/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Mayo/Mac/mayo-conv"
                            "/Users/brianroy/Library/Application Support/SketchUp 2024/SketchUp/Plugins/universal_importer/Applications/Mayo/Mac/mayo-conv" --system-info
                              Hello
                              ça faisait longtemps! 🙂 SketchUp Make 2017
                              J'ai fait marché le plugin avec des modèles FBX réalisés avec le Free Tripo AI!
                              En Retopologie basse résolution Game Asset (3000) pas de problème!
                              A la résolution du dessus, (Low 5000) je n'ai pas la proposition de réduction des polygones dans Universal Importer!
                              Et donc mon écran reste noir! Et cela échoue!
                              Y a-t-il un nombre maximum en entrée ?
                              Merci d'avance des conseils! 🙂
                              mon modèle :
                              https://www.tripo3d.ai/app/model/d122e434-c32d-4bac-adaa-1d47968dd18f
                              Le modèle donné par Tripo
                              Mon propre modèle
                              • samuel_tS
                                samuel_t @pilou
                                @pilou Hello, how have you been since then?
                                I haven't set any hard limits in the Universal Importer plugin code... However, depending on your machine's specifications (especially the amount of system RAM), the import may be slow or even fail.
                                Or maybe the second retopology generates an invalid model.
                                Can you please send me the files directly in both resolutions? Because I don't wish to spend Tripo credits 😅
                                  @samuel_t
                                  Med resolution (who don't works)
                                  https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_a8a4796d-366a-45ec-b815-09b229a99bbd__2_.fbx
                                  Low resolution who works
                                  https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_c35581b0-d804-4224-990b-b31022f0afd8.fbx
                                  Maybe the textures...
                                  https://moiscript.weebly.com/uploads/3/9/3/8/3938813/uir-source.fbx
                                  But maybe sure on my latop 12 years old there is only 8G Hard Memory! 🙂
                                  • U
                                    Uhlala Newcomers
                                    Hi, I have the same message as romanencom with Universal Importer 1.2.6
                                    Any idea? Thanks.
                                    • U
                                      Uhlala Newcomers @romanencom
                                      @romanencodem Hi, I have the same issue with Universal Importer 1.2.6
                                      • B
                                        BGUERRE
                                        hello
                                        thank you to provide universal importer to the SU community.
                                        Unfortunately, i did try to dowload .obj file, but get the following error message
                                        OBJ fil is about 16 MO and he was generating by 3D Snap an IOS app.
                                        Any suggestion ?.
                                        thank you
                                        Bruno
                                        • samuel_tS
                                          samuel_t @BGUERRE
                                          @BGUERRE Hello,
                                          You're welcome!
                                          Seems there's an issue in .MTL file paired with .OBJ file.
                                          Can you please upload them and send me both (in private if you prefer)?
                                          • Rich O BrienR Rich O Brien referenced this topic on
                                          • K
                                            kevgrn114 Newcomers
                                            Hi, Just found your Universal plugin today, I've been wanting something like that for a long time!! It seem to work fine for me exporting dxf files from lightburn except that anything that is a curve is chopped up into dashed lines. Squares come in fine but circles or curves get the dash effect. Any thoughts? Thanks
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
